POV-Ray : Newsgroups : povray.windows : POV-Ray for windoze 3.1e bug(s) Server Time
17 Mar 2026 13:34:20 EDT (-0400)
  POV-Ray for windoze 3.1e bug(s) (Message 1 to 8 of 8)
Subject: POV-Ray for windoze 3.1e bug(s)
Date: 27 Jun 1999 02:14:29
Message: <3775ca8c.32616520@204.213.191.228>
I am posting to this group because these are not POV-Ray core bugs but
rather ones of the windoze front-end
1) I am pretty sure this one's a bug. When using the rubberband select
to render a region, POV fails to free the system resource it takes. I
am not talking about program or data memory but about those 2x64 Kb
(thanks, Spider! :) ) that windoze allocates for icons, menus etc.
After about 15-25 renders the system goes really low of resources
(0-5% free). Closing and restarting POV solves the problem.
To replicate this bug try this. Open POV and a scene. Start a render
and stop it (so that the render window shows up). Now right click on
My Computer, select Properties and click on the Performance tab. See
the amount of free resources you have. Close this window now, you'll
open it later, because windoze doesn't update it automatically. Go
back to POV and use the rubberband to select a render region (I
haven't notices if its size matters, but the larger, the better,
methinks) Check the amount of system resources again. On my system
this procedure usually eats away 3-6 % of the resources.
2) I think this one has been mentioned before: when using adaptive
anti-aliasing, the pps indicator shows zero
System:
CPU: AMD K6/233
MB:  Intel Triton TX
RAM: 96 Mb SDRAM
OS : Windows 95 OSR 2.1, Windows 98
POV: Official POV-Ray for Windows v3.1e.watcom.win32.r1 (PII Opt.)
Peter Popov
ICQ: 15002700
Subject: Re: POV-Ray for windoze 3.1e bug(s)
Date: 27 Jun 1999 02:44:46
Message: <3775C848.8373D771@aol.com>
About 1), yep I'm always soft-crashing the program when I do many region selections in
a
row as I test a small area of a render for correctness and adjustments on a scene
file.
I just live with it and figure it's obvious enough for anyone to know about, esp.
Chris
Cason. Could be a limitation not figured out as of yet.
About 2), why did you tell me!? Now I will stare at that zero every time I render with
Sampling_Method=2 instead of 1, which I use quite often and never even noticed this
fact.
> System:
> CPU: AMD K6/233
> MB:  Intel Triton TX
> RAM: 96 Mb SDRAM
> Peter Popov
> ICQ: 15002700
 mailto://inversez@aol.com?Subject=PoV-News
Date: 27 Jun 1999 03:02:15
Message: <3776cbcd.775826864@news.povray.org>
On Sun, 27 Jun 1999 07:14:56 GMT, pet### [at] usanet (Peter Popov)
One actually is a core bug, believe it or not, but you don't have to
post it to bugreports.  I've forwarded it.
For those playing along at home, pvengine.c creates but does not
delete the pen it uses to draw the outline.  The longer you move
the mouse around, the more resources it uses.
This one's in render.c.  Adaptive antialiasing doesn't call the
POV_PRE_PIXEL or POV_POST_PIXEL functions.
I've forwarded both of these with patches to the appropriate people.
Date: 27 Jun 1999 03:16:52
Message: <3775d003.776905039@news.povray.org>
By the way, Peter, either your clock or your time zone is off by an
hour:
Date: Sun, 27 Jun 1999 07:14:56 GMT
X-Trace: 27 Jun 1999 02:14:29 -0400, 212.124.65.63
The way your clock is set, it looks like I fixed your bug ten minutes
before you posted it.
Date: 27 Jun 1999 10:33:34
Message: <3776348B.6BEC43AE@aol.com>
Damn you're good...
-Mike
> hour:
Date: 27 Jun 1999 10:36:20
Message: <37771bab.6761638@204.213.191.228>
>hour:
Thanks for pointing this out, Ron. My clock is alright and my time
zone is alright (Sofija). It's just that the lamers that made windoze
98 (I upgraded yesterday) don't know where Sofia is and think it's at
GMT +01:00! Yeah, and they don't know how to spell it, too!
Problem is now fixed. I told windoze that I lived in Athens.
Peter Popov
ICQ: 15002700
Date: 27 Jun 1999 10:36:22
Message: <37762213.8402543@204.213.191.228>
On Sun, 27 Jun 1999 07:04:46 GMT, par### [at] fwicom (Ron Parker) wrote:
<snip>
Does this mean that CPU usage histograms won't work either?
Thanks
Peter Popov
ICQ: 15002700
Date: 28 Jun 1999 06:21:19
Message: <37774c9f@news.povray.org>
Peter Popov wrote in message <3775ca8c.32616520@204.213.191.228>...
<snip 1 and 2>
Here's another
When selecting a region to render, if the region goes outside the image,
nothing will be rendered. Eg if my resolution is 512*384 and I try to select
a region
from 300-600*100-200 the picture will be all black
Machine 1:
P 150
64 MB ram
Win 95 OEM2
Machine 2:
P III 450
64 MB ram
Win 95 OEM2
Machine 3:
PII 233
64 MB ram
Win NT
Gail
* gsh### [at] monotixcoza              * ERROR: COFFEE.COM not found  *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
   My Software never has bugs, It just develops random features
