POV-Ray : Newsgroups : povray.windows : Q: 3.1e & cmax & patches Server Time
6 Feb 2026 02:44:09 EST (-0500)
  Q: 3.1e & cmax & patches (Message 1 to 10 of 20)
Subject: Q: 3.1e & cmax & patches
Date: 27 Mar 1999 08:20:56
Message: <36fcdb38.0@news.povray.org>
POV-Ray 3.1e runns well and fast, but the patches based on 3.1(a) don't like
the new codemax dll's. There is an error" wrong dll version". I tried put
the patches together with the old dll's in a different directory, but this
is does not work.
Is there a way to get the patches to work with the old dll's and 3.1e work
with the new one's under winNT4? I can do without, but the editor makes life
a little easier.
ingo
Met dank aan de muze met het glazen oog.
Subject: Re: Q: 3.1e & cmax & patches
Date: 27 Mar 1999 09:33:09
Message: <36ffebc7.5772406@news.povray.org>
>is does not work.
The error you get is not related to the codemax dll - it is in fact cmedit.dll
that is giving you the error message.
>a little easier.
cmedit.dll is located using the path given in the registry for POVWIN. there's
nothing that you can do (short of either swapping the files in the bin dir back
and forth, or editing the registry) to change which one it loads.
Date: 27 Mar 1999 11:27:03
Message: <36fd06d7.0@news.povray.org>
povray.org admin team heeft geschreven in bericht
<36ffebc7.5772406@news.povray.org>...
<snip>
life
>>a little easier.
there's
back
Ok, I see. Was afraid this would be the answer,
Thanks,
ingo
Date: 28 Mar 1999 17:27:31
Message: <36feab04.37023937@news.povray.org>
On Sat, 27 Mar 1999 14:37:33 GMT, new### [at] DESPAMpovrayorg
>>is does not work.
>>a little easier.
So... could one set up a batch file which "merged" the right registry
line in before running POV?
I've not tried this with WindowsNT but certainly you can export just a
single line from the registry editor in Win95, and it should be simple
enough to set-up a a couple of batch files - one which re-instates the
old .dll (at some new location, presumably) and then load POV and a
second which changes the registry back to pointing to the new DLL in
it's default location before loading POV.
a couple of shortcuts on the desktop (one for the registry patch and
POV, one for the other registry patch and SuperPatch POV).
I'm about to look at Superpatch (and have been for some weeks) so it'd
be quite nice if POv3.1e and SuperPatch could co-exist :)
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at
http://www.geocities.com/Area51/Dimension/7855/
PS change ".duffnet" to ".net" if replying via e-mail
Date: 28 Mar 1999 20:17:09
Message: <36FED489.57BE4E57@aol.com>
I just posted this question about the patches not working in conjunction
with the new 3.1e. I was hopeful there was an answer here that didn't
mean changing the registry or cmedit.dll back and forth.
Oh well, at least I found the registry entry in need of modification so
I could save new pov scripts into the scenes folder instead of
C:\WINDOWS.
At least I'm hoping so, I will need to restart Windows first to be sure
of that.
I tried the exchange of the two different cmedit.dlls using a batch
file, goes okay. Better that than registry changes.
> >>is does not work.
> >>a little easier.
> Cheers,
> Cliff Bowman
Date: 29 Mar 1999 02:14:35
Message: <36FF2858.13F820B2@aol.com>
The following works in Win95 anyway, so should be pretty much the same
for 98 or NT I would think. Only a suggested possibility here.
Make a sub-folder for the patch or patches in the bin folder, I used
Photon and Super for names.
Put all the patch files into their respective folders, NOTE: uvpov.exe
will need the cmax101.dll dated 9/9/98 [170K] in its folder as well (I
don't know about povray.exe SuperPatch or others), then copy and rename
the original 3.1e cmedit.dll to cmedit.dlo and the older cmedit.dll to
cmedit.dlp (make another copy cmedit.dls for SuperPatch though it is the
same just to be orderly). Here's the batch files written out using
Notepad that I'm using to switch between these:
Put this one into bin folder, saved as 31e.bat (or whatever).
