POV-Ray : Newsgroups : povray.windows : difference error ? pls hlp :) Server Time
16 May 2026 03:33:58 EDT (-0400)
  difference error ? pls hlp :) (Message 1 to 3 of 3)
Subject: difference error ? pls hlp :)
Date: 9 Feb 1998 22:15:30
Message: <34dfc2eb.2086002@news.povray.org>
I am a new POV-RAY user and i have alittle problem with difference. :(
(im using ver 3.02 for win95)
If i use difference to cut something and do not give the second object
a pigment, the cut-surface becomes black ? :(  in the toturial it
stated that it woud take the color of the first object ??
Even If i use the difference example in the Pov tutorial ... the one
with the blue cylinder  and just remove the pigment i get a black
pigment, cut surface.
I kow it's easy to just make the second object the same color as the
first but if i use a wood texture and want it to look is if its cut
out then it wont work cause the textures wont mach up.
pls help me find a way around the problem or tell me where i have made
an error.
Thanx:)
	G-funk
			g-f### [at] usanet
Subject: Re: difference error ? pls hlp :)
Date: 9 Feb 1998 22:56:43
Message: <34dfdf84.0@news.povray.org>
Just apply the texture *after* the difference operation has been performed.
Paul Hinds
gri### [at] swbellnet
Date: 5 Mar 1998 15:51:57
Message: <34ff109c.0@news.povray.org>
As long as you don't translate the difference result before you apply the
texture, it will match up perfectly. (Pov-Ray's textures are procedurals)
GrimDude wrote in message <34dfdf84.0@news.povray.org>...
>Paul Hinds
