POV-Ray : Newsgroups : povray.unofficial.patches : MechSim collision question Server Time
23 Dec 2025 17:40:33 EST (-0500)
  MechSim collision question (Message 1 to 8 of 8)
Subject: MechSim collision question
Date: 27 Mar 2005 18:20:00
Message: <web.42473ef5f1da215ca8399d8d0@news.povray.org>
i'm trying to drop some bolts onto a (growing) pile of bolts.
(each bolt is in a group{} )
http://jwstolk.afreehost.net/mechsim_problem.png
but:
collision { 0,0,2 ...} does not seem to work
(the connection-connection collisions do not happen.)
collision { 0,0,1 ...} also does not work.
collision { 1,1,1 ...} still does not do connection-connection collisions.
i'm using 80000 steps, witch very low speeds, so i don't think it will be
possible that the connections move past each other within a single step.
(face-connection collisions and face-face collisions also do not work,
but i think they are not supposed to work anyway)
is adding lot's of masses and then doing mass-face collisions the
only solution?
any suggestions?
Jaap.
Subject: Re: MechSim collision question
Date: 28 Mar 2005 02:00:13
Message: <d289rq$mbn$1@chho.imagico.de>
> but:
I am pretty sure collisions are calculated in all those cases although i
can't completely rule out an internal problem at the moment.  To
actually tell you why you think they don't occur i would need to see the
complete scene.
Note however that your topology is insufficient to accurately simulate
the movement of a bolt.  The approximation is simply too sparse.
Remember: the simulation works by calculating the forces from the
deformations of the bodies it simulates.  If the topology does not
actually deform in the way it would in reality this won't lead to
realistic results.
Where do the docs mention anything about face-face collisions or
face-connection collisions?  The don't exist and are not necessary either.
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
Date: 28 Mar 2005 02:45:00
Message: <web.4247b512452b02e1a8399d8d0@news.povray.org>
> complete scene.
http://jwstolk.afreehost.net/bolts_mechsim.pov.gz
it does not.
I removed group{}, changed bounding to 0 (off) and method to 0,
but that dit not help.
(interaction of bolts with the enviroment (floor) looks very nice!)
jaap
Date: 3 Apr 2005 06:15:02
Message: <d2ofkf$fo7$1@chho.imagico.de>
>>complete scene.
Sorry for the late reply.
You code does not even run with the current version (immediate
instability, did not check with 1.1 though).  Your models are simply way
too stiff (extremely small masses combined with high stiffness
connections).  You can make it run by changing this but will never get
reasonable movements with this topology.
So the way to go is create reasonable bolt shapes (with a reasonable
mass distribution) and make them soft enough (start with very soft and
increase stiffness until the look good enough, you will have to decrease
time stepping at the same time).  Start with one bolt and see if it
collides well with the environment.  Then add a second one and turn on
mass-mass and mass-face collisions, you probably do not even need the
con-con collisions.
Date: 3 Apr 2005 09:05:01
Message: <web.424fe9e0452b02e1a8399d8d0@news.povray.org>
i've been playing with lightSys+hcrEdit, which does kill time very well. :-)
-it does runs in 1.1, but yes, i had some stability problems.
-i will try with very soft connections.
-i know that the simulation will not be very realistic, for a
 start the mass is not distributed evenly threwout the bolt.
 I was actually only interested in the final result: a pile
 of (non-moving) bolts.
-i will add more masses along the thread of the bolt and add
 faces, and then do mass-face collisions. i guess the increase
 in number of masses will be compensated by a more stable
 simulation, which allows for larger time steps.
-i'm still wondering why the connection-connection collisions
 dit not work, even with near-instability the system should at
 least do something. is it possible that the connections end
 up with a zero radius, even if they are drawn with a large
 radius when rendered?
-i picked 3 (perpendicular) masses from the simulation and
 converted there position to a matrix, which positions the
 iso-surface bolts: http://jwstolk.afreehost.net/bolts_test.jpg
 (the bolt-head in the simulation was bigger, and the radius of
 the masses was not counted for, which leads to the "hovering")
jaap.
Date: 3 Apr 2005 09:20:06
Message: <d2oqeh$h2$1@chho.imagico.de>
No, the radius used in the simulation is taken from the masses the
connection connects.
Date: 3 Apr 2005 16:55:00
Message: <web.42505758452b02e1a8399d8d0@news.povray.org>
I'm simulating two M16x75 bolts (0.075m long),
each about 120 grams. 75 masses per bolt, about
1.5 grams per mass. All connections are generated
with the default length. I set stiffness to 750 and
dampening to 375, to keep deformations acceptable.
Everything works fine, but slow, because I need to set
time_step to 1/1400000 to prevent the instability warning.
From the source I understand that the warning is
generated when acceleration is more than 1e7. F=m*a so
there is a 10000 N force acting on (one of) my masses.
All of this is happening while by bolts are still
free-floating in mid-air. I never get an instability
warning during the rest of the simulation when the actual
collisions happen.
Can someone tell me more about what might course this
large force? Is it just that some masses are moved by
gravity, and are pulling in the not-yet-moved masses?
Can there be small rounding errors in the initial position
of the masses or the length of the connections?
The .DAT file seems to have sufficient deciaml places for
the mass length position and speed in my situation.
jaap
Date: 4 Apr 2005 03:13:43
Message: <4250E9F5.A36A64BA@gmx.de>
You have to understand what instability in a numerical simulation
means.  This is nothing about rounding errors or inaccuracy of math
operations.
If you start with very small time steps this won't lead you anywhere
since you will have to decrease them later anyway when you optimize the
simulation to look good.  So if your simulation is instable in the first
run don't use smaller time steps but modify the simulated system.
-- Christoph
