POV-Ray : Newsgroups : povray.windows : Does the editor properties dialog crash for you? Server Time
6 Feb 2026 04:36:25 EST (-0500)
  Does the editor properties dialog crash for you? (Message 1 to 8 of 8)
Subject: Does the editor properties dialog crash for you?
Date: 11 Feb 1999 02:25:35
Message: <01be558f$e53bac10$ef7581ce@angus>
Hello,
A member of the POVRay team has informed me that several customers have
reported crashing POVRay 3.1 when invoking the code editor properties
dialog (rclick then 'Properties', or Alt+Enter) and switching to the
'Keyboard' tab.
I have been unable to reproduce this, and have not heard anything from
non-POVRay users of CodeMax.
If you have experienced this crash, could you please respond to this
message with the following information?
1) Operating system version (e.g. Windows NT 4.0 SP3)
2) Keyboard language locale (set in Control Panel - keyboard settings)
3) What localized version of Windows are you running? (US? German? French?
etc)
I'd like to get this fixed immediately so the next version of POVRay will
not crash.
Thanks!
Barry Allyn, CodeMax author
WinMain Software
Subject: Re: Does the editor properties dialog crash for you?
Date: 11 Feb 1999 05:53:30
Message: <36C2B692.5F4415CF@aol.com>
Windows 95 OSR2 and IE 4.01 SP1
Language:                     Layout:
En English(United States)     United States 101
104 keys on keyboard (3 Windows keys) however the profile states PC/AT
Enhanced Keyboard 101/102 key.
> etc)
English (U.S.)
> WinMain Software
 mailto:inv### [at] aolcom?PoV
Date: 11 Feb 1999 11:21:57
Message: <36C3038F.4B84AEF9@compuserveNO-SPAM.com>
>>    French? etc)
  Hi, Barry. The following question might also help you.
4) Can you consistently repeat this bug/crash?
- Alan
"Do you expect me to talk?" - James Bond
"No, Mr. Bond... I expect you to die!" - Auric Goldfinger
                                         "Goldfinger" (1964)
Date: 11 Feb 1999 18:27:53
Message: <36C3663C.33F60ED7@bahnhof.se>
Barry Allyn wrote:
> Hello,
Windows 95 osr 2 +USB support
Swedish 101+3
swedish
Crash report :
PVENGINE.EXE caused fault #c0000005 in CMAX101.DLL at address
0137:10018ccd
To date, 1 fatal errors have been recorded in this program.  This
particular error was recorded 1 times.
Reported By:
CrashGuard v2.0.1
Report Date:
1999-01-23 17:59:11
WindowTitle:
Render Window
Last Message:
MSG("Misc", 0110, 00000000, 005D2BC4)
Program:
C:\GRAPHIC\POV-RAY FOR WINDOWS V3.1\BIN\PVENGINE.EXE
(10/05/98 01:13 - 1768448)
Registers:
EAX=00000000 CS=0137
EIP=10018ccd EFLGS=00010202
EBX=bff61681 SS=013f
ESP=0077f18c EBP=0077f1b8
ECX=00000010 DS=013f
ESI=00000f94 FS=32e7
EDX=0077f5fc ES=013f
EDI=00000001 GS=0000
Bytes at CS:EIP:
8b 47 6c c1 f8 1e 50 68 04 04 00 00 56 ff d3 8b
Stack dump:
0077f1a0 0000820e 0077f1b8 0077f1ea bff73663 00000f94 00000110 00000000
005d2bc4 81e80d5f 0000013f 0077f1cc bff92894 36df820e 000036df 00000000
//Spider
Date: 12 Feb 1999 22:06:02
Message: <01be56fd$f9c25610$b17581ce@angus>
Alan,
Thanks for the heads-up.  From what I've gathered, this crash happens 100%
of the time..
-Barry Allyn
Date: 12 Feb 1999 22:19:33
Message: <36C4EDFF.BD49C859@bahnhof.se>
Barry Allyn wrote:
> Alan,
> Thanks for the heads-up.  From what I've gathered, this crash happens 100%  of the
time..
No, it doesn't...
I have no idea why, but in the first time, I had a crash every time I
used either language or keyboard tabs, but lately, it hasn't crashed at
all. I can't say what changes I have done, since i continually update
software that changes drivers and such. but I can tell that there were
no new OS or hardware install. Sorry for beeing such a poor bug-finder
in this case.
//Spider
Date: 15 Feb 1999 08:28:42
Message: <36C820B2.690E87F6@pacbell.net>
Barry Allyn wrote:
> Hello,
> 'Keyboard' tab.
> etc)
> not crash.
> Thanks!
> WinMain Software
Hi Barry !
  This is unrelated to the keyboard tab issue but since I had a fault with
the control panel tonight I thought I would share some info with you.
  I usualy have several files open at once. In one file I cut some text of
of the file, opened a new file and pasted it in. I accidentaly cut a little
too much out so I highlighted the text I needed to return to the previous
file with the shift/arrow keys. As I was doing this my overly sensitive
mouse button in my other hand brought up the control panel. With my finger
still on the shift key I clicked on the desktop to close the control panel
and I got the FFFFFFFF warning. Actualy I recieved three different warnings
as listed below.
The first was -
Access violation at address 1000ABDA in modual cmax101.dll
read of address FFFFFFFF
immediatly followed by -
Access violation at address 0077EEF1
Note: there was no mention of modual cmax101.dll in this warning
or the next -
Access violation at address 51FF01B2
read of address 51FF01B2
None of these cause pov to crash and it recovered without complaint.
  I was able to repeat these access violations at will by repeating the
highlight text, right click for control panel and clicking on the desktop
sequence. I closed the program and then restarted it. With a little bit
of pushing I was able to make it happen yet again.
  I have a pentium 200 mmx 128 megs of edo ram in one bank. My keyboard
is an older AT standard 106 key unit set for the english language on a
windows 98 US version platform. At the time of the access violations
I had only two other programs running in the background - one explorer the
other a small calculator program I keep handy floating above the Pov session.
Nothing else was active in the widows task monitor window at the time of the
problem.
If you haven't already done so please see my recent comments to Alan in
povray.bugreports concerning this issue.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 16 Feb 1999 01:12:01
Message: <01be5973$736e9290$527581ce@angus>
Ken,
Thanks for the note.  I'll respond privately for more details since this is
not the bug-reports forum.  Expect my email by the time you read this.
Thanks!
-Barry
