POV-Ray : Newsgroups : povray.windows : Animation question.... Server Time
6 Feb 2026 11:54:37 EST (-0500)
  Animation question.... (Message 1 to 5 of 5)
Subject: Animation question....
Date: 4 Nov 1997 16:17:35
Message: <345F90EE.5C1A8FD8@mindless.com>
I am kind of new to animation with pov....
did one last night, rendered it all by hand (250+ frames)
and it took me 4.5 hours.....
to use the clock variable, all that I have to do is put it in the pov
file right?
if someone has an example of a simple, animation sequence, text
spinning, etc. that they would be willing to let me take a look at, I
would be most appreciative.
tec### [at] mindlesscom
"Of all the things that I have lost I miss my mind the most"
--Jimi Hendrix
Subject: Re: Animation question....
Date: 5 Nov 1997 20:34:14
Message: <34612d58.0@aussie.org>
The clock variable works just like you would expect.  Here's a sample scene
to spin a box.  If I overlook something, I'm sorry.  I'm just typing it out
here, not testing it.  To render the scene, you have to use command line
parameters or an ini file to tell pov you are rendering an animation, and
how many frames you want.  You can set command line parameters in POV for
Windows by going to the render menu, and Edit Settings/Render.  There is a
box near the bottom labeled Command line options.  If you want to do a 30
frame animation of this scene, type +KFF30 in the box.  Next time you
render, it will do 30 frames, slowly moving the clock from 0 to 1.  Since
this acts like a percentage, multiplying the clock by 360 in the rotation
(see code below) cause the box to go through one full rotation by the end of
the animation.  Play arround with it a little and you should get the hang of
it.  This idea would work with a text object or whatever.
Ken
---begin scene file---
  location <0,5,-5>
light_source {
  <-10,10-10>
  color White
box {
  <-1,-1,-1>
  <1,1,1>
  pigment {Red}
  rotate <0,clock*360,0>
--end scene file--
TechnoMage wrote in message <345F90EE.5C1A8FD8@mindless.com>...
>file right?
>--Jimi Hendrix
Date: 6 Nov 1997 05:05:36
Message: <34619670.7E0C@mindless.com>
THANKS!!!!
reading all the documentation in the world is not as good as having
*one* good example to go by.....
btw, the scene file that you wrote did need a little tweaking....
with your permision I will post the updated code to the
povray.binaries.scene-files group, maybe it will help someone else...
again thanks...
TechnoMage
Date: 6 Nov 1997 13:50:05
Message: <34622020.0@aussie.org>
Sure.  Feel free.  As far as examples vs. documentation, that's one thing
that I love about the pov documentation is that it includes lots of example
code, as well as in depth descriptions.  Anyway, go ahead and post.
Ken
wrote in message <346### [at] mindlesscom>...
>THANKS!!!!
>again thanks...
>TechnoMage
Date: 1 Jan 1998 11:35:02
Message: <34abd32b.0@news.povray.org>
Ken Cecka wrote in message <346### [at] aussieorg>...
of
of
>Ken
You should also make sure you have the parameter "Cyclic_Animation=on" in
you command line.  This tells POV-Ray to move the clock from 0 to something
slightly less than 1.  That way, if you play the animation with looping it
won't jump when it starts over.
Aaron Plattner
