POV-Ray : Newsgroups : povray.unofficial.patches : f_output_depth non-linear - but what? Server Time
17 Nov 2025 10:33:33 EST (-0500)
  f_output_depth non-linear - but what? (Message 1 to 4 of 4)
Subject: f_output_depth non-linear - but what?
Date: 21 Sep 2009 05:45:00
Message: <web.4ab74a31bf54fa92ea2377910@news.povray.org>
I've been trying to get depth information from a scene using both the raw
f_output_depth feature as well as the PP_Depth macro. Here are some of the
samples:
Actual depth      pixel value
25                     35
50                     53
100                    72
150                    88
This is based on using a depth range of 0->1500
This is obviously non-linear - but not referenced anywhere in the documentation
and I can't find it via google. Does anyone know how the conversion from the
actual distance from the camera to the object is converted into a value in
f_output_depth???
Subject: Re: f_output_depth non-linear - but what?
Date: 21 Sep 2009 09:25:01
Message: <web.4ab77dd35c107e41ea2377910@news.povray.org>
> samples:
> 25                     35
> 50                     53
> 100                    72
> 150                    88
> f_output_depth???
After many, many hours of pouring through the source code for both POV and
megaPOV I found it - bloody gamma correction. Don't know if it's a bug but it
would be nice to turn it off in post-processing somehow.
x' = 255* (x/max)^ (1/gamma)
assuming that min_dist=0.
You can pre-correct for it by using something like:
post_process {
    function { pow(f_output_depth(x,y)/depth_max_disp,2.2) }
    function { 1 }
    save_file "depth.bmp"
Date: 21 Sep 2009 10:15:42
Message: <4ab78a8e$1@news.povray.org>
How about the assumed_gamma and Display_Gamma settings, or the
Gamma_Correct() macro?
Date: 21 Sep 2009 20:35:01
Message: <web.4ab818ae5c107e41ea2377910@news.povray.org>
Thanks for the suggestion. Ideally I'd like to have gamma correction for the
colour image, but disable it for the depth image. I guess I could render them
separately with and without gamma but the above works fine.
It may be worth putting a sentence in the documentation about gamma correction
affecting the depth output in post processing because to me at least this is not
obvious.
