Subject: Re: MCPov web page (montecarlo path tracing patch)
Date: 13 May 2008 11:51:03
Message: <4829b8e7@news.povray.org>
"triple_r" <nomail@nomail> wrote in message
news:web.4829b8336f09fee62a82b8e90@news.povray.org...
> "Zeger Knaepen" <zeg### [at] povplace com> wrote:
>> there seems to be an error with png-output, I get ridiculously large
>> files
>> (a 64x64 rendering of the cornell-box gives me a 65MB png, or a 13KB
>> BMP),
>> and after a few iterations (ranging from 10 to 300, so far), I get the
>> error-message:
> That's the same thing I get, but I think the answer is just that png
> output is
> not really supported yet. Since it renders in passes, the BMP output has
> been
> altered so it overwrites the image, rather than appending. Solution? Use
> BMP
> for now?
yep, that's the solutions I'm using at the moment :)
cu!
_(0x+y.5+y/2x)_(0x-y.5+y/2x) // ZK http://www.povplace.com
Date: 13 May 2008 13:13:48
Message: <4829cc4c$1@news.povray.org>
continuing a trace ( +c ) doesn't work apparently
cu!
> > there seems to be an error with png-output, I get ridiculously large files
> > (a 64x64 rendering of the cornell-box gives me a 65MB png, or a 13KB BMP),
> > error-message:
> That's the same thing I get, but I think the answer is just that png output is
> not really supported yet. Since it renders in passes, the BMP output has been
> altered so it overwrites the image, rather than appending. Solution? Use BMP
> for now?
> - Ricky
Thanks Ricky, It is exactly the problem, only bmp format is supported. I thank I
will do in an other way : instead of wrapping the rendering (and changing source
dependant of the plateform), I will rename the file of the previous pass and
create a new one. Code should be in this case plateform independant.
Fidos
> > > error-message:
> > for now?
> > - Ricky
> Fidos
Modification done. It works fine. I tested on Windows and Linux Debian 4.0r1 (I
think that on MAC OS X it should be the same because I had the same compilation
error than Ricky).
Fidos
Hello,
I put in line (http://pagesperso-orange.fr/fidos/MCPov/MCPov.html) the version
0.0.2 of MCPov patch :
- it compiles now correctly under Linux.
- It uses a fast high-quality RNG as provided by Wrap.
Any feedback wellcome.
Fidos.
Date: 16 May 2008 01:56:29
Message: <482d220c@news.povray.org>
Who?-)
(Btw, it would be interesting to see some side-by-side comparisons,
to see if there's any visual or rendertime differences compared to the
older version.)
> Who?-)
Oops, sorry for the big mistake.
> older version.)
I know that there is only a slight rendertime improvement.
But there is a visual difference. I'm rendering the office of Jaime Vives
Piqueres and it is less bright and the overall result is quite good.
Fidos
Date: 16 May 2008 15:01:35
Message: <482dda0f@news.povray.org>
> > Who?-)
Anyways, the original RNG algorithm (and implementation) is by
Bob Jenkins, if you want to give proper credit. (I just wrapped his
code into an easy-to-use C++ class.)
> So here's a question at least. Is there a reason the following scene renders so
> differently with the three different options? Cases one and three produce the
> smooth focal blur I would expect, but case 2 produces a sharp cutoff. I have
> tried to boil this down to the simplest scene that causes unexpected behavior,
> but I just can't see what the problem is.
I found the reason. It was a bug... Because I change the origin of the camera
with dof on, the vista buffer return a wrong object intersection. I will make a
new release. Thank you for your testing infos.
Fidos
Hello,
Version 0.0.3 of MCPov is released
(http://pagesperso-orange.fr/fidos/MCPov/MCPov.html) :
- bugfix : sometimes wrong results when depth of feild is activated.
- bugfix : wrong results if a CSG object is defined as portal.
- bugfix : segmentation fault if the mc_sky keyword is used in a CSG object.
- bugfix : wrong results with mc_sky.
- Max grid dimension for sky is now 1000 (instead of 100).
Any comments wellcome.
Fidos.
