POV-Ray : Newsgroups : povray.windows : Changing the images directory Server Time
12 Jun 2026 14:15:40 EDT (-0400)
  Changing the images directory (Message 1 to 3 of 3)
Subject: Changing the images directory
Date: 9 May 1999 17:25:37
Message: <3735EF3C.76692E45@netvision.net.il>
Does anyone out there know how to change the default output directory? I
tried searching the registry but no luck.
Subject: Re: Changing the images directory
Date: 9 May 1999 18:42:25
Message: <3735FEDA.F62E76CC@unlgrad1.unl.edu>
The images directory is set in the povray.ini file, which is in the renderer
sub directory.
	Until that Day,
	Ben
Date: 9 May 1999 18:55:47
Message: <37360463.0@news.povray.org>
Inside the tool menu up the editor you'll see an "Edit povray.ini"
entry. Once inside look for a line beginning by Output_File_Name = (a path).
Replace that path by whatever you like better.
        JM
