POV-Ray : Newsgroups : povray.windows : odd problem Server Time
6 Feb 2026 04:37:47 EST (-0500)
  odd problem (Message 1 to 2 of 2)
Subject: odd problem
Date: 27 Feb 1999 19:00:35
Message: <36D8B1CF.95436604@ij.net>
I have a rather complex scene (
http://members.aol.com/jull43/giants5a.jpg ) that takes either 3
or 9 hours to render. Using Win95 with 128M RAM and POV 3.1.
(333MHz, a quite fast HD but those should have nothing to do with
it.)
	The difference is that if I do a lot of other things while
waiting for renders including internet surfing. Now that sounds
reasonable but if I stop everything from working and disconnect
OR shut everthing down leaving only POV it takes the long time.
	If I reboot first, and then run POV only it takes the shorter
time.
	I have monitored RAM usage (for swap file slow downs) but it
never falls below 50Meg no matter what the conditions. I can see
fragmented RAM causing a little slow down but not 300%. Has
anyone else see this?
Subject: Re: odd problem
Date: 4 Mar 1999 00:11:14
Message: <36DDCFB2.254E2280@kreber.com>
> it.)
> time.
I've never seen a problem like this with POV, but my friends CD burner
has a similar problem. The computer overheats, and then takes longer to
burn a CD than when it's cold.
You might try opening your case and seeing if that affects the rendering time.
-Ed
Edward Wedig
aka Doc Brown
Graphic Artist, 3D Designer, Gamemaster, Nice Guy
http://www.netwalk.com/~docbrown
