POV-Ray : Newsgroups : povray.windows : Prism Server Time
7 Sep 2025 18:18:43 EDT (-0400)
  Prism (Message 1 to 3 of 3)
Subject: Prism
Date: 3 Jan 1998 00:59:54
Message: <34ADD3D9.F7C6BB15@hal-pc.org>
Am I doing something wrong, or what?
I have included the prism statement generated by the editor in POV-Ray
for Windows. It looks like this:
prism {
  linear_sweep // or conic_sweep for tapering to a point
  cubic_spline // linear_spline | quadratic_spline | cubic_spline
  -0.5,        // height 1
   0.5,        // height 2
  10,          // number of points
  // the <u,v> points
  < 0.2, -1.0>, < 0.2,  0.2>, < 1.0, -0.2>, < 1.0,  0.2>, < 0.2,  1.0>,
  <-0.2,  1.0>, <-1.0,  0.2>, <-1.0, -0.2>, <-0.2,  0.2>, <-0.2, -1.0>
  // [open]
  // [sturm]
When I try and compile this, I get:
"Returned from renderer (non-zero return value)?."
Jon
Subject: Re: Prism
Date: 3 Jan 1998 07:50:57
Message: <34AE3431.9E553539@hal-pc.org>
> prism {
>   -0.5,        // height 1
>    0.5,        // height 2
>   // the <u,v> points
> 1.0>,
>   // [open]
>   // [sturm]
Actually, it says: "Too few points in prism".
Jon
Subject: Re: Prism
Date: 5 Jan 1998 10:14:38
Message: <34b2f466.6069898@10.0.2.33>
On Sat, 03 Jan 1998 06:50:57 -0600, "Jon S. Berndt" <jsb### [at] hal-pcorg>
>> prism {
>>   -0.5,        // height 1
>>    0.5,        // height 2
>>   // the <u,v> points
>> 1.0>,
>>   // [open]
>>   // [sturm]
Perhaps there are some words of wisdom in section 7.5.2.8 of the
manual:
	Each of the sub-prisms has to be closed by repeating the first
	point of a sub-prism at the end of the sub-prism's point
	sequence. If this is not the case a warning is issued and the
	prism is ignored (with linear splines automatic closing is
	used). This implies that all points of a prism are different
	(except the first and last of course). This applies to all
	spline types though the control points of the quadratic and
	cubic splines can be arbitrarily chosen.
	The last sub-prism of a linear spline prism is automatically
	closed - just like the last sub-polygon in the polygon
	statement - if the first and last point of the sub-polygon's
	point sequence are not the same. This make it very easy to
	convert between polygons and prisms. Quadratic and cubic
	splines are never automatically closed.
The prism isn't closed, but if you change it to a linear spline it
would be closed for you.  Otherwise, you'll have to close it manually
(and don't forget the two extra control points.)  Here's one possible
fix:
// extrude a closed 2-D shape along an axis
prism {
 -0.5,        // height 1
  0.5,        // height 2
 13,          // number of points
 // the <u,v> points
 <-0.2,  1.0>, <-1.0,  0.2>, <-1.0, -0.2>, <-0.2,  0.2>, <-0.2, -1.0>,
 // [open]
 // [sturm]
To fix this in the POV editor templates, choose "Edit POV3TMPL.TXT"
from the Tools menu and search for "@mt2.prism"
