POV-Ray : Newsgroups : povray.unofficial.patches : Retaining persistent variables in MegaPov 1.0 Server Time
30 Mar 2026 20:00:56 EDT (-0400)
  Retaining persistent variables in MegaPov 1.0 (Message 14 to 23 of 23)
Subject: Re: Retaining persistent variables in MegaPov 1.0
Date: 10 Oct 2003 04:16:18
Message: <mkqcov04t6990qforfh55isegqsdrkgndr@4ax.com>
On Fri, 10 Oct 2003 09:28:07 +0200, Christoph Hormann
<chr### [at] gmxde> wrote:
>I agree.  You can also say #local implies a 'declare' -> 'to declare sth
>local(ly)'.  #persistant would be logical in the same way.
But I bet there are scourges of people who don't know how to spell
'persistent' correctly :)
Peter Popov ICQ : 15002700
Date: 10 Oct 2003 04:20:20
Message: <voqcovop8r8sg50p2126tng10on4vkdkeg@4ax.com>
Autocom [TAB] pletion
ABX
Date: 10 Oct 2003 04:33:32
Message: <3f866edc@news.povray.org>
  Is this the same kind of phenomenon as with "primative"?-)
Date: 10 Oct 2003 04:37:04
Message: <nj7i51-i87.ln1@triton.schunter.etc.tu-bs.de>
But don't blame me, Chris Huff made the same mistake.
I should really get a newsreader with builtin POV-SDL syntax
highlighting - of course it would not have helped in this case.
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 10 Oct 2003 10:37:40
Message: <cjameshuff-B7E359.10351610102003@netplex.aussie.org>
In article <Xns### [at] netplexaussieorg>,
 ingo <ing### [at] tagpovrayorg> wrote:
> You could make not just variables persistent but whole objects or scene
> sections.
Objects can be variables. The language should be able to take care of
anything else by using persistent variables. I think the goal of these
modules is more serialization and permanent storage of data, which would
require a pretty large amount of work to implement. It could be useful,
though...
http://tag.povray.org/
Date: 10 Oct 2003 10:47:05
Message: <cjameshuff-78F529.10444210102003@netplex.aussie.org>
In article <mkqcov04t6990qforfh55isegqsdrkgndr@4ax.com>,
Very good point.
Date: 10 Oct 2003 15:09:04
Message: <tk0eovg74nfrdtbf0ostivu2udaokkrqii@4ax.com>
On Fri, 10 Oct 2003 10:35:35 +0200, Christoph Hormann
Yeah but you're the one who proposes this horrendous syntax. Man, I
had to turn on the spell checker to make sure I wasn't making a fool
of myself... I guess it's as well that you didn't propose some
46-character German word for it :-)
/me ducks
Date: 10 Oct 2003 15:52:02
Message: <onej51-heh.ln1@triton.schunter.etc.tu-bs.de>
i
characters are also so nicely improving portability of script files...)
Of course we can also make it:
#merk_dir_das_und_vergiss_es_nicht_gleich_wieder
Date: 15 Oct 2003 14:50:48
Message: <3f8d9708@news.povray.org>
In C/C++ persistent external variables are declared as static.  Since static
is not a reserved word in POV (I checked) that should be the name of a
variable that persists from frame to frame in an animation:
#static Fwd = 203.4;
news:jtv### [at] tritonschunteretctu-bsde...
> sups wrote:
> > Hi ABX!
> > Thank you for both your replies. From your previous reply it was clear
that
> > persistent variables may not have made it to MP1.0. But in the manuals
of
> > MP1.0, nowhere it has been explicitly mentioned. Therefore I had the
> > slightest hope that this feature may be accesible in some other way. It
> > would be really nice to get this feature back since my code is not
> > compatible with MP0.7.
> It is not very likely that this will happen any time soon.  The
> persistence of variables patch was somewhat ugly and Nathan was probably
> the only one who really understood it.
> I would also prefer a different syntax for such a patch.  Like for
> example a new #persistent directive which works like #declare and #local
> but stores the data differently so it is not cleared after each frame.
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 15 Oct 2003 15:39:10
Message: <cjameshuff-AF6B4D.15365315102003@netplex.aussie.org>
In article <3f8d9708@news.povray.org>,
I think the static keyword is one of the worst misfeatures of C/C++.
Retained, indestructible, invariable, permanent, safe...I think
"persistent" is really the best word for this.
How about this: deprecate #declare, and have #global declare a global
persistent variable. Use #local to declare local variables, and #set to
modify existing variables. Most variables should be local anyway, except
for those in includes. This fixes several problems with the existing
system. If non-persistent global variables turn out to be useful often
enough, add something like #transient or #temporary to avoid the need to
undefine them. (I don't think this will be necessary.)
