POV-Ray : Newsgroups : povray.unofficial.patches : MPI Patch for Povray 3.5/3.6 Server Time
31 Oct 2024 19:29:33 EDT (-0400)
  MPI Patch for Povray 3.5/3.6 (Message 1 to 6 of 6)
Subject: MPI Patch for Povray 3.5/3.6
Date: 14 Jun 2005 04:05:02
Message: <web.42ae8ed980c984bb9b2f6e300@news.povray.org>
I would like to know if there any MPI Patch for Povray 3.5/3.6 now?
Another question, is the .pov/.ini file of Povray 3.5/3.6 very different
from that of 3.1g? Is there any method to convert the 3.5/3.6 .pov/.ini
file to use on 3.1g?
Best regards,
John Lau
Subject: Re: MPI Patch for Povray 3.5/3.6
Date: 14 Jun 2005 10:56:19
Message: <Xns9675AC4F8933Cseed7@news.povray.org>
No, you can run almost any 3.1g file under 3.5/6. It may be though that in
some occasions the results differ a bit. Check out the #version feature in
the docs.
Ingo
Date: 15 Jun 2005 23:15:01
Message: <web.42b0eea973c591cd9b2f6e300@news.povray.org>
> the docs.
> Ingo
So, can I run 3.5/6 file under 3.1g? If I don't want any new features in
3.5/6?
John
Date: 16 Jun 2005 02:40:01
Message: <web.42b11e5e73c591cd95447d740@news.povray.org>
> 3.5/6?
POV-Ray files are *text* files!  If you had just looked into a POV-Ray file
or any POV-Ray related website you would have known. You should really read
the user manual.
Date: 16 Jun 2005 04:32:14
Message: <Xns96776B31E92B4seed7@news.povray.org>
> 3.5/6?
You can try. POV-Ray will generate errors when it doesn't like the code
and you can change it to what 3.1 accepts. In the 3.5 documentation was a
list with changes that can help you predict what will work an what not.
Ingo
Date: 16 Jun 2005 21:26:30
Message: <42b226c6$1@news.povray.org>
>>3.5/6?
> the user manual.
It is not unreasonable to assume the language might not be backwards
compatible.
