POV-Ray : Newsgroups : povray.unofficial.patches : Your wanted features Server Time
25 Mar 2026 23:13:56 EDT (-0400)
  Your wanted features (Message 21 to 30 of 30)
Subject: Re: Your wanted features
Date: 19 Jun 2003 13:24:56
Message: <3ef1f1e8@news.povray.org>
> This may be useful for scanlining, but what I'm after is a method for
> generating meshes for general use.
Yeah, that's brutal. If a recursive dicer was used,
one would then have to merge small triangles
afterwards, basically a mesh LOD-reduction algorithm.
Granted the memory requirement can be steep, but
worst case is only for the primitive being diced,
and any persistent geometry afterwards is of the
optimized LOD form. If one used a bezier patch
instead of triangles as the atomic dicing unit,
the tesselation memory use would be worse but the
final optimized mesh would be more compact.
> ...It may not be
> necessary though...things like proximity and glow effects (two other
> things I plan to use tessellation with) may work fine with simple
> quick-and-dirty removal of triangles that are entirely contained in
> another object.
Entirely possible. The method is nice in having the
property of offering a fine-grained speed vs. quality distribution.
One need not be forced to compute a perfect CSG op every time.
> What I actually meant was: how are you tessellating and drawing the
> objects? Did you add an object method to draw in OpenGL, or one to
> tessellate to a mesh which is used by drawing code elsewhere? Or
> something else?
Each POV primitive has a wireframe method which emits
abstracted OpenGL calls (daylon_glBeginLineStrip, daylon_glVertex3dv, etc.).
The tesselation is done in a Wireframe_<primitive> routine
residing in the related module (spheres.cpp for spheres, etc.),
A primitive is considered a mesh of line strips along U and V axes,
and there is no retained geometry (for each line strip, vertices
are just baked up and issued and then discarded).
It's one of those lucky coincidences that POV's primitives'
Trans->matrix member happens to match the row/column order
and precision of OpenGL matrices; one can feed them directly to glMul().
Given how fortuitious that is, it almost seems criminal not
to integrate OpenGL. :)
I had some (currently disabled) code that captured bbox drawing to disk for
later display in Leveller, to test wireframe exports for interactive
scene navigation, but that's something running outside of POV-Ray,
or even at another time or on another machine. I thought of
embedding a scene navigator in the WinPOV GUI, but it might be
better (and more flexible) to just have it exec a navigation app.
You'd place the cursor within a camera statement, issue a
"render for nav" command, a scene wireframe file would be
generated with the camera block included, the navigator would be run,
and when it wrapped up it would update the cam in that file and
then WinPOV would tell CodeMax to replace the camera statement
with it (and perhaps optionally commenting out or #if(false)'ing
the old camera statement). Actually, the navigator would be better
as a DLL, since it can be hard to tell when another app has finished
running.
What gets kind of interesting is that a navigator DLL could
also double as a scene interaction previewer. For example,
you could implement a navigator that uses Quake-style walking/running,
and another that provides a flight-simulator point of view.
If you wanted to be really intense, a DLL could interpret
the wireframe (model) file as a game level, and let you
literally "play" that level on the spot. It means that the
POV SDL can be a game level modeler (among other things),
but why not? There's no reason the SDL has to be tightly
coupled to a particular rendering system. Once you have
a way to emit the geometry into something easier to parse
than SDL syntax, some neat possibilities become enabled.
Geometry emission is actually a whole other patch, but
it happens to be easy to do in the OpenGL patch as a side effect.
Normally one would just use a traditional modeler, but
the SDL is handy for those times when you want to quickly
make a bunch of objects procedurally, or you find
it easier to express an object with SDL than by drawing it.
You see scripting in modelers, even, like Rhino's textual
command line above its view windows, etc., but this would
let POV users leverage their SDL knowledge -- it's kind
of bothersome to have to learn a different language for
each app in the toolchain. If you had some SDL code that
did something clever, it's nice to be able to just take
that and deploy it to feed geometry to another app,
and let the computer handle the translation.
