POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV 0.5a renders only black if I stop part way through a render. Must restart. Hmmm Server Time
15 Jan 2026 09:42:18 EST (-0500)
  MegaPOV 0.5a renders only black if I stop part way through a render. Must restart. Hmmm (Message 1 to 3 of 3)
Subject: MegaPOV 0.5a renders only black if I stop part way through a render. Must restart. Hmmm
Date: 25 Jul 2000 08:07:07
Message: <e30rnsse3sj8g7gco0qenra7gd9p9c2rcf@4ax.com>
Hiya,
Any reason why megaPOV 0.5a will render only a black scene with some
of my POV files? Most render and re-render fine if I stop them part
way through a render. Some just show that they rendered completely but
are all black. I only found this with scenes containg radiosity and
photon mapping. When this happens, I have to end MegaPOV and
completely restart the program EVERY time. Also, I don't think the
comments would have anything to do with it. And the INC file has been
included in the scene file so there are no outside references to
mterials or objects. This only started happening when I started
getting more accurate with the radiosity and photon settings.
SPECS:	256mb SDRAM
	Win98SE/Win2000
	V3 3000 AGP
Thanks, and any help would be appreciated but not expected.
The following are the file contents:
//  Persistence of Vision Raytracer V3.1
//  World definition file.
//  Contains 1 lights, 6 materials and 9 primitives.
//  This file was generated for POV-Ray V3.1 by
//  Moray V3.2 For Windows Copyright (c) 1993-2000 Lutz + Kretzschmar
#version unofficial MegaPov 0.5;
//  Date : 07/19/2000    (19.07.2000)
  The text between these two comments is in MorayPOV.INC and is
  automatically included in all POV files that Moray exports.
default {
    pigment { rgb <1,0,0> }
/* // Scene Comment
This scene was created with Moray For Windows.
*/ // End Scene Comment
global_settings {
//  adc_bailout 0.003922
  ambient_light <0.0,0.0,0.0>
  assumed_gamma 1.9
  hf_gray_16 off
  irid_wavelength <0.247059,0.176471,0.137255>
  max_intersections 64    //  64
  max_trace_level 8   // 16
  number_of_waves 10
  radiosity{
    pretrace_start 0.08  // 0.04
    pretrace_end   0.04  // 0.02
    count 400            // CHANGE range from 20 to 150  (max is 1600)
400   200   75
    media  100             // -100
    nearest_count       3       // CHANGE range from 3 to 20  // 6  4
3  1
    error_bound         0.1     // CHANGE - range from 1 to 3   // 0.2
0.1  0.6
    recursion_limit     1       // CHANGE
//  distance_maximum    4.0    // 3.0
    low_error_factor    0.3     // leave this 0.2  0.8  0.3  0.1
    gray_threshold      0.0     // leave this   0.0
    minimum_reuse       0.015   // leave this 0.015 or 0.000  0.31
0.1 - blotchiness below 0.4
    brightness          2.0     // leave this   1.0
//    max_sample          -100.0
    adc_bailout 0.1/0   // CHANGE - use adc_bailout = 0.01 /
brightest_ambient_object  0.01/2   0.5/0
    normal on
    media on
    save_file "c01.rad"    //
//    load_file "c01.rad"
    always_sample on
        photons{
//        spacing 0.035         // 0.005   0.0075   0.0025   0.004
0.035
        gather 20, 100       // 20, 100
        autostop 0.01   //  //
 	radius 5.0            // 1.0   0.2
	expand_thresholds 100, 100   //
        count 300000     //   count 2000000 3000000   //
//        max_trace_level 12
        jitter 5.0       //   jitter 8.0  0.75  1.0  3.0
//        media 100 , 100
         save_file "c01.ph"      //
//       load_file "c01.ph"
      reflection_blur on
background { color <0.000,0.000,0.000> }
camera {  //  Camera StdCam
  location  <     -0.051,     -10.119,       0.651>
  sky       <    0.00000,     0.00000,     1.00000> // Use right
handed-system
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.36295,         0.0,         0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray)
