POV-Ray : Newsgroups : povray.unofficial.patches : PostProcess Output Options Server Time
15 Sep 2025 23:16:56 EDT (-0400)
  PostProcess Output Options (Message 1 to 3 of 3)
Subject: PostProcess Output Options
Date: 20 Jan 2006 13:05:00
Message: <web.43d125a1e29582134250940@news.povray.org>
hi folks,
I have been using megapov for a few days. Specifically, i am interested in
extracting the Intersection points using the post process options in
megapov. The code that i use was a hack of some samples available on the
net. I have attached it below.
#version unofficial MegaPov 1.2;
#include "pprocess.inc"
PP_Init_IPoint_Outputs()
        global_settings {max_trace_level 5}
global_settings {
  post_process {
    function { f_output_ipoint_x(u,v) }   // calculation of red component
    function { f_output_ipoint_y(u,v) }   // calculation of green component
    function { f_output_ipoint_z(u,v) }   // calculation of blue component
    function { 1 }   // calculation of transperancy component
    save_file concat("pp_",output_filename(0))
The code works fine ... but the output is written to BMP, this doesn't allow
for negative values to be dumped (these are clipped to zero) and values
higher than 255 are also cutoff.
IS THERE a way to dump the Ipoint information in a ascii file ... any
suggestions/pointers on how to go about extracting the information ? I
appreciate any help in this. Thanks in advance.
some background info: I am using XP with the latest stable version of PovRay
and Megapov ...
Aswin
Subject: Re: PostProcess Output Options
Date: 20 Jan 2006 14:28:12
Message: <lce2t15foiibqimdhkc0fvtvu6he053bmq@4ax.com>
Yes, you don't post process for it. Just loop over trace() function within
script should be enough. HTH,
ABX
Date: 20 Jan 2006 15:50:00
Message: <web.43d14c64b413b63f4c8b947b0@news.povray.org>
> ABX
Thanks for the pointer. Trace() definitely seems to be one possible way of
doing it .. although a bit tricky to register the ray orientations with
those used for rendering the image, as I would need information about the
focal length etc ...
Still, it seems to be a possible approach. Thanks.
