POV-Ray : Newsgroups : povray.windows : HELP! My gradients aren't "fluent" Server Time
1 Apr 2026 16:39:41 EDT (-0400)
  HELP! My gradients aren't "fluent" (Message 1 to 4 of 4)
Subject: HELP! My gradients aren't "fluent"
Date: 12 Feb 1999 11:12:25
Message: <1103_918836093@leerintveld>
Hello!
Can somebody please help me with my non-fluent-gradients? I'm using Pov-ray v3.1 and
when I try to make a gradient-background like a dawn or something, I keep
getting this really annoying "lines". I mean, you can see very clearly where one color
starts and the other ends, you know what I mean?
I hope somebody can help me with this!
regards,
Bas Leerintveld
bas### [at] ddsnl
Subject: Re: HELP! My gradients aren't "fluent"
Date: 12 Feb 1999 12:34:27
Message: <MPG.112e8257c7baba02989687@news.povray.org>
'T was on Fri, 12 Feb 1999 16:14:53 GMT,
> I'm using Pov-ray v3.1 and when I try to make a gradient-background
> like a dawn or something, I keep getting this really annoying "lines".
> I mean, you can see very clearly where one color starts and the
I think you are trying to watch the image on a 16-bit colour screen. If
this is the case, change it to 24-bit or higher.
Phoenix
eag### [at] telekabelnl                       http://users.telekabel.nl/eagle
The POV-Ray VFAQ: http://iki.fi/warp/povVFAQ.html
Date: 12 Feb 1999 19:48:20
Message: <36C4CBA9.E0E7DFEB@aol.com>
Yep, either that or the video is not good anyhow. Or you may even have
the color_map setup wrong(?). Is it in the form of:
 color_map {
  [0 color rgb<1,0,0>]
  [.3 color rgb<1,1,0>]
  [.6 color rgb<0,1,1>]
  [1 color rgb<0,0,1>]
? Or perhaps:
 color_map {
  [0,.3 color rgb<1,0,0> color rgb<1,1,0>]
  [.3,.6 color rgb<1,1,0> color rgb<0,1,1>]
  [.6,1 color rgb<0,1,1> color rgb<0,0,1>]
And if wrapping it:
 color_map {
  [0,.1 color rgb<0,0,1> color rgb<1,0,0>] //begins blue
  [.1,.3 color rgb<1,0,0> color rgb<1,1,0>]
  [.6,1 color rgb<0,1,1> color rgb<0,0,1>] //ends blue
> Phoenix
 mailto:inv### [at] aolcom?PoV
Date: 12 Feb 1999 21:33:59
Message: <36C4E38A.B3F7531E@aol.com>
Try rendering larger.  Color patterns are just as prone to aliasing as
geometry.  There's no way to get grey between a white and black line if
you only render two lines.
-Mike
> Hello!
color starts and the other ends, you know what I mean?
> regards,
> Bas Leerintveld
> bas### [at] ddsnl
