POV-Ray : Newsgroups : povray.windows : WinPOVray 3.1d and MSDOS-POVray 3.1d Server Time
22 Jul 2026 04:45:48 EDT (-0400)
  WinPOVray 3.1d and MSDOS-POVray 3.1d (Message 1 to 2 of 2)
Subject: WinPOVray 3.1d and MSDOS-POVray 3.1d
Date: 5 Mar 1999 21:50:51
Message: <36e0980b.0@news.povray.org>
Hi all are there any differences in functionality and rendered output
between the msdos and windows version of POVray 3.1d (apart from any OS
restrections - file names etc)
Subject: Re: WinPOVray 3.1d and MSDOS-POVray 3.1d
Date: 5 Mar 1999 22:19:08
Message: <36E0A811.E13DDABC@pacbell.net>
> Rick
   It should be identical. You will need to be carefull that when you
 set up the scene render conditions that you have all of the quality
 and default settings the same as used in the windows version. You will
 see a difference if things are not set the same. I noticed some render
 differences when I switched from Pov v2.2 dos to Pov v3.01 win and it
 took me a while to change the settings the way I wanted them.
   After that they were identical in output and I could find no differences.
 I compared two images produced with the different version using a binary
 file comparison utility and they were physicaly identical.
Ken Tyler
mailto://tylereng@pacbell.net
