POV-Ray : Newsgroups : povray.windows : POV will not Render Server Time
13 Jul 2025 06:37:04 EDT (-0400)
  POV will not Render (Message 1 to 9 of 9)
Subject: POV will not Render
Date: 22 Aug 1998 16:30:45
Message: <35DF1C23.4F457BFE@cln.etc.bc.ca>
Recently POV-Ray crashed will I was trying to render a
scene.  So,
I restarted the computer and loaded POV-Ray again, and when
I tryed
to run the demo (to see if it was becuase of the scene), but
it still crashed.
    The Messages screen gets to:
        Redirecting Options
            Warning Stream to console.......On
    then a dialog comes up with the title Pvengine, and
reads:
        This program has performed an illegal operation
        and will be shut down.
        If the problem persists, contact the program
        vendor.
    fallowed by a textbox with:
        PVENGINE caused a stack fault in module <unknown> at
0000:00000003.
        Registers:
        EAX=00000000 CS=0137 EIP=00000003 EFLGS=00010202
        EBX=00000001 SS=013f ESP=00a9ff08 EBP=00000000
        ECX=0d000000 DS=013f ESI=00000000 FS=2757
        EDX=00000000 ES=013f EDI=00000000 GS=0000
        Bytes at CS:EIP:
        00 65 04 70 00 16 00 dd 13 65 04 70 00 65 04 70
        Stack dump:
        00401012 0044c5f5 0046013f 00a9ffc8 004d1690
        00a9ff36 fffffff4 00000000 006e1104 00000009
        00000000 00000001 00a9ffc8 00000003 00000001
        00000000
    Next, I reinstalled POV-Ray with the newest version
(which was only 3.02, and I had 3.01 [or something like
that]).  This also failed.
    I really enjoyed the program, so this is very
disappointing,
I hope you can help.
                David Young
Subject: Re: POV will not Render
Date: 22 Aug 1998 17:03:16
Message: <35DF23BA.456D2FB3@cln.etc.bc.ca>
K.Tyler,
        Under "Render" in the menu bar you will find a
"Run Demo", that is what I was talking about.
POV-Ray crashes on any file I render.  The reason I
used the demo was because it should work, (it was
made to be rendered with the program).
David Young
Subject: Check the settings for max trace levels it must be between 5 and 15 for no crashes (on my 'puter anyway!!)
Date: 23 Aug 1998 02:04:10
Message: <35DFA2B3.74085166@mailexcite.com>
> scene.  So,
> I tryed
> it still crashed.
>         Redirecting Options
> reads:
>         vendor.
> 0000:00000003.
>         Registers:
>         Bytes at CS:EIP:
>         Stack dump:
>         00000000
> disappointing,
>                 David Young
The only good politician is a dead politician !!
Politics or religion = corruption and true evil.
Believe 1% of what you see or hear.
The laws that politicians make are mostly bad laws,
  we'd do far better without them - the politicians AND their laws.
Date: 23 Aug 1998 20:52:21
Message: <35E0AAF2.8D2DE279@cln.etc.bc.ca>
> scene.  So,
> when
> I tryed
> but
> it still crashed.
>         Redirecting Options
> reads:
>         vendor.
> at
> 0000:00000003.
>         Registers:
>         Bytes at CS:EIP:
>         Stack dump:
>         00000000
> disappointing,
>                 David Young
Date: 23 Aug 1998 20:58:06
Message: <35E0AC4B.5BAE7174@cln.etc.bc.ca>
I am sure that it is not the fault of scene, because it
crashes rendering any scene.  If there is a problem,
syntax error or if I try to render a blank page, it still
crashes - but with an 'invalid page fault'.  Can anyone
help me, or tell me where I can find help.  I would really
like to get back to Ray-tracing.
                        David Young
Date: 23 Aug 1998 23:09:02
Message: <35E0CB37.33192EB3@flash.net>
>                         David Young
You really need to run it under a debugger to see where
in the code the error occurs, I think.
Dan
http://www.flash.net/~djconnel/
Date: 24 Aug 1998 22:47:27
Message: <35E2176C.61E31C32@cln.etc.bc.ca>
I am just about ready to try anything (even
install the DOS version), so if you could tell me
where to find a debugger to use, I would be
very appriciative.
                David Young
Date: 25 Aug 1998 23:15:15
Message: <35e36f92.258304722@news.povray.org>
Try doing a full uninstall, then install beta 6 from
  ftp://ftp.povray.org/pub/povray/beta/beta3.1-6/povwin31.exe
Date: 26 Aug 1998 23:08:11
Message: <35E4BF4A.7F5E8BB9@cln.etc.bc.ca>
Thank you so much!  It worked! Plus,
I really like the new interface (although
it kinda looks like MicroSoft IE).
            David Young
