POV-Ray : Newsgroups : povray.unofficial.patches : Megapov error whith skyvase.pov Server Time
22 Mar 2026 16:12:01 EDT (-0400)
  Megapov error whith skyvase.pov (Message 1 to 10 of 14)
Subject: Megapov error whith skyvase.pov
Date: 28 May 2001 08:47:10
Message: <slrn9h4i44.nvj.steve@zero-pps.localdomain>
Hi all
When trying to render skyvase with megapov, versions:
3.1g.mp+.0.5a.0.2.5b (UniMegaPOVPlus 0.5a mod 0.2.5b).Linux.gcc
3.1g.mp.0.6.2 (mPov 0.6.2).Linux.gcc
3.1g.mp.0.7.0 (mPov 0.7.0).Linux.gcc
I get the error message:
Parsing.......    pigment { FBM_Clouds }
    finish { ambient 1.0 diffuse 0 }
texture {                          // The darker underside of the clouds
    pigment { FBM_Clouds  translate -0.15* <----ERROR
/usr/local/lib/povray31/include/textures.inc:335: error: No matching } in pigment, *
found
instead.
It renders fine (though slower than standard 3.1g), with version 3.1g.ump.0.4
(UniMegaPov
0.4).Linux.gcc.
This has all probably been discovered before, but I wan't aware of the problem
(whatever
it is).
  1:32pm  up 115 days, 14:21,  2 users,  load average: 1.07, 1.18, 1.24
Subject: Re: Megapov error whith skyvase.pov
Date: 28 May 2001 09:07:29
Message: <3B124E55.B3EE2B18@pacbell.net>
Steve wrote:
> Hi all
found
> instead.
(UniMegaPov
> 0.4).Linux.gcc.
(whatever
> it is).
My official version of skyvase does not have "pigment { FBM_Clouds }"
clouds anywhere in the file. You are probably using a custom version
of the file. Anyway you cannot have a finish statement, declared or
otherwise, within a pigment statement which would explain the error
message.
Ken Tyler
Date: 28 May 2001 10:48:35
Message: <slrn9h4p8b.oer.steve@zero-pps.localdomain>
* found
>> instead.
>message.
It renders fine in standard 3.1g, and no mention of { FBM_Clouds } in my
copy.  I've just rendered a scene with textures.inc included, but get no
errors.  Here is what FBM_Clouds looks like in textures.inc:
#declare FBM_Clouds =
    bozo
    turbulence 0.65
    octaves 6
    omega 0.7
    lambda 2
    color_map {
        [0.0 rgb 0.85]
        [0.1 rgb 0.75]
        [0.5 rgb 0.75]
        [0.5 rgbf <1,1,1,1>]
scale <6, 1, 6>
None of the textures/pigments called from textures.inc include this pigment.
  3:20pm  up 115 days, 16:09,  2 users,  load average: 1.18, 1.16, 1.10
Date: 28 May 2001 13:20:07
Message: <slrn9h524i.ool.steve@zero-pps.localdomain>
My Mistake.
It is to do with the command line option +b1000.  Really strange that I get
the error that I'm getting though and with varying results with different
POV/Mega versions.
  6:15pm  up 115 days, 19:03,  3 users,  load average: 1.95, 1.68, 1.50
Date: 29 May 2001 06:20:49
Message: <3b137801$1@news.povray.org>
Memory trouble perhaps.  Different compilations, different ways of handling
it, maybe explains something.
Bob H.
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
get
> POV/Mega versions.
Date: 29 May 2001 14:47:56
Message: <slrn9h7pvn.r6q.steve@zero-pps.localdomain>
>Bob H.
>get
>> POV/Mega versions.
I was unclear there, I meant some give me the error, and some don't.
  7:13pm  up 116 days, 20:01,  2 users,  load average: 1.26, 1.17, 1.11
Date: 29 May 2001 16:53:17
Message: <3b140c3d@news.povray.org>
In article <3b137801$1@news.povray.org> , "Bob H." <omn### [at] msncom>
Skyvase.pov only uses a few KB of memory, you could render it on a system
with one MB of RAM...
   Thorsten
Date: 29 May 2001 19:13:48
Message: <3b142d2c$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3b140c3d@news.povray.org...
handling
Yes, but couldn't the +b1000 throw a wrench into the works?  That's what I
was getting at anyway.  Obviously it is not a large number (1 MB) but I was
grasping at straws there, memory use flaw type thing.
Bob H.
Date: 30 May 2001 02:15:53
Message: <slrn9h8f7o.uvu.steve@zero-pps.localdomain>
I was thinking something on the same lines, but the error message is quite
spurious if that is the case.
  1:19am  up 117 days,  2:08,  2 users,  load average: 1.17, 1.11, 1.03
Date: 30 May 2001 03:26:56
Message: <3b14a0c0@news.povray.org>
In article <3b142d2c$1@news.povray.org> , "Bob H." <omn### [at] msncom>
No, it actually reduces memory use compared to say +b1 (a few bytes only in
skyvase.pov in either case).  You could set it to +b1000000 and it would not
require more memory than +b1000 in any case.
    Thorsten
e-mail: tho### [at] trfde
