POV-Ray : Newsgroups : povray.windows : converting HALO to MEDIA Server Time
22 Jul 2026 01:17:23 EDT (-0400)
  converting HALO to MEDIA (Message 1 to 4 of 4)
Subject: converting HALO to MEDIA
Date: 18 Aug 1999 12:52:46
Message: <37BAE519.8CEEA93E@accn.org>
Could someone tell me how to convert the HALO keyword in old POV files
to the newer POV 3.1 MEDIA clause? THanks.
Subject: Re: converting HALO to MEDIA
Date: 19 Aug 1999 03:20:39
Message: <37BBB046.725D3C9C@pacbell.net>
http://members.xoom.com/POVRAY3/media1.html
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 19 Aug 1999 09:09:56
Message: <37BC0262.7A2D9468@accn.org>
Thanks, but I didn't see anything about converting HALO to MEDIA there.
Just a tutorial on MEDIA. I was looking for a conversion program really.
> Ken Tyler
Date: 19 Aug 1999 09:17:04
Message: <37BC03D0.9ACC4413@pacbell.net>
  There are no programs or even include files that I have heard of which
can accomplish this. I have only had one occasion where I needed to convert
a halo to media and I personally found it a rather straight forward job.
The syntax between the two is similar enough that it shouldn't be too
difficult for you if you work at it a bit and refer to the docs in the
related sections. If you have a particular example that is causing you
problems then post it in the appropriate group and I'm sure someone will
lend you a hand until you are up to speed on it. I would say that that
person would be me but I never really learned how to use the halo feature
and dove straight into media when it came out. Others however have made
the transition OK so I suppose it is a fairly easy thing to do.
Ken Tyler
