POV-Ray : Newsgroups : povray.windows : Nested While Loops Bug? Problem with arrays? Server Time
12 Jun 2026 17:18:07 EDT (-0400)
  Nested While Loops Bug? Problem with arrays? (Message 1 to 10 of 13)
Subject: Nested While Loops Bug? Problem with arrays?
Date: 18 Oct 1998 07:22:23
Message: <3629c15f.0@news.povray.org>
Downloaded and began playing with 3.1 recently.  The new arrays look like a
great addition (not to mention the new editor).  However I'm having problems
initializing a two-dimensional array (128 x 128) with vectors using a nested
while loop (one for x, the other for y).  Has anyone else dealt with this?
Thanks,
Jeff
Subject: Re: Nested While Loops Bug? Problem with arrays?
Date: 18 Oct 1998 17:48:19
Message: <362A53E9.7FF43F2@flash.net>
Please post your code here -- there are several errors
you could be making (for example, using indices from 1
to 128 instead of 0 to 127), but it is impossible to tell
without seeing the code.
Dan
> Thanks,
> Jeff
http://www.flash.net/~djconnel/
Date: 18 Oct 1998 19:44:09
Message: <362A7DC0.B12C5733@xs4all.nl>
> Thanks,
> Jeff
I'm absolutely no POV-expert but could it have something to do with the size of
the array? Perhaps POV uses a stack or something like that. I don't know: is
there a maximum size (oops, didn't read the docs obviously....)
Remco
Date: 20 Oct 1998 21:17:20
Message: <362d2810.0@news.povray.org>
Jeffrey,
I'm not sure this is the same problem but I noticed I can't seem to write to
a single
element in my UV lattice (2 dim array) of vectors, although I can read:
    #local nx = clat[U][V].x;
My workaround was:
     #local clat[U][V] = <cc+1,0,0>;
If you are initializing in a nested loop, you might try:
   #local clat[U][V] = <xvalue,yvalue,zvalue>;
If this has something to do with my using version 3.1 rather than 3.1a, I'd
sure like to
know about it !
Hope this helps,
Sally
Jeffrey H. Zimmer wrote in message <3629c15f.0@news.povray.org>...
problems
nested
>Thanks,
>Jeff
Date: 20 Oct 1998 22:43:25
Message: <362D3C0D.CD65EB8F@flash.net>
There is a bug in the vector code for dimensions other
than 2.  This is a known, and long time, problem.  I've
played around with the source code a bit in an attempt
to find the error -- it's clear it is getting confused
about the dimensionality of the vector (in the case
of 2-d), but I didn't find the precise error.
A manifestation of this is the following won't work :
#declare UV = <1, 2>;
#declare V  = uv.v;
For dimension larger than 3, there are other problems.
Dan
P.S. I believe I've seen the correction posted somewhere,
but I am not sure where.
Sally Rothenberg wrote:
> Jeffrey,
> a single
> My workaround was:
> sure like to
> know about it !
> Hope this helps,
> Sally
> problems
> nested
> >Thanks,
> >Jeff
Date: 21 Oct 1998 03:50:06
Message: <362D83F2.2DF45862@flash.net>
> than 2.
This should be 3.
Date: 22 Oct 1998 15:46:15
Message: <362F7D1F.A62AC804@ltu.edu>
The two-dimension vector bug is well known (but for some reason not yet
fixed).  I am not familear with problems with dimensions greater than
three, though.  Could you provide details?
-Nathan Kopp
> #declare V  = uv.v;
> Dan
> > Jeffrey,
> > a single
> > My workaround was:
> > sure like to
> > know about it !
> > Hope this helps,
> > Sally
> > problems
> > nested
> > >Thanks,
> > >Jeff
Date: 22 Oct 1998 22:36:49
Message: <362FDD7B.88238E32@flash.net>
news://news.povray.org/360cbb8f.0%40news.povray.org
#declare a = <1, 2, 3, 4>;
yields an error.
Dan
Date: 23 Oct 1998 01:46:59
Message: <363009EA.81077218@ltu.edu>
> yields an error.
That's true, but
#declare a = color<1, 2, 3, 4>;
works just fine.  This also works for 5-d vectors.  Maybe it should be
changed, but it was done intentionally, so it's not really a 'bug'.
-Nathan Kopp
Date: 23 Oct 1998 02:47:38
Message: <36301847.A9FB022A@flash.net>
It is a bug, intentional or otherwise, if it is inconsistent with the
documentation, and I don't know where the documentation indicates
that 4-d vectors must be associated with the color keyword.
What is the purpose of such a restriction?
Dan
Nathan Kopp wrote:
> > yields an error.
> That's true, but
> -Nathan Kopp
