POV-Ray : Newsgroups : povray.windows : DXF to POV Server Time
16 May 2026 04:52:47 EDT (-0400)
  DXF to POV (Message 1 to 10 of 11)
Subject: DXF to POV
Date: 10 Nov 1970 15:31:20
Message: <01bcee0f$4d9a28c0$579728a1@1864816.unitedspacealliance.com>
Is anyone aware of a program (or extension ??) which takes a .dxf file
(e.g. AutoCAD files, or 3D Home Designer-exports - in my case) and converts
it to a POV file? Surely there must be one. If not, would anyone here like
to see one? If I can't find one I'll probably "roll my own".
Jon Berndt
Subject: Re: DXF to POV
Date: 10 Nov 1997 20:39:02
Message: <3467B736.DDF@mindless.com>
> Jon Berndt
I am not sure of where to get one that will only do that, but Breeze
Designer 2.0 will import DXF and export POV.....
hope that helps...
TechnoMage
Date: 11 Nov 1997 00:24:05
Message: <3467ea6e.372399602@news.stmuc.com>
>Jon Berndt
Jon,
  I've had the same need and already rolled my own.  It's a two step
process.  Convert from DXF to RAW and thenfrom RAW to POV.  What I've
done is write the first part, a utility called D2R  (I've just but a
copy of the archive up in povray.binaries.utilites).  The second step,
converting from RAW to POV is don with Thomas Baier's 3DTO3D (There's
a DOS windows as well as a Windows version).  3DTO3D can be obtained
at his site at
  http://ourworld.compuserve.com/homepages/thbaier/
     George Hunt
P.S.
   My D2R utility is also available at my site...
George Hunt --- Raytracer Obsessivo
http://ourworld.compuserve.com/homepages/lightsword
102### [at] compuservecom
Date: 11 Nov 1997 09:27:06
Message: <34686B3A.6F4DF9B9@hal-pc.org>
> file
> converts
> like
> >Jon Berndt
> Jon,
> at his site at
>   Regards,
>      George Hunt
> P.S.
I have looked at the .dxf output from 3D Home Architect, and it looks
like 2D code. I have written to Broderbund (mfgr'r of 3DHA) asking them
about this but do not expect a reply for a day or two, if at all.
I sure would like to transform my floor plans to POV ... will your
method work for this?
Jon
Date: 11 Nov 1997 23:49:10
Message: <34693546.2539@aol.com>
> > file
> > converts
> > like
> > >Jon Berndt
> > Jon,
> > at his site at
> >   Regards,
> >      George Hunt
> > P.S.
If it is 2D code, you will need to loft it into a 3d object.  I don't
know what programs can do it that are free.  Moray might...  You might
need to convert it to an EPS file, or an AI file.  Just lofting it will
look pretty bad though.  If it is 3d dxf file, then most dxf coverters
should work, I would think.
Date: 20 Nov 1997 18:42:18
Message: <3474CADA.3A44@yuck.geocities.com>
> > > file
> > > converts
There is a program I've used before called Realize.  This is the
description in the documentation:
   " REALIZE is a full-featured, one-step dxf file to POV ver 2.0
converter.
    For  those not  familiar  with POV  -  POV is one of the best (if
not the best) ray-tracers available. POV's incredibly rich decription
language allows truly photo-realistic renderings.  If you have a 3D or
even a 2D drawing in dxf format that you would like to present in an
impressive sort of way or perhaps you just like to visualize the
finished product, REALIZE will convert it to POV format which can then
be rendered in the most realistic method - ray-tracing.
    For those not familiar with the .dxf file format - dxf (Drawing
interchange file format) is a nearly universal format to convey drawing
information. Most notable systems are AutoCad, AutoCad Lite, Cadkey,
etc.
    Even if you don't own any of these powerful CAD packages, you can
still use REALIZE as long as your drawing package can produce a line in
.dxf format. REALIZE can extrude your 2D lines and/or "fatten" it to
produce POV description language code for realistic 3D images (see
demoplan.rdr)."
I don't remember where I downloaded it, but if you need it I could zip
it and email it to you.
serket
Date: 20 Nov 1997 22:09:34
Message: <3474FB6E.B2EE5D66@hal-pc.org>
> .dxf
> > > > file
> and
> > > > converts
> anyone
> converter.
> drawing
> etc.
> in
> demoplan.rdr)."
> serket
I would appreciate that. I tried to email you but your address was
invalid for some reason.
I will try and search for it, too.
Thanks,
Jon
Date: 21 Nov 1997 01:02:00
Message: <347523D8.BC73E266@ibm.net>
check out please
http://ourworld.compuserve.com/homepages/thbaier/tools.htm.
3DWin 3.0 now supports dxf.
Date: 20 Nov 1997 21:50:27
Message: <3474f695.515345555@news.stmuc.com>
On Tue, 11 Nov 1997 08:27:06 -0600, "Jon S. Berndt" <jsb### [at] hal-pcorg>
wrote:
Here's yet another solution...
See Thomas Baier's 3DWin program --- apparently a newer version of his
3DTO3D program, this one takes DXF (among other things) and outputs
POV (among MANY other things).  Check it out...
Date: 16 Dec 1997 04:12:02
Message: <349653f1.0@news.povray.org>
Jon Berndt wrote in message
<01bcee0f$4d9a28c0$579728a1@1864816.unitedspacealliance.com>...
>Jon Berndt
You can try WCVT2POV and Crossroads - both by Keith Rule.
(http://www.europa.com/~keithr/)
|Knut Torgersen         |Bart, don't swear! You're  |
|tor### [at] geocitiescom|no longer in Sunday School!|
|    http://www.geocities.com/area51/lair/3640/     |
