POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV getting final frame (mech) Server Time
14 Dec 2025 08:59:53 EST (-0500)
  MegaPOV getting final frame (mech) (Message 1 to 3 of 3)
Subject: MegaPOV getting final frame (mech)
Date: 8 Apr 2005 21:55:00
Message: <web.425735a286bd592e6dccdb020@news.povray.org>
Hiya,
I'm really new to MegaPOV, and I have some trouble understanding how to get
the mechism thingie to work as I want it to ;-)
For example, using the cloth.pov sample, is there a way to generate the
final image (or an arbitrary frame) without having to render all previous
images between the first and the last?
I've tried by tweaking the step_count and time_step parameters (and to be
honest I find it hard to figure out exactly what they do), tried by setting
up the .ini so only 2 frames are generated, but still no luck.
Is there a way to let the mechism do its simulation/iteration/whatever in a
single render only? Ive noticed that tweaking the step_count / time_step
doesn't affect much when Im not animating (but then, as mentioned, I havent
really grasped what to expect from them)...
Any help/tips is appreciated.
Thanks
/Per
Subject: Re: MegaPOV getting final frame (mech)
Date: 9 Apr 2005 06:10:01
Message: <web.4257a952e92dd31a8399d8d0@news.povray.org>
"PerFnurt" <per### [at] hotmailcom> wrote:
> Hiya,
if you have the saved simulation data: (*.dat)
render a still image(no animation) using this:
global_settings {
  mechsim {
    step_count 0 // disable simultion
    collision { off }
    topology {
      load_file "your_final_simulation_data.dat"
to simulate all the way to the final image, and then render the result:
set time_step as usual, and multiply step_count by the frame number you
want.
(step_count = the number of simulation steap between rendered frames.)
do the above while rendering a single frame animation.
(note: simulation will still take as long as simulating all separate frames
did before, it only saves the rendering time)
disadvantage:
-at least the windows GUI version has trouble stopping the simulation (can
 only be interrupted during actual rendering, witch you do after a long
time)
-no way to check if things are simulating as expected.
what i do:
render with really low resolution and no aa and cancel the animation at the
point i thing it has simulated what i need.
(you can rename the .dat file, to prevent overwriting it by accident)
then make a slightly changed pov file, (as above) to render the result in
hi-res, with radiosity/HDR, nice textures, etc.
(i also experimented with replacing simulated objects with pov objects)
http://jwstolk.afreehost.net/image.htm
hope this helps.
jaap.
Date: 9 Apr 2005 06:30:02
Message: <d38apa$853$1@chho.imagico.de>
PerFnurt wrote:
> Hiya,
As Jaap said you can generate the final image without *rendering* every
frame but not without simulating the whole time (this is nothing
specific to MegaPOV, it is inherent to any simulation like this).  So
you could do something like:
#if (clock_on)
   (insert the old simulation timing here)
#else
   step_count Frame_Count*Steps
   time_step ...
where 'Steps' is the old number of steps per frame and Frame_Count the
number of frames you want to simulate.
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