@echo off
:. Version 3.1e batch
cd c:\progra~1\pov-ra~1.1\bin
copy /y cmedit.dll cmedit.dlx
del cmedit.dll
copy cmedit.dlo cmedit.dll
pvengine.exe
exit
Put this next one into bin\Super sub-folder, name it Super.bat(?)
@echo off
:. Super Patch batch
del cmedit.dll
copy cmedit.dls cmedit.dll
povray.exe
exit
And put this one into the bin\Photon sub-folder, naming it photon.bat(?)
@echo off
:. Photon Map batch
del cmedit.dll
copy cmedit.dlp cmedit.dll
uvpov.exe
exit
Make shortcuts to the Desktop for these and right-click on their icons,
go into Properties/Program tab and check the "Close on Exit" box.
This will keep separate copies of the dll and allow the switching to be
possible but you will have to use these new shortcuts only since the dll
may not be the right one next time you try a different POV-Ray. Also,
you can not have two different ones open at the same time or a sharing
violation occurs. I would have made the cmedit.dll return to the
original each time but I couldn't get it to work, the batch seems to
complete and then the POV-Ray program errors due to a wrong DLL when run
all at once.
Hope this helps the few who want to do such a thing as this. If you know
how to do this better than me, great, however I've got a working system
going for now so I won't need to change.
Directory/file structure for the inept ;-)
C:\Progra~1\POV-Ra~1\bin
			pvengine.exe
			cmax101.dll...180K...3/7/99
			cmedit.dlo ...683K...3/20/99
			cmedit.dlp ...680K...2/15/99
			cmedit.dls ...680K...2/15/99
				\Photon
				uvpov.exe
				cmax101.dll ...170K...9/9/98
				\Super
			others	*.dll       ...?K  ...10/28/98(?)
> is does not work.
> a little easier.
> ingo
Date: 29 Mar 1999 09:07:16
Message: <36ff8914.0@news.povray.org>
There probably is, but it will require changes to the code.  If Chris
doesn't end up creating a version that looks in the current directory
for the codemax DLLs, I'm sure I could add a command-line parameter or
something to the Superpatch to change the default behaviour.
It doesn't seem like this would be a long-term problem, at least not
with the superpatch and UVPOV, because I would wager that as soon as
the new source is made available, new binaries of those two patches
will also be made available.
Date: 29 Mar 1999 10:07:10
Message: <370096fe.20491734@news.povray.org>
Please try downloading
  http://www.povray.org/temp/pve31up.exe
and install that. It's a new way of installing the update that I want tested
(other users please try it as well). It sets the 3.1e variable in the registry
(textureview wants this).
In addition, however, the exe included (3.1e.watcom.win32.r1) will load
cmedit.dll from the current directory if it is found there ; otherwise it loads
it from the path shown in the directory.
Date: 29 Mar 1999 10:07:47
Message: <36ff9743.0@news.povray.org>
Thanks Bob,
In the meanwhile I found an other way to get both versions running. I've Put
all the patches in a separate directory (D:\POV-Ray-Patch) with a complete
copy of the subdirectory's bin, help,ini,insertmenu,renderer. Then I use a
batchfile to start a patch, before that the batchfile changes the registry
setting. For this I use an utility REG.EXE from
http://www.mindspring.com/~dgthomas
Here is the (ugly) batchfile:
reg -set
HKLM\Software\POV-Ray\CurrentVersion\Windows\Home="D:\POV-Ray-Patch"
reg -set HKLM\Software\POV-Ray\v3.1\Windows\Home="D:\POV-Ray-Patch"
D:\POV-Ray-Patch\bin\uvpov.exe
reg -set HKLM\Software\POV-Ray\CurrentVersion\Windows\Home="D:\POV-Ray"
reg -set HKLM\Software\POV-Ray\v3.1\Windows\Home="D:\POV-Ray"
after closing uvpov the registry is changed back.
ingo
Bob Hughes heeft geschreven in bericht <36FF2858.13F820B2@aol.com>...
>Photon and Super for names....
> snip
Date: 29 Mar 1999 13:26:01
Message: <36ffc5b9.0@news.povray.org>
tested
registry
loads
Works great, thanks,
ingo
