POV-Ray : Newsgroups : povray.windows : Re: INFO: API for POV-Ray Server Time
15 May 2026 22:53:04 EDT (-0400)
  Re: INFO: API for POV-Ray (Message 1 to 9 of 9)
Subject: Re: INFO: API for POV-Ray
Date: 20 Apr 1999 18:04:40
Message: <371cebe8.0@news.povray.org>
A couple of months ago I put forward the idea to separate the rendering
engine from the user interface and got a flat NO (actually it was almost a
flame war!!!) from the POV-Ray team. I think the only way to use POV-Ray is
like what TextureView does, i.e. shelling out POV-Ray, making
it render a file and intecepting the image output. Not a great idea, but
THEY (POV-Ray team) would not even accept the idea of dinamically linked
modules... so I think this is the end.
Alessandro Coppo
a.c### [at] iolit
www.geocities.com/SiliconValley/Way/8111/
Hassoun Karam wrote in message <371B4CDA.522252A5@sympatico.ca>...
>Hi
>i would like to know if there is a free API for pov-ray 3.1 for win95,
>or anything else that would be considered as such.
>thanks in advance
>Hassoun
Date: 21 Apr 1999 07:26:12
Message: <371da67b.4361437@news.povray.org>
We provide the GUIEXT system on Windows, which is a dynamically linked module.
This is the technique that TextureView uses. If that isn't good enough for you,
well, too bad. We've been burnt before by unscrupulous individuals who want to
steal our hard work. We're not suggesting that you're in that category but as
with anything, the actions of a small minority ruin things for the majority.
I find your attitude disheartening (in fact, somewhat rude). We have reasons
for our decision. While we don't expect you to agree (you're welcome to your
own opinion), we do expect you to respect that decision.
Date: 21 Apr 1999 20:07:42
Message: <371E4E5B.5476FA8E@canit.se>
I'am a bit confused is not povray a command line utility? Under unix I dont
even hava a UI.
Hmm whats wrong with it ? What do you want to do get access to the internal
representation and directly insert object whitout going thru the povray
language?? That would be quite limiting to future development I think.
> Alessandro Coppo
> a.c### [at] iolit
> >Hi
> >thanks in advance
> >Hassoun
Date: 21 Apr 1999 21:51:20
Message: <371e7288.0@news.povray.org>
In article <371E4E5B.5476FA8E@canit.se> , Kenneth Johansson <ken### [at] canitse>
> even hava a UI.
The Windows and Macintosh versions provide a Graphical User Interface.
    Thorsten
Date: 21 Apr 1999 23:25:00
Message: <371E8751.F74E5893@bahnhof.se>
Not at all, it is very easy to turn it off(saves memory :-) at least in windows.
> > even hava a UI.
>     Thorsten
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 23 Apr 1999 15:59:42
Message: <3720c31e.0@news.povray.org>
I've been wondering about something.  Please, don't take this as an insult
or a second-guess or anything, as I have the greatest respect for the Team
and for your right to choose your own distribution and licensing terms - I
for one am happy to be able to see source code at all, considering some of
the alternatives.  But perhaps someone could clear this up for me.
POVLEGAL.DOC already says this:
  No portion of the POV-Ray source code may be incorporated into another
  program unless it is clearly a custom version of POV-Ray that includes
  all of the basic functions of POV-Ray.
and this:
  Any attempt to obscure the fact that the user is running POV-Ray or to
  obscure that this is an unofficial version expressly prohibited.[1]
What is the reasoning behind the further prohibition of things that can be
used to break either of the two rules above but could also be used for good?
I mean, if I'm a bad guy and I'm going to steal the POV code for my own
nefarious purposes, I'm not going to be scared off by yet another paragraph
telling me I can't do it.  If I'm a good guy and I plan to follow the terms
of the license, then even if I'm allowed to add new interfaces I won't add
any that are designed to violate the terms quoted above.
I guess I could understand an additional explicit prohibition of interfaces
that could reasonably be expected to be (mis)used to violate other provisions
of the license, even if they're not designed for that purpose, but the current
language does seem overly broad to me.
Of course, portability is an admirable goal as well, and the current terms do
help to enhance that, but I've never seen that mentioned as one of the goals
of the license.  Again, this is not intended to be a criticism, but a sincere
request for additional enlightenment.
[1] I might note that the second quoted item is not a complete sentence and
is therefore technically meaningless.  This should perhaps be remedied in a
future version.
Date: 23 Apr 1999 16:02:35
Message: <3720c3cb.0@news.povray.org>
On Fri, 23 Apr 1999 14:28:57 -0400, Hassoun Karam <has### [at] sympaticoca> wrote:
>where can i get the GUIEXT for win95? is there any tutorial with it?
GUIEXT, or GUI Extensions, are a part of the Windows source code, which you
should be able to get from the same place you got your copy of POV-Ray. The
existing documentation is somewhat scant, but there are a handful of people
in this newsgroup who would no doubt be happy to help you with any of the
tough parts.  I would suggest that you first thoroughly understand the sample
code before attempting to write your own GUI extension.
Date: 24 Apr 1999 06:00:28
Message: <372287a9.24610031@news.povray.org>
While I haven't checked the complete text in povlegal.doc, it's probably there
to stop people from taking an officially-compiled version, and somehow (at run
time or otherwise), defeating the splash-screen, or running the DOS version in
an invisible console, or some such.
-- ChrisC
Date: 24 Apr 1999 12:21:23
Message: <3721e079.176791327@news.povray.org>
On Sat, 24 Apr 1999 08:59:59 GMT, new### [at] povrayorg (Chris Cason)
But that's what the line quoted above does.  What I was asking was
why, if that line is already there, is there yet more verbiage later
attempting to prohibit exactly the same thing by way of prohibiting a
much larger set of things, i.e. additional interfaces.
