POV-Ray : Newsgroups : povray.unofficial.patches : Compiling UberPOV on MacOSX Server Time
7 Jan 2026 02:32:16 EST (-0500)
  Compiling UberPOV on MacOSX (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Compiling UberPOV on MacOSX
Date: 2 Dec 2013 16:25:00
Message: <web.529cfa64d8663c00409e7c7f0@news.povray.org>
Thanks for the reply. I haven't tried to compile POV-Ray on Mac before - Yvo's
unofficial builds have worked perfectly for me, but of course I wanted to tinker
with UberPOV :)
> I expect that to happen any moment now, so I'm a bit reluctant to sneak
> the fixes into UberPOV via the side door, and would rather prefer to
> merge them from the POV-Ray master branch once they're there.
So I guess I'm better off waiting for the fixes to make it back in officially?
I'm in no particular rush if this stuff is being worked on already, and I also
have a linux box I can use it on in the meantime.
Bill
Date: 3 Dec 2013 06:40:02
Message: <1ldayvs.1rzzfqmipd4uwN%yvo.s@cancel_This_gmx.net>
Bill Pragnell <bil### [at] hotmailcom> wrote: I have already compiled
UberPOV for MacOS but I have to create an archive and update the home
page for it.
You can of course download the xcode project for the command line
version on my home page and move the uberpov sources into it.
http://megapov.inetart.net/povrayunofficial_mac/
You only have to take
care not to modify
libraries/jpeg/jconfig.h
source/backend/povray.h >> I think it is save to replace this one
vfe/syspovprotobase.h
becouse there are a few tweaks.
Don't replace the png, tiff,... libs. They are the
same for both 3.7 and UberPOV.` All in one project, no messing with make
etc...
I compiled both, gui and command line version of UberPOV f I have time I
Iwill upload UberPOV beta 3 for mac later today after work. If time
Ipermits.
Yvo > Thanks for the reply. I haven't tried to compile POV-Ray on Mac
before - Yvo's > unofficial builds have worked perfectly for me, but of
course I wanted to tinker > with UberPOV :) > > clipka
<ano### [at] anonymousorg> wrote: > > I expect that to happen any moment
now, so I'm a bit reluctant to sneak > > the fixes into UberPOV via the
side door, and would rather prefer to > > merge them from the POV-Ray
master branch once they're there. > > So I guess I'm better off waiting
for the fixes to make it back in officially? > I'm in no particular rush
if this stuff is being worked on already, and I also > have a linux box
I can use it on in the meantime. > > Bill
-- ----------------------------------- MegaPOV at:
http://megapov.inetart.net MacMegaPOV at:
http://users.skynet.be/smellenbergh E-mail: yvo(DOT)s(AT)gmx.net
Date: 3 Dec 2013 10:17:17
Message: <529df5fd$1@news.povray.org>
Am 03.12.2013 12:40, schrieb Yvo Smellenbergh:
> Ipermits.
:-D
Thanks, once again, for your faithful catering to the Mac-affine wing of
the POV-Ray community!
Date: 4 Dec 2013 05:40:00
Message: <web.529f065bd8663c005b7d07940@news.povray.org>
> > Ipermits.
> :-D
Seconded, that's amazing, thanks! I shall try it out tonight.
Bill
Date: 4 Dec 2013 05:59:24
Message: <529f0b0c$1@news.povray.org>
Am 04.12.2013 11:39, schrieb Bill Pragnell:
>>> Ipermits.
>> :-D
I'd also like to kindly ask you to try compiling from this version:
https://github.com/UberPOV/UberPOV/archive/feature/osx-support.zip
It's supposed to build fine(*) on OS X now, but I need a guinea pig to
actually try it ;-)
(* except for the boost thing. You'll still need to add
LIBS="-lboost_system -lboost_thread" to the ./configure command to get
around that one; but that's not a Mac-specific issue.)
Date: 4 Dec 2013 14:05:00
Message: <web.529f7ca3d8663c00409e7c7f0@news.povray.org>
> actually try it ;-)
The prebuild script works fine now, but configure still bails at the boost check
even with your suggested LIBS switch, or with --with-boost and
--with-boost-thread set as per many other 3.7 compilation newsgroup threads (my
boost libs are installed in /opt/local/lib/, if that's relevant).
Bill
Date: 4 Dec 2013 14:12:07
Message: <529f7e87$1@news.povray.org>
Am 04.12.2013 20:04, schrieb Bill Pragnell:
>> actually try it ;-)
Can you give any additional details (what exactly configure is
complaining about)?
You do have boost installed, do you?
Date: 4 Dec 2013 14:55:01
Message: <web.529f8762d8663c00409e7c7f0@news.povray.org>
> complaining about)?
This seems to be the relevant chunk of config.log:
configure:7606: checking whether the Boost::Thread library is available
configure:7638: g++ -c -pthread  -D_THREAD_SAFE   -I/opt/local/include
conftest.cpp >&5
configure:7638: $? = 0
configure:7653: result: yes
configure:7682: checking for exit in -lboost_thread-mt
configure:7707: g++ -o conftest  -D_THREAD_SAFE   -I/opt/local/include
-L/opt/local/lib conftest.cpp -lboost_thread-mt   -D_THREAD_SAFE   >&5
configure:7707: $? = 0
configure:7717: result: yes
configure:7849: checking whether the boost thread library is usable
configure:7869: g++ -o conftest  -D_THREAD_SAFE   -pthread -I/opt/local/include
Undefined symbols:
  "boost::system::generic_category()", referenced from:
      __static_initialization_and_destruction_0(int, int)in ccjJtpIS.o
  "boost::system::system_category()", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
Worth asking, but yes ;)
Bill
Date: 4 Dec 2013 15:37:04
Message: <529f9270$1@news.povray.org>
Am 04.12.2013 20:49, schrieb Bill Pragnell:
>> complaining about)?
> conftest.cpp >&5
> Undefined symbols:
Is this with LIBS="-lboost_system -lboost_thread"? If not, can you try
that again and post the relevant config.log section?
Date: 4 Dec 2013 16:10:01
Message: <web.529f996ad8663c00409e7c7f0@news.povray.org>
with the LIBS as above:
configure:4820: checking whether the C compiler works
configure:4842: gcc    conftest.c -lboost_system -lboost_thread >&5
ld: library not found for -lboost_system
configure:4846: $? = 1
configure:4884: result: no
the boost_system libs are /opt/local/lib/libboost_system-mt.a and .dylib.
Bill