Ray
Date: 19 Jun 2003 17:15:10
Message: <3ef227de@news.povray.org>
Christopher James Huff <cja### [at] earthlinknet> wrote:
> One of the other things that needs to be done is to do clipping after
> the antialiasing. An extremely bright object should contribute more to a
> pixel than just a white one. However, because simple clipping is used,
> this makes super-bright objects appear unantialiased...
  A more (photo)realistic effect would be that this kind of ultrabright
spot bleeds brightness to the surrounding pixels.
  However, the algorithm for implementing this might not be trivial nor
fast...
Date: 19 Jun 2003 23:46:28
Message: <cjameshuff-10FDF0.22362719062003@netplex.aussie.org>
In article <3ef227de@news.povray.org>, Warp <war### [at] tagpovrayorg>
This would be more photorealistic than an ordinary antialiased image,
but is a separate effect from antialiasing.
> fast...
Actually, it was implemented as a post-process filter in the old
MegaPOV, and there has been quite a bit of discussion about it recently.
Basically, you make a blurred version of the image using the unclipped
values, and combine it with the unblurred version. The blurred version
simulates the light scattered within the eye (or camera film), the
unblurred version is the unscattered light, so you just weight them
appropriately and average them.
http://tag.povray.org/
Date: 20 Jun 2003 07:29:33
Message: <3ef2f01d@news.povray.org>
  Did it really use values >1.0 for calculating the soft glow?
Date: 20 Jun 2003 10:21:34
Message: <cjameshuff-974393.09112220062003@netplex.aussie.org>
In article <3ef2f01d@news.povray.org>, Warp <war### [at] tagpovrayorg>
I assume so...those values were available, it would only make sense to
use them. If not, there was another filter to load the unclipped colors
into the image buffer.
Date: 20 Jun 2003 11:06:53
Message: <cjameshuff-AD4D63.09564120062003@netplex.aussie.org>
In article <3ef1f1e8@news.povray.org>,
There are actually one or two constraints I would use with this
method...only triangles with maximum edge lengths and/or areas below a
certain threshold would be removed, triangles that are too big would be
subdivided and the same test used on their children. This should keep
the new triangle generation down to a reasonable level, while allowing
low triangle count meshes to be reasonably used.
Date: 20 Jun 2003 13:19:07
Message: <3ef3420b$1@news.povray.org>
Christopher James Huff wrote:
 > ...maybe even using ray differentials.
This would be a great feature because it would theoretically allow to
filter off high frequencies from pigments - like antialiased shaders do
in RenderMan Shader Language - making supersampling only necessary for
edges.
-sascha
Date: 23 Jun 2003 15:25:15
Message: <3ef7541b$1@news.povray.org>
"Rohan Bernett" <rox### [at] yahoocom> wrote in message
news:web.3edf5ebd7e2b69fbaa7c54710@news.povray.org...
> Let's make a nice big list of all the features people would like to see in
> an official/unofficial version of POVRay!
1) To be an ass and a non-team player,   I'll say    ^
2)  Is there some way to fix the specular to allow color-specific
highlights?
I'm thinking about a possible (and extremely simple) toon-shader just based
on a high specular finish.
See:  http://news.povray.org/3ef7334c%241%40news.povray.org
Date: 24 Jun 2003 18:48:34
Message: <cjameshuff-4306E0.17371424062003@netplex.aussie.org>
In article <3ef3420b$1@news.povray.org>,
> edges.
Yes...and a similar filtering could be used on the pigments to
strengthen small details. However, the pigments would still need to be
supersampled...it could just be done separately from edges. Maybe
something like this: sample the surface coverage, computing an average
location and normal for each surface hit by the pixel, and then compute
texturing once with that information and the ray footprint. It may be
too much work for the possible savings.
Date: 5 Jul 2003 03:23:40
Message: <3f067cfc@news.povray.org>
 > compute texturing once with that information and the ray footprint.
Sounds a bit like MIP-mapping to me. I once posted a question about
MIP-mapping to p.u.patches - it needs the surface derivatives too, but
Nathan Kopp postet a link to a paper about ray-differentials in
raytracing: http://graphics.stanford.edu/papers/trd/
-sascha
