POV-Ray : Newsgroups : povray.windows : Animation Question Server Time
6 Feb 2026 11:59:55 EST (-0500)
  Animation Question (Message 1 to 6 of 6)
Subject: Animation Question
Date: 13 Jan 1998 23:17:37
Message: <34bc4abe.0@news.povray.org>
If it's no trouble ... Would anyone know if this is rotating the sphere
or just the texture in the sphere? And could you explain the light
source and how much/many to use?
Thanks,
Mark Wright
#include "textures.inc"
 location <0,0.5,-5>
 look_at <0,0,0> }
light_source
     { <100,140,-300> color White }
sphere { <0,0,0>,2
 texture { Red_Marble } rotate 360*clock*y }
Download 'iso-8859-1' (2 KB)
Subject: Re: Animation Question
Date: 14 Jan 1970 01:52:56
Message: <01bd20af$4ca3a2c0$f5681cce@arkansasusa.com.arkansasusa.com>
As you defined the scene you are rotating the sphere, and thus the texture
with it.
  I believe that the more light_sources you use the greater the render
time, so don't get carried away. Because you didn't define an up, or right
vector for the camera, this scene will use the default left-handed sense.
If you read the doc's they do a great job of explaining handedness. This
will give you a relative idea (z extends into the monitor as it increases
in offset, and out of it as it decreases). Please forgive me, fellow
artists. :)
                    +y
                     |        +z
-x __________|/____________+x
           -z /     | -y
  You defined a single light_source offset 100 units in the *positive* x
direction (to the right), 140 units in the positive y (vertical) direction,
and 300 units in the negative z direction (you can think of it as behind
you, if you are the camera). If you go further and declare a plane for a
floor, or as a wall to the rear, you will see a shadow from the sphere
(Perhaps. It has to be placed right even then). If you place the light
co-position with the camera, it is not likely that you will see a shadow.
OR, if you can add the keyword "no_shadow" to the sphere definition to
eliminate it altogether. As you render this image you should see a shadow
slightly visible on the left side, and the sphere and texture rotating to
the left, together.
  Additionally, you really should add the pigment statement within your
texture definition, thusly:
      texture { pigment { Red_Marble } }
  Try using the following within an ini file to render the scene. Assuming
you are using the Windows version, this will work great.
[ Sphere Anim. 320x240 ]
Initial_Frame=0
Final_Frame=32
Initial_Clock=0
Final_Clock=1
+w320 +h240 +a.3 +r2 +q9
Cyclic_Animation = on
   I hope that helps. Keep on Tracing!
Paul Hinds
gri### [at] swbellnet
Date: 14 Jan 1998 13:37:05
Message: <34bd1424.0@news.povray.org>
Thanks GrimDude .. I've read the help docs over and over and Your
explaination really helped to clear up the cobwebs.
Mark Wright
Download 'iso-8859-1' (1 KB)
Date: 14 Jan 1970 16:11:22
Message: <01bd2127$3fc729a0$ec681cce@arkansasusa.com.arkansasusa.com>
I'm glad to help, Mark. I hope to see some of your work over on
povray.binary.images real soon. ;)
Paul Hinds
Date: 16 Jan 1998 11:58:12
Message: <34bfa3ee.0@news.povray.org>
Hmm, now that I have Outlook installed my last post is no longer formatted
correctly. How ever did you read it, Mark?
Paul Hinds
GrimDude wrote in message
<01bd20af$4ca3a2c0$f5681cce@arkansasusa.com.arkansasusa.com>...
>with it.
>artists. :)
>                    +y
>                     |        +z
>           -z /     | -y
>the left, together.
>Initial_Frame=0
>Final_Frame=32
>Initial_Clock=0
>Final_Clock=1
>Paul Hinds
Date: 16 Jan 1998 21:56:47
Message: <34c02c2b.0@news.povray.org>
Hmmm ... Not sure GrimDude, I let the computer do its thing and I do mine.
-Mark Wright
GrimDude wrote in message <34bfa3ee.0@news.povray.org>...
>Paul Hinds
>>with it.
>>artists. :)
>>                    +y
>>                     |        +z
>>           -z /     | -y
direction,
>>the left, together.
>>Initial_Frame=0
>>Final_Frame=32
>>Initial_Clock=0
>>Final_Clock=1
>>Paul Hinds
