POV-Ray : Newsgroups : povray.windows : Simple Animation Scene Server Time
1 Apr 2026 22:46:38 EDT (-0400)
  Simple Animation Scene (Message 1 to 3 of 3)
Subject: Simple Animation Scene
Date: 5 Nov 1997 12:02:09
Message: <3460A691.E2709CDD@ecs.soton.ac.uk-NOSPAM>
Hi there
OK, this is basically how to use the clock variable - how it works is,
if you tell POV-Ray to render multiple frames, it renders the first
frame with the variable 'clock' set to 0, the last one with clock=1, and
automatically works out the clock values in-between.
This piece of code creates a box rotating around the y-axis:
object {
  box {<-1,-1,-1>, <1,1,1>}
  pigment {colour Blue}
  rotate <0, clock*360, 0>
- to render it across twenty animation frames, use the command line
switches
POVRAY <other switches> +KFI1 +KFF20
(KFIn = initial frame number n, KFFn = final frame number n)
A useful tip for animation loops is to render one more frame than
needed, ie. render 21 frames rather than 20, and then delete the last
frame file before you 'compile' the animation, since if you just compile
a normal frame sequence the first and last frames are identical and
there's a noticeable stutter in the animation loop.
Hope this is some help to you.
Dylan
Subject: Re: Simple Animation Scene
Date: 5 Nov 1997 12:58:15
Message: <3460b311.213940790@news.stmuc.com>
On Wed, 05 Nov 1997 17:02:09 +0000, Dylan Beattie
>Dylan
An alternative to this method is to use the POV-Ray +KC switch to turn
on POV's awareness of cyclical animation. i.e., it will do essentialy
what you described.. if you ask for 20 frames, it calculates 'clock'
as if it were doing 21 frames but only renders 20 frames.
Subject: Re: Simple Animation Scene - Oops!
Date: 5 Nov 1997 12:04:04
Message: <3460A704.6536C9CE@ecs.soton.ac.uk-NOSPAM>
OOPS - I just noticed that I screwed that code up, it SHOULD read:
object {
Sorry!
Dylan
