POV-Ray : Newsgroups : povray.unofficial.patches : MCPov web page (montecarlo path tracing patch) Server Time
29 Apr 2024 21:27:41 EDT (-0400)
  MCPov web page (montecarlo path tracing patch) (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: MCPov web page (montecarlo path tracing patch)
Date: 13 May 2008 11:51:03
Message: <4829b8e7@news.povray.org>
"triple_r" <nomail@nomail> wrote in message
news:web.4829b8336f09fee62a82b8e90@news.povray.org...
> "Zeger Knaepen" <zeg### [at] povplacecom> wrote:
>> there seems to be an error with png-output, I get ridiculously large
>> files
>> (a 64x64 rendering of the cornell-box gives me a 65MB png, or a 13KB
>> BMP),
>> and after a few iterations (ranging from 10 to 300, so far), I get the
>> error-message:
> That's the same thing I get, but I think the answer is just that png
> output is
> not really supported yet.  Since it renders in passes, the BMP output has
> been
> altered so it overwrites the image, rather than appending.  Solution?  Use
> BMP
> for now?
yep, that's the solutions I'm using at the moment :)
cu!
Date: 13 May 2008 13:13:48
Message: <4829cc4c$1@news.povray.org>
continuing a trace ( +c ) doesn't work apparently
cu!
Date: 13 May 2008 14:05:00
Message: <web.4829d7266f09fee6d93b772e0@news.povray.org>
> > there seems to be an error with png-output, I get ridiculously large files
> > (a 64x64 rendering of the cornell-box gives me a 65MB png, or a 13KB BMP),
> > error-message:
> That's the same thing I get, but I think the answer is just that png output is
> not really supported yet.  Since it renders in passes, the BMP output has been
> altered so it overwrites the image, rather than appending.  Solution?  Use BMP
> for now?
>  - Ricky
Thanks Ricky, It is exactly the problem, only bmp format is supported. I thank I
will do in an other way : instead of wrapping the rendering (and changing source
dependant of the plateform), I will rename the file of the previous pass and
create a new one. Code should be in this case plateform independant.
Fidos
Date: 13 May 2008 16:15:00
Message: <web.4829f6046f09fee6d93b772e0@news.povray.org>
> > > error-message:
> > for now?
> >  - Ricky
> Fidos
Modification done. It works fine. I tested on Windows and Linux Debian 4.0r1 (I
think that on MAC OS X it should be the same because I had the same compilation
error than Ricky).
Fidos
Date: 15 May 2008 16:10:01
Message: <web.482c98626f09fee6c7085b890@news.povray.org>
Hello,
I put in line (http://pagesperso-orange.fr/fidos/MCPov/MCPov.html) the version
0.0.2 of MCPov patch :
- it compiles now correctly under Linux.
- It uses a fast high-quality RNG as provided by Wrap.
Any feedback wellcome.
Fidos.
Date: 16 May 2008 01:56:29
Message: <482d220c@news.povray.org>
  Who?-)
  (Btw, it would be interesting to see some side-by-side comparisons,
to see if there's any visual or rendertime differences compared to the
older version.)
Date: 16 May 2008 14:55:01
Message: <web.482dd76c6f09fee6daee8acf0@news.povray.org>
>   Who?-)
Oops, sorry for the big mistake.
> older version.)
I know that there is only a slight rendertime improvement.
But there is a visual difference. I'm rendering the office of Jaime Vives
Piqueres and it is less bright and the overall result is quite good.
Fidos
Date: 16 May 2008 15:01:35
Message: <482dda0f@news.povray.org>
> >   Who?-)
  Anyways, the original RNG algorithm (and implementation) is by
Bob Jenkins, if you want to give proper credit. (I just wrapped his
code into an easy-to-use C++ class.)
Date: 17 May 2008 09:25:01
Message: <web.482edc0b6f09fee64b13a0080@news.povray.org>
> So here's a question at least.  Is there a reason the following scene renders so
> differently with the three different options?  Cases one and three produce the
> smooth focal blur I would expect, but case 2 produces a sharp cutoff.  I have
> tried to boil this down to the simplest scene that causes unexpected behavior,
> but I just can't see what the problem is.
I found the reason. It was a bug... Because I change the origin of the camera
with dof on, the vista buffer return a wrong object intersection. I will make a
new release. Thank you for your testing infos.
Fidos
Date: 18 May 2008 10:40:00
Message: <web.48303eb76f09fee6eec318de0@news.povray.org>
Hello,
Version 0.0.3 of MCPov is released
(http://pagesperso-orange.fr/fidos/MCPov/MCPov.html) :
- bugfix : sometimes wrong results when depth of feild is activated.
- bugfix : wrong results if a CSG object is defined as portal.
- bugfix : segmentation fault if the mc_sky keyword is used in a CSG object.
- bugfix : wrong results with mc_sky.
- Max grid dimension for sky is now 1000 (instead of 100).
Any comments wellcome.
Fidos.
