POV-Ray : Newsgroups : povray.windows : I am new to POV Ray Server Time
17 Mar 2026 13:37:41 EDT (-0400)
  I am new to POV Ray (Message 1 to 10 of 13)
Subject: I am new to POV Ray
Date: 3 Jul 1999 14:25:34
Message: <377E6285.D2A07FDD@earthlink.net>
Could anyone please send me some good tutorials for pov ray?  I just
downloaded the program yesterday and I have basic skills for the
software.  Thanks.
Subject: Re: I am new to POV Ray
Date: 3 Jul 1999 14:32:19
Message: <377E56E7.C9F9478E@pacbell.net>
> software.  Thanks.
 Welcome aboard. Go to the group povray.announce.frequently-asked-questions
and look for my tutorials faq. It contains an extremely large list of on
line tutorials aimed at both new users and advanced alike. While there
be sure to check out my massive collection of links. These links were
gathered with the Pov-Ray artist in mind and the resources available are
impressive.
  I also have an online links page at the address below but the list on
this server is much more upto date and has several hundred more links
than my site does.
http://home.pacbell.net/tylereng/links.htm
  When none of these links or tutorials answer your questions we will be
around to help answer any questions you may have.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 3 Jul 1999 14:41:29
Message: <377E6640.53945851@earthlink.net>
Ken,
   Hi again, is there anyway you could help me out with pov ray?  I
viewed those web pages and they have good resources but I am mainly
looking for how to create text and also how to use all the different
textures like S_Cloud1.  If you could please help me then just mail me
or reply back.  Thanks.
                        Travis Barton
> software.  Thanks.
Date: 3 Jul 1999 14:53:23
Message: <377E5BD6.30C79D7@pacbell.net>
> Ken,
>                         Travis Barton
 Your best bet for learning the basic use of these features is by going
through Docs and the included scene files provided with the program. Each
of the scenes were provided to illustrate a feature in pov. Look in the
objects directory for a file called ttf.pov for an example of how to use
the text feature in pov. There are literaly dozens of examples for how
to use the various textures.
The basic syntax for using textures is:
#include "clouds.inc"
sphere{<0,0,0>,1 texture { S_Cloud1 } }
Ken Tyler
Date: 3 Jul 1999 15:10:44
Message: <377E6D1B.E48EDA00@earthlink.net>
Yea I know, about #include but how do you know that it's S_Cloud1?
> Ken,
>                         Travis Barton
> > software.  Thanks.
Date: 3 Jul 1999 15:50:51
Message: <377E694F.9E2CFE76@pacbell.net>
  My mistake. It's been a long time since I have even looked at the include
file since I usualy make all of my own.
  Then include files that have multilayed textures are formated in such a
way that each texture component is predeclared as individual pigments.
It is later then combined in a declared texture statement. The S_Cloud1
you reference is one of those predeclared pigment statments. By itself
it probably will not look good as a cloudy sky and requires the other
components to look right. If you really want to try it as a stand alone
texture you would use it like this:
Note: the include I mentioned earlier should have been skies.inc
      and not clouds.inc
#include "skies.inc"
  sphere { < 0, 0, 0 >,1
    pigment { S_Cloud1 }
   }         // end texture
  scale 200  // scale the sky to the size needed for your scene
}            // end sphere
 Usualy most people use the premade textures in that file like this:
  sphere { < 0, 0, 0 >, 1
   texture { T_Cloud1 }
 }              // end sphere
  All of the includes use a similar scheme to note which is a texture by
using a "T" in the declaration. For example T_Stone_1A, T_Gold_5E etc.
Ken Tyler
Date: 4 Jul 1999 19:53:05
Message: <378000C5.AAD0735E@earthlink.net>
Ken,
    How do I add text to my graphics?  Also, what all can I do with that
text?  Thanks again.
                    Travis
> > Ken,
> >                         Travis Barton
> > > software.  Thanks.
Date: 4 Jul 1999 22:00:33
Message: <37801170.944F3FE0@pacbell.net>
> Ken,
> text?  Thanks again.
>                     Travis
              Ken's quick tutorial for using the Pov text object
  First let's start with the basic syntax of the text object. One of the
things that confuses most people is that htey try to use one of the fonts
that is in their windows font directory. If you try this make sure that
you provide the fullo path to the directory that your windows fonts are
in or Pov will not be able to find them.
e.g.  text { ttf "c:\windows\fonts\myfont.ttf" 1,0 }
 Render the following to see how the basic text object looks.
  camera       { location < 0, 0, -5> look_at 0}
  light_source { <-10,10,-30> rgb 1}
  text         { ttf "timrom.ttf" "POV" .5,0 translate x*-.9 pigment { rgb 2}}
  background   { rgb .35}
  The next example shows how to add raised text to another objects surface.
  union        {
    box        { -1,1  scale<1.25,1,.25>translate <0,.5,.5> pigment { red 1}}
   text        { ttf "timrom.ttf" "POV" .5,0 translate x*-1 pigment { rgb 2}}
  This last example shows how to subtract text from another object using a
CSG operation.
  difference   {
  The above three examples show how to use the internal Pov text object but
there is another method for adding any kind of picture or text to an object
using the image map operation. This will require you to supply your own image
for the code below to work. Your best bet is to go into a paint program that
has a text feature, spell whatever you want over a background color of your
choice, and then save it as a .gif file called text.gif.
       box { -0.5, 0.5
 image_map { gif "text.gif" interpolate 2 }
             translate -0.5
             scale<2.5, 2, 2.5>
  With the text object this next suggestion is a bit redundant but there
are time is has it's attraction. There is a program called Elefont that
offers a few different text manipulation abilities you will not be able
to do in pov. On of these is the ability to bevel text among other things.
It has direct support for Pov file format. You can download a copy at:
http://www.armanisoft.ch/
  Be sure to check out the other utility called spiralizer while you are
there. It is a pretty trick little tool.
  The last and least desirable method is to take your completed image into
a paint program and add it in as a post processing step. Purest Pov artist
stick their nose up at people that do this but to each their own.
Ken Tyler
Date: 4 Jul 1999 22:28:40
Message: <378018C0.86F62025@xs4all.nl>
If you feel particularly bold (and have a Win95-system) you could have a peek at
my SoftText-program. I actually gave it a webpage! It's at
http://www.xs4all.nl/~remcodek/softtext.html
Remco
Date: 4 Jul 1999 23:32:10
Message: <3780341D.43856DF3@earthlink.net>
Ken,
        Ok, last question cause I know I am bothering you.  Ok, how do I add
like a glassly or ice looking texture to the font?
                Thanks,
                    Travis
> Ken,
> text?  Thanks again.
>                     Travis
> > > Ken,
> > >                         Travis Barton
> > > > software.  Thanks.
