POV-Ray : Newsgroups : povray.windows : Texture mapping problem Server Time
16 May 2026 02:20:25 EDT (-0400)
  Texture mapping problem (Message 1 to 3 of 3)
Subject: Texture mapping problem
Date: 15 Jul 1998 07:15:55
Message: <35ac7cc7.391636@news.povray.org>
Perhaps it's only a newcomer mistake, but why texture maps (I mean
bitmap ones, not procedural) don't stay the same when I choose to
render at a higher resolution? I placed a black & yellow stripe (like
those "under construction") on a sliding panel, scaled the texture
until looked fine, rendered at 320x200. Not bad. Then rendered again
at 640x400 and the texture was a mess! Does render size affect texture
scaling? The model are the same size, just the render window is
bigger. What's wrong? Anyone knows?
Thanks
Massimo
aka MadMax
Subject: Re: Texture mapping problem
Date: 15 Jul 1998 08:29:32
Message: <35AC8472.9AB816E5@pacbell.net>
Can you explain what kind of "mess" is happening.
Is your black&yellow line becoming crooked, or
the color is wrong or ... ?
Are you using anti-aliasing when you render the
bigger image. Turning it on can clean up a lot of
problems with strait lines that are at an angle to
the camera.
Try 640x480 AA 0.3 or even 640x480 AA 0.1
and see if that helps.
K.Tyler
> Thanks
> Massimo
> aka MadMax
Date: 26 Jul 1998 05:18:15
Message: <35BAE64C.EC7B2A22@flash.net>
Make sure you use "interpolate 2" in the
image_map statement -- it smooths out the
transition between raster file pixels.
> bigger image.
> K.Tyler
http://www.flash.net/~djconnel/
