POV-Ray : Newsgroups : povray.windows : Surface Coefficients??? Server Time
15 Jun 2026 08:29:32 EDT (-0400)
  Surface Coefficients??? (Message 1 to 6 of 6)
Subject: Surface Coefficients???
Date: 25 Jan 1998 03:23:46
Message: <34caf672.308033992@news.povray.org>
POV-Ray v3.02 can render up to 7th-degree polynomial surfaces.
The documentation does not say what the coefficents are in the order
that they need to be in a poly{} statement.  They have great examples
for quartics of degree 4, but for 5th, 6th, and 7th there is nothing
in any of the help files or the documentation!
What are the surface coefficents in order???
Thank you for your help!
SteveH
Subject: Re: Surface Coefficients???
Date: 11 Feb 1970 10:12:17
Message: <01bd36f6$c022c200$181657a8@W_tristan.gb.tandem.com>
Look at how the 4th order goes
extend to 5th
The numbers give which power of each of x, y and z are in each term.
To extend further, count down in base n (eg 6th order use base 6) from n00
to get each term.
4th and 5th		inserted for 5th only
			(delete three tabs before each)
x^	y	z^	x^	y^	z^
			5	0	0
			4	1	0
			4	0	0
4	0	0
			3	2	0
			3	1	1
3	1	0
			3	0	2
3	0	1
3	0	0
			2	3	0
			2	2	1
2	2	0
			2	1	2
2	1	1
2	1	0
			2	0	3
2	0	2
2	0	1
2	0	0
			1	4	0
			1	3	1
1	3	0
			1	2	2
1	2	1
1	2	0
			1	1	3
1	1	2
1	1	1
1	1	0
			1	0	4
1	0	3
1	0	2
1	0	1
1	0	0
			0	5	0
			0	4	1
0	4	0
			0	3	2
0	3	1
0	3	0
			0	2	3
0	2	2
0	2	1
0	2	0
			0	1	4
0	1	3
0	1	2
0	1	1
0	1	0
			0	0	5
0	0	4
0	0	3
0	0	2
0	0	1
0	0	0
Tristan Wibberley
(Remove the '.NO_LUNCHEON_MEAT' from my
email address to reply.)
Stephen Horn <hor### [at] osuedu> wrote in article
<34caf672.308033992@news.povray.org>...
| SteveH
Date: 11 Feb 1998 10:51:34
Message: <34e2bb13.6909575@10.0.2.33>
On 11 Feb 98 15:12:17 GMT, "Tristan Wibberley"
>extend to 5th
>to get each term.
Not quite.  For example, there is no 440 term.  Only terms
of order 6 or less are included.  Also, of course, you must
include 600, 060, and 006, which are not legal numbers in
base 6.  So the real answer is: count down (base 10) from
777, and only include numbers where the sum of the digits
is equal to or less than the order of the polynomial you're
generating.  Of course, there are easier and more efficient
ways to do it.
Here's a perl program that will generate the terms in
the correct order, suitable for including in a POV file.
to use it on Unix, just call it "coeffs", make it mode 700,
and type "coeffs 6 >coeffs.out" to create a file called
"coeffs.out" containing the definition for a poly of order
6.  Under Windows, you'll have to type
"perl coeffs 6 >coeffs.out" and make sure perl.exe is in
your path somewhere.  To find a recent port of Perl for
your machine, see http://cpan.perl.org/ports/
Programmers in other languages, feel free to borrow this
and rewrite it for the Perl-deprived.  Windows and Mac
users, hop over to povray.binaries.utilities and grab
the template file I'll post over there shortly.
----------- cut here ------>8==========
#!/usr/bin/perl -w
use strict;
my $order = $ARGV[0];
print "poly { $order, <\n";
for ( my $x=$order; $x >= 0; $x-- ) {
  for ( my $y=$order-$x; $y >= 0; $y-- ) {
    for ( my $z=$order-$y-$x; $z >= 0; $z-- ) {
      print '  0';
      if ($x+$y+$z) {
        print ', /* ';
        print 'x' if ($x);
        print $x if ($x>1);
        print 'y' if ($y);
        print $y if ($y>1);
        print 'z' if ($z);
        print $z if ($z>1);
        print ' */';
    print "\n";
print "> }\n";
Here's a sample of the output, for order 3:
poly { 3, <
  0, /* x3 */
  0, /* x2y */
  0, /* x2z */
  0, /* x2 */
  0, /* xy2 */
  0, /* xyz */
  0, /* xy */
  0, /* xz2 */
  0, /* xz */
  0, /* x */
  0, /* y3 */
  0, /* y2z */
  0, /* y2 */
  0, /* yz2 */
  0, /* yz */
  0, /* y */
  0, /* z3 */
  0, /* z2 */
  0, /* z */
  0
Date: 11 Feb 1998 14:38:52
Message: <34e20b29.0@news.povray.org>
I can't claim authorship of this, but here's a perl script which will take a
fairly standard infix notation equation (as opposed to postfix/referse
polish or prefix), and spit out the pov code for you.  Someone posted it on
CGRR way back when and I've kept a copy handy.
