POV-Ray : Newsgroups : povray.windows : POV crash when using height field from terrain maker Server Time
1 Apr 2026 21:08:49 EDT (-0400)
  POV crash when using height field from terrain maker (Message 1 to 6 of 6)
Subject: POV crash when using height field from terrain maker
Date: 6 Jan 1998 23:04:45
Message: <34B2FEDD.5742@emc.com>
	I have just started playing with height fields.  I found the
"terrain maker" program, which I must say is fantastic.
	For some reason, POV crashes when rendering most of the
height fields that I create.  Some resolutions won't crash on
the same .pov and height field file.
	I am using POV that includes Pvengine.exe dated 9/10/96.
	Has anyone seen or solved this problem?
_John Miskinis_
Subject: Re: POV crash when using height field from terrain maker
Date: 7 Jan 1998 08:43:35
Message: <34b38d57.0@news.povray.org>
I've had this happen in the Linux version of POV-Ray (3.02).
The workaround seems to be in reducing the size of the image file
used for the height_field.
At any rate, I don't think the problem has anything to do with
Terrain Maker specifically.
Date: 8 Jan 1998 01:43:53
Message: <34B475A9.E7AAE357@neta.com>
I seem to get the HF crashes when I set the camera angle higher than 45
degrees and look down on my HF. Kinda strange.
Timothy A. Grubb
Date: 10 Jan 1998 03:02:46
Message: <34b72b1e.5583680@news.stmuc.com>
On Tue, 06 Jan 1998 23:04:45 -0500, John Miskinis <mis### [at] emccom>
wrote:
>Hi,
>_John Miskinis_
Hi John, is it still v1.1 or is the 2.0 available?
		steff
Date: 10 Jan 1998 12:35:35
Message: <34B7B167.3C9B@emc.com>
>                 steff
	It is v1.1, from 1994.  Note that the first screen you see
	when it examines the VGA driver says "1.0", but the main
	screen says "1.1".
	It's a great program, but I'm a little frustrated that POV
	crashes on some of the terrains I generate.
_John_
Date: 15 Jan 1998 20:12:17
Message: <34beb3e4.8213470@news.stmuc.com>
On Sat, 10 Jan 1998 12:35:35 -0500, John Miskinis <mis### [at] emccom>
>>                 steff
>Hi,
>	screen says "1.1".
I'm afraid can't help you there. But I asked, 'cause it's bound to
have a new release soon, according to the webpage.
>_John_
