POV-Ray : Newsgroups : povray.windows : Re: INFO: what is a histogram? Server Time
1 Apr 2026 16:41:16 EDT (-0400)
  Re: INFO: what is a histogram? (Message 1 to 4 of 4)
Subject: Re: INFO: what is a histogram?
Date: 1 Jan 1999 06:31:04
Message: <368CB1E9.C8EDFF87@aol.com>
As Thorsten pointed out, the documentation says it all.
Summed up:
it allows for a visual representation of computation "intensity" of the
scene being rendered; and since it is a red/green (no blue) image it's
suggested use is for height fields, though getting a scene together for
one in this way is not exactly easy to shape if you want to form a
height field.
Other than that, I haven't seen any other uses myself.
Hassoun wrote:
> Hi
> i am new to povray and i would like to know about the Histogram feature:
> definition, what does it do, applications,...
> thanks in advance
> Hassoun
=Bob
Date: 10 Jan 1999 22:41:41
Message: <36997211.221FDF54@bahnhof.se>
> Summed up:
> height field.
Well, it is nice to know what parts of a complex scene it is that takes most
resources...
I've done it many times, to try and find out where to add some variables to speed up
test
rendering... (#if(fast=true) #else #end)
//Spider
Date: 13 Jan 1999 06:24:09
Message: <369c8221.13294265@news.povray.org>
Spider <spi### [at] bahnhofse> wrote:
>> Summed up:
>> height field.
If the information is output to a .CSV file, you can then input that file into
a program that handles distributed rendering. It can use the information giving
which parts of the output image are more processor-intensive to work out a more
optimal sub-division in terms of which CPU's render which bits.
Date: 15 Jan 1999 13:54:35
Message: <369F8EE7.BFBDF569@aol.com>
Good use for the "histogram"!
> >> Summed up:
> >> height field.
=Bob
