POV-Ray : Newsgroups : povray.windows : file output??? Server Time
12 Jun 2026 12:57:49 EDT (-0400)
  file output??? (Message 1 to 5 of 5)
Subject: file output???
Date: 16 Sep 1999 13:55:59
Message: <37e12f2f@news.povray.org>
I am using POVRay 3.1 for win98 and I can't find an option anywhere to save
the image to disk.  How on earth do I do that?  Is there a good site that
explains these sorts of things?  The help file that came with it does a
terrible job of explaining out to use the program (it only ges into detail
about what the menu options mean, which doesn't do a damn thing for me
because I can't find the bloody option).  I need help with this ASAP.
Thanks
Sean Robertson
Multimedia Artist, PilotOnline
_______________________________________
Work Email: sea### [at] infinet
Personal Email: web### [at] webolutionarycom
trueSpace-Mania: http://truespace.mania-online.com
Midi-Mania: http://midi.mania-online.com
Subject: Re: file output???
Date: 16 Sep 1999 14:55:14
Message: <37e13d12@news.povray.org>
Hi there Sean,
  POV-Ray 3.0* Doc was better suited to the tutorial aspect perhaps,
matter of opinion really.  Anyway, all you need do is have a scene
file (*.pov) open in the editor and press the Run button for Windows
version.
This renders your scene and saves the file as the scene name with a
Bmp extension into C:\images\ folder (if you so set up during install,
otherwise it goes into the folder where the scene file resides).
Sean Robertson <sea### [at] infinet> wrote in message
news:37e12f2f@news.povray.org...
to save
that
does a
detail
me
ASAP.
> Thanks
> Sean Robertson
Date: 16 Sep 1999 15:06:06
Message: <1z=hNzLVLMRghy1a+9tHcEQTN347@4ax.com>
On Thu, 16 Sep 1999 13:58:00 -0400, "Sean Robertson" <sea### [at] infinet> wrote:
>Thanks
Sean
In the "Tools" menu go to "Edit master POVRAY.INI"
Notepad will then launch and if you look through this file you will see a line;
Output_File_Name= <file>   where <file> is the location in which POV-Ray will store
the
output files.  This has a default option that I have forgotten, but you will see it.
Look
in there and you should see all the files that you have been rendered.
You can edit this line and the one that follows to have files stored where you want
and
choose from the several file formats available.
In my case I have edited these lines to read;
Output_File_Name=C:\POV images\tga\
+FC
This means that all my output files are stored C:\POV Images\tga and are in compressed
targa format.
To get further information on the options available look in the main POV-Ray
documentation
under "File Output Options"
Hope this helps,
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 16 Sep 1999 15:38:11
Message: <37E146AE.CD127D51@pacbell.net>
> Thanks
> Sean Robertson
  The others already answered your primary question but since you are
likely to have others similar to this one I suggest you spend a few
minutes browsing through the VFAQ. It was put together by several of
the people here concerning questions that fall into the "very frequently
asked questions" category and you can learn a lot of the basics from this
list.
http://www.students.tut.fi/~warp/povVFAQ.html
  Also see my links page for a wealth of online tutorials and POV-Ray
related programs, resources, and utilities.
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 17 Sep 1999 03:59:34
Message: <37E1F587.251484F3@inapg.inra.fr>
I suspect that you don't use the right help file. There are two of them, a
system-specific one that explains the interface and a general one that explains
the syntax and options. In the windows version, the first one is called "Help
on Pov-ray for windows" and the second one is called "Help on the pov-ray scene
language" (both available in the Help menu). Look for the second help file.
Gilles Tran
