POV-Ray : Newsgroups : povray.windows : Wall of China again Server Time
6 Feb 2026 08:16:33 EST (-0500)
  Wall of China again (Message 1 to 2 of 2)
Subject: Wall of China again
Date: 27 Jul 1998 14:47:56
Message: <35bcbd4c.0@news.povray.org>
Thanks for the many helpful ideas on this problem but maybe I need to
expound a little further on my needs.
1. For my application the top of the 'wall' always remains at the same
level. Hey! that should make it simpler.
2. As the height_field rises, less of the wall is seen. At an extreme the
wall disappears into the height_field. The wall base can be at the base of
the height_field.
3. I need to texture the wall. I say this since some solutions with a simple
color do not appear to work the same way when a texture is involved.
4. I have several/many wall sections scattered throughout the image. My
preference would be to put generalized code into the .ini file for all of
the wall sections and then put the center-line co-ordinate list(s) into the
.pov file which is, in turn, created by a source generating program.
David
Subject: Re: Wall of China again
Date: 5 Sep 1998 04:35:20
Message: <35F0E968.453@t-online.de>
> the height_field.
> David
Hello,
the answer to this posting may be appreciable delayed and I did mail the
following file to David himself already. But since I imagine, that could
be of more general interest, I'll post it here too.
The code provides the possibility for generating any polygonal shaped
"wall" structures only by defining the center-line coordinate list. This
may also be done using a separate .inc file generated elsewhere.
Each of the segments is textured in the same manner automatically and
not dependant on its position or direction on the plane.
ReVerSi
Download 'us-ascii' (6 KB)
