POV-Ray : Newsgroups : povray.unofficial.patches : Megapov post_process save_file format Server Time
26 May 2024 19:10:31 EDT (-0400)
  Megapov post_process save_file format (Message 1 to 3 of 3)
Subject: Megapov post_process save_file format
Date: 11 Jan 2011 06:00:00
Message: <web.4d2c3703162a5787a8dd583f0@news.povray.org>
Hello everyone,
I'm using this macro :
#version unofficial MegaPov 1.21;
#macro make_depth(max_depth, min_depth, file_name)
global_settings{
        post_process {
                PP_Init_Depth_Output()
                function { (f_output_depth(x,y)-min_depth)/(max_depth-min_depth)
                function { 1 }
                save_file file_name
to compute the distance to first intersection.
Everything is working allright, and I get my distance as a png image, with 256
grayscale.
Problems come on the next step : 256 grayscales are not precise enough.
Is there a way to change the format in which the save_file command saves the
image ?
I tried to write the distance into a formatted txt file, which would be
acceptable, but I need to get a float from f_output_depth(x,y), and this seems
to be a vector or color expression.
If this is documented somewhere, I dont find it...
Thanks for helping
Subject: Re: Megapov post_process save_file format
Date: 11 Jan 2011 14:22:13
Message: <4d2cade5@news.povray.org>
> image ?
I'm not so familiar with MegaPOV but you could check if
the hf_gray_16 keyword has any effect here. Otherwise, you
might consider using a gray color gradient texture instead
of depth post-processing and using regular image output.
Possibly you could output a second image where the
function is defined not as the depth but as 256.0 times
the remainder of depth when dividing by 1/256 (or something
like that), so you get a PNG with the lower 8 bits and can
combine afterwards using external tools.
Date: 12 Jan 2011 08:35:01
Message: <web.4d2dad85f56ed354a8dd583f0@news.povray.org>
Thanks for the advice !
I adapted your second solution and wrote an RGB image and used the three R G B
fields to put the three "bits" of my sampling so that my distance is :
It seems to be working fine and my precision went from 256 grays to over 16
millions grays, which is quite enough :)
I other have more elegant solutions to change the output format of save_file,
feel free to help ;)