An example session is as follows:
bash-2.01$ echo "x^2*y^2*z^2+x^2*z^2+x*y*z=0"|poveq
poly {
    6, <0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
1, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0>
I know it's kind of finicky about spaces and such, but usually if you play
arround with it, you can get what you want.  The source file is listed
below.
Ken
----cut here---
#!/usr/bin/perl
while(<>)
    chop;
    $eq .= $_;
foreach $comp (split('\s*\+\s*',$eq))
    $comp =~ s/\s+//;
    $x=0; $y=0; $z=0; $coef=1;
    foreach $factor (split('\*',$comp))
        if ($factor =~ /^[xyz]/)
            ($var,$exp) = ($factor =~ /^([xyz])\^?(\d+)?/);
            $exp = 1 if ($exp =~ /^$/);
            eval "\$$var = $exp";
        } else {
            $coef = $factor;
    $equation{$x,$y,$z} = $coef;
    $power = $x+$y+$z if ($x+$y+$z > $power);
print "poly {\n    $power, <";
$first = 1;
for($x=$power;$x>=0;$x--)
    for($y=$power-$x;$y>=0;$y--)
        for($z=$power-$x-$y;$z>=0;$z--)
            #print "\n$x,$y,$z\n";
            print ", " if (!$first);
            $first = 0;
            if ($equation{$x,$y,$z})
                print "$equation{$x,$y,$z}";
            } else {
                print "0";
print ">\n}\n";
------cut here-------
Ronald L. Parker wrote in message <34e### [at] 100233>...
>>extend to 5th
>>to get each term.
>ways to do it.
>#!/usr/bin/perl -w
>use strict;
>      print '  0';
>      if ($x+$y+$z) {
>        print ', /* ';
>        print 'x' if ($x);
>        print $x if ($x>1);
>        print 'y' if ($y);
>        print $y if ($y>1);
>        print 'z' if ($z);
>        print $z if ($z>1);
>        print ' */';
>    print "\n";
>print "> }\n";
>poly { 3, <
>  0, /* x3 */
>  0, /* x2y */
>  0, /* x2z */
>  0, /* x2 */
>  0, /* xy2 */
>  0, /* xyz */
>  0, /* xy */
>  0, /* xz2 */
>  0, /* xz */
>  0, /* x */
>  0, /* y3 */
>  0, /* y2z */
>  0, /* y2 */
>  0, /* yz2 */
>  0, /* yz */
>  0, /* y */
>  0, /* z3 */
>  0, /* z2 */
>  0, /* z */
>  0
Date: 11 Feb 1998 16:07:27
Message: <34e20bd7.27585015@10.0.2.33>
On Wed, 11 Feb 1998 11:38:52 -0800, "Ken Cecka" <cec### [at] televarcom>
Note that "x^2-y^2=5" has to be represented as "x^2+-1*y^2+-5".  The
constant term after the '=' in your example is ignored.
Here's a version that works with the more intuitive  "x^2-y^2=5".  It
also fixes a syntax error in the original code, plus an error that
would occur if the input didn't end with a newline.
=====8<---- cut here ---------
#!/usr/bin/perl
while(<>) {
    chomp;
    $eq .= $_;
$coef=1;
$equation{0,0,0}=0-$1 if ( $eq =~ s/=(.*)$// );
foreach $comp (split('\s*([+-])\s*',$eq)) {
    $comp =~ s/\s+//;
    $x=0; $y=0; $z=0;
    $coef = -1, next if ( $comp eq '-' );
    $coef = 1, next if ( $comp eq '+' );
    foreach $factor (split('\*',$comp)) {
        if ($factor =~ /^[xyz]/) {
        } else {
            $coef *= $factor;
$first = 1;
for($x=$power;$x>=0;$x--) {
    for($y=$power-$x;$y>=0;$y--) {
        for($z=$power-$x-$y;$z>=0;$z--) {
            $first = 0;
            if ($equation{$x,$y,$z}) {
            } else {
                print "0";
print ">\n}\n";
Date: 13 Feb 1970 09:34:22
Message: <01bd3883$d2042480$181657a8@W_tristan.gb.tandem.com>
Doh yeah...
Ronald L. Parker <ron### [at] farmworkscom> wrote in article
| >extend to 5th
n00
| >to get each term.
| ways to do it.
| #!/usr/bin/perl -w
| use strict;
|       print '  0';
|       if ($x+$y+$z) {
|         print ', /* ';
|         print 'x' if ($x);
|         print $x if ($x>1);
|         print 'y' if ($y);
|         print $y if ($y>1);
|         print 'z' if ($z);
|         print $z if ($z>1);
|         print ' */';
|     print "\n";
| print "> }\n";
| poly { 3, <
|   0, /* x3 */
|   0, /* x2y */
|   0, /* x2z */
|   0, /* x2 */
|   0, /* xy2 */
|   0, /* xyz */
|   0, /* xy */
|   0, /* xz2 */
|   0, /* xz */
|   0, /* x */
|   0, /* y3 */
|   0, /* y2z */
|   0, /* y2 */
|   0, /* yz2 */
|   0, /* yz */
|   0, /* y */
|   0, /* z3 */
|   0, /* z2 */
|   0, /* z */
|   0
