POV-Ray : Newsgroups : povray.windows : Context help problem in beta6 Server Time
17 Mar 2026 18:27:31 EDT (-0400)
  Context help problem in beta6 (Message 1 to 9 of 9)
Subject: Context help problem in beta6
Date: 31 Aug 1998 04:37:26
Message: <35ea52b6.0@news.povray.org>
Has anybody encountered the following problem: when I hit Ctrl-F1 I get the
following mesage:
Cannot find the C:\PROGRAM FILES\POV-RAY FOR WINDOWS 3.1\\Help\poray31.hlp
file.
Do you want to locate it yourself?
<Yes> <No>
I click <Yes> and I get:
file. Check to see that the file exists of your disk. If it doesnt, you need
to reinstall it.
Did you notice the \\ in the path? Not a typo, that's what the message says.
POV-Ray beta5 crashed during uninstall and even though it disappeared from
the disk and the add/remove list, when installing beta6 it said it detected
an early version... Any ideas?
Subject: Re: Context help problem in beta6
Date: 31 Aug 1998 04:57:14
Message: <35ea575a.0@news.povray.org>
Peter Popov wrote in message <35ea52b6.0@news.povray.org>...
>following mesage:
>file.
><Yes> <No>
Yes I have the same problem
need
>to reinstall it.
says.
I didn't notice the \\. I had some difficulties installing beta6 also, so
maybe
this is it...
Can't help you more, sorry :-|
Sincerely,
Philippe
Date: 31 Aug 1998 05:15:06
Message: <35ea5b8a.0@news.povray.org>
I had the same problem, but I was able to locate the file and I haven't had
a problem since.  It started with Beta 5 but it was gone in Beta 6.  Who
knows...
Duane
Check out my web page.  I just started, so don't laugh too hard.
www.geocities.com/siliconvalley/lab.8407
e-mail me: ddt### [at] junocom
Philippe Debar wrote in message <35ea575a.0@news.povray.org>...
the
>>following mesage:
>>file.
>><Yes> <No>
>need
>>to reinstall it.
>says.
detected
>maybe
>this is it...
>Sincerely,
>Philippe
Date: 31 Aug 1998 06:15:10
Message: <35ea699e.0@news.povray.org>
Peter Popov schrieb in Nachricht <35ea52b6.0@news.povray.org>...
>following mesage:
>file.
><Yes> <No>
need
>to reinstall it.
Yep, exactly the same on my system. Beta 6 installed flawlessly, so I don't
think it's anything to to with that...
CU
Ade
Date: 31 Aug 1998 13:47:10
Message: <35ead38e.0@news.povray.org>
Following myself here. I went through the registry and the inis but this
path was not mentioned anywhere. I guess it's a typo in the source, if so
it's an easy-to-fix bug.
Another thing that bothers me is opening files via explorer. I wasn't able
to do it with 3.0, 3.01, 3.02, 3.1b4, 3.1b5 and 3.1b6. I get an error
similar to "can't find thin .ini file" of "there's an error in this .ini
file". POV seems to be treating the filename as an ini, i.e. the first
parameter after pvengine.exe (like it is in the DOS version) is the .ini
name. I install it correctly and answer <yes> to "open in editor?" Maybe if
I create a file type myself...
Peter
Date: 31 Aug 1998 14:29:20
Message: <35eadd70.0@news.povray.org>
hi
I had same...
But not entry in the registry ...
I don't undestand that you locate the file and stated with Beta 5...
Martial
>knows...
>Duane
Date: 31 Aug 1998 17:28:16
Message: <35eb0760.0@news.povray.org>
>file.
><Yes> <No>
need
>to reinstall it.
Arrrrgh... that's povray there, not poray (we all love typos don't we?).
Sorry.
Peter
Date: 1 Sep 1998 01:13:54
Message: <35eb7482.0@news.povray.org>
Martial,
    What I mean is the first beta of 3.1 I had was beta 5 and when I started
beta 5 and selected help (to see what was new) it told me it couldn't find
the help file as well.  It gave me the option to browse for it (which I did)
and when I found the file I told Pov-Ray to use that instead of whatever it
was looking for and it worked fine and has worked ever since.  Sorry to be
so vague...
Duane
www.geocities.com/siliconvalley/lab/8407
Martial wrote in message <35eadd70.0@news.povray.org>...
>hi
>I had same...
>Martial
had
>>knows...
>>Duane
Date: 2 Sep 1998 19:22:47
Message: <35edc475.783324@news.povray.org>
On Tue, 1 Sep 1998 00:14:11 -0400, "Duane Tackett"
<ddt### [at] junocom> wrote:
>Martial,
>so vague...
>Duane
Hi
Ok! I had reinstall 3.00 and 3.16,  3.14 and  3.16, 3.15 and 3.16
nothing
at last  I install 3.16 and 3.02 in another file for the context_help
I'st no satisfaction but for a beginner it good ...
