POV-Ray : Newsgroups : povray.unofficial.patches : Megapov under Alpha Linux Server Time
27 Mar 2026 06:14:00 EDT (-0400)
  Megapov under Alpha Linux (Message 1 to 3 of 3)
Subject: Megapov under Alpha Linux
Date: 21 May 2001 16:12:32
Message: <3B0976AE.CD2636A7@club-internet.fr>
Hi everybody.
I have been contacted by a lucky user who has access to a 20x alpha
cluster running Linux, and is trying to make PvMegaPOV run on it.
He is facing some problems at parse-time (it seems to compile) which
seem strange to me:
> as soon as it reads a simple multiplication (1.25*y) it exits with '
> expecting }'
> Starting frame 0...
> stad [40007] reported:     pigment { FBM_Clouds }
> stad [40007] reported:     finish { ambient 1.0 diffuse 0 }
> stad [40007] reported: }
> stad [40007] reported: texture {                          // The darker
> underside of the clouds
> stad [40007] reported:     pigment { FBM_Clouds  translate -0.15* <----ERROR
> /home/maarten/povray31/include/textures.inc:335: error: stad [40007]
> reported: No matching } in pigment,stad [40007] reported:  * found instead.
Has anybody tried to run Megapov (or even better PvMegaPOV) under
alpha-Linux ? Could someone provide some feedback?
TIA.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Subject: Re: Megapov under Alpha Linux
Date: 28 May 2001 17:43:54
Message: <slrn9h5hj5.ph2.steve@zero-pps.localdomain>
On Mon, 21 May 2001 20:12:30 +0000, Francois Dispot wrote:
>Hi everybody.
>seem strange to me:
>> expecting }'
>> Starting frame 0...
Wow almost the exact same thing that happened over here today, but it
wasn't megapov that was the problem, I got that error by trying to
render skyvase.pov on Linux with Megapov 7 while using the +b1000 command
line option, when I took that option out it worked fine, maybe it's the
same problem over there.
 10:36pm  up 115 days, 23:25,  2 users,  load average: 1.79, 1.42, 1.25
Date: 31 May 2001 08:38:06
Message: <3B15F4DE.1FFC6A4C@mail.ourservers.net>
> >Hi everybody.
> >seem strange to me:
> >> expecting }'
> >> Starting frame 0...
I get the above error with MegaPOV v0.7 on OpenVMS Alpha if I try to use
the "+Mv2.0" setting.  If I leave that out, it compiles just fine with
all the
other options.
	$ megapovray +i skyvase.pov +v1 -d +ft -x +a0.300 +r3 +b1000
                     +w640 +h480
Works where..
                     +mV2.0 +w640 +h480
dosen't work and gives the above error.
 | Robert Alan Byer | bye### [at] mailourserversnet | ICQ #65926579 |
 | Send an E-mail request to obtain a copy of my PGP key.      |
 | "It is by caffeine alone I set my mind in motion.  It is by |
 |  cans of cola the thoughts aquire speed, the hands aquire   |
 |  shakes, the shakes become a warning.  It is by caffeine    |
 |  alone I set my mind in motion."                            |
