POV-Ray : Newsgroups : povray.windows : Lost the Resolution Drop-Down List Server Time
17 Mar 2026 13:37:21 EDT (-0400)
  Lost the Resolution Drop-Down List (Message 1 to 3 of 3)
Subject: Lost the Resolution Drop-Down List
Date: 23 Jun 1999 14:53:40
Message: <37712CEA.E93A0AF3@hotmail.com>
I'm a relatively new PoyRay user, and *something* I did caused all the
resolutions
(320 x 240, 640 x 480, etc) to vanish from the drop down list on the
GUI... I've looked all over the docs and the net for a fix, but I've not
had any luck.  Right now it seems that I'm stuck in 320 x 240 mode.
Eventually when my rendering is finished, I'll want to increase the
resolution to get a bigger picture, and I don't want to have to do it by
hand or in the INI file.
Any suggestions?  I tried reinstalling it over the old copy, but no
luck.  I guess I could try to uninstall the old copy first.
Thanks in advance.
Kane
Subject: Re: Lost the Resolution Drop-Down List
Date: 23 Jun 1999 19:37:09
Message: <37716FA3.5CDE9EC8@tsn.cc>
You most likely have selected an INI file other than the default.  Click
the ini button and click default under ini name.
Date: 23 Jun 1999 23:43:45
Message: <3771A9E8.F232B71F@tiac.net>
>resolutions
I think the reason your stuck in 320 x 240 is because that is the
default
in the master POVRAY.INI . Look in your 'renderer' folder to make sure
you
still have QUICKRES.INI ;if you do still have it then do what Steve
Jones
said and click the INI button and then click 'default' and that should
fix
it. If that doesn't do it you might have to click 'Browse' and find
QUICKRES.INI .
However, if your missing QUICKRES.INI let me know and I'll e-mail you a
copy.
Phil