aspect ratio
  angle         43.30465    // Vertical      32.478
  look_at   <     -0.028,       0.005,       0.111>
// *******  L I G H T S *******
light_source {   // Spotlight Spotlight001
  <0.0, 0.0, 0.0>
  color rgb <0.9, 0.9, 0.9>
  area_light <2.0, 0.000, 0.000>, <0.000, 2.0, 0.000>, 8, 8      /**/
  adaptive 2
  jitter
  spotlight
    point_at  <0.0, 0.0, -2.000>
    falloff    100.000  // outer radius (in deg)
    radius     45.000  // inner radius
    tightness  0.000
    fade_distance  3.3     //
    fade_power 2.0
    media_attenuation on
    scale <0.944956, 0.854249, 0.00001>
  translate  2.280531*z
    photons {
    global
    refraction on
    reflection on
    area_light    //
// ********  MATERIALS  *******
//  $MRY$: 'white light'
#declare white_light =
   material  // white light
      texture
         pigment
            color rgb <1.0, 1.0, 1.0>
         finish
            ambient 100.0
            diffuse 100.0
            brilliance 100.0
            phong 0.0
            phong_size 0.0
            specular 0.0
            roughness 0.0
//  $MRY$: 'glass_mat'
#declare glass_mat =
   material  // glass_mat
      texture
         pigment
            color rgbt <0.0, 0.0, 0.0, 1.0>
         finish
            ambient 0.0
            diffuse 1.0
            brilliance 0.0
/*            phong_size 0.0
          phong 0.0
            specular 0.0    */
            roughness 0.0
                reflection_type 1
                reflection_min 0.1      // 0.3  0.2  0.1  0.1  0.1
0.1
                reflection_max 0.1      // 0.1  0.5  0.6  0.5  0.2
0.1
      interior
         ior 1.66
    /*     caustics 1.0
         media
            emission rgbft <0.0, 0.0, 0.0, 0.0, 0.0>      //  <0.0,
0.0, 0.0, 1.0, 1.0>
//  $MRY$: 'chrome_mat'
#declare chrome_mat =
   material  // chrome_mat
      texture
         pigment
            color rgb <0.0, 0.0, 0.0>
         finish
            ambient 0.0
            diffuse 0.0
            brilliance 0.0
            phong_size 0.0
            roughness 0.0
            reflection 1.0
//  $MRY$: 'left_mat'
#declare left_mat =
   material  // left_mat
      texture
         pigment
            color rgb <0.937, 0.463, 0.463>
         finish
            ambient 0.0
            diffuse 1.0
            phong_size 0.0
            roughness 0.0
//  $MRY$: 'right_mat'
#declare right_mat =
   material  // right_mat
      texture
         pigment
            color rgb <0.474510, 0.439216, 0.74902>
         finish
            ambient 0.0
            diffuse 1.0
            phong_size 0.0
            roughness 0.0
//  $MRY$: 'walls_mat'
#declare walls_mat =
   material  // walls_mat
      texture
         pigment
            color rgb <0.729020,  0.729020,  0.729020>
         finish
            ambient 0.0
            diffuse 1.0
            phong_size 0.0
            roughness 0.0
// ********  REFERENCED OBJECTS  *******
// ********  OBJECTS  *******
box { // floor
  <-1, -1, -1>, <1, 1, 1>
  material {
    walls_mat
  scale <0.000507, 4.448451, 2.801902>
  rotate -90.0*y
  translate  <0.0, 0.0, -2.27461>
box { // top
  material {
    walls_mat
  rotate -90.0*y
  translate  <-0.014077, 0.0, 2.28461>
box { // rightwall
  material {
    right_mat
  scale <0.000507, 4.448451, 2.295117>
  translate  <2.77324, 0.0, 0.014077>
box { // backwall
  material {
    walls_mat
  scale <0.000507, 2.8014, 2.295117>
  rotate 90.0*z
  translate  <-0.014077, 4.42146, 0.014077>
box { // leftwall
  material {
    left_mat
  translate  <-2.801395, 0.0, 0.014077>
box { // lightbox
  material {
    white_light
  translate  <-0.032521, 0.943114, 2.280532>
sphere { // glass
  <0,0,0>,1
  material {
    glass_mat
  scale 0.9
  translate  <1.306932, 0.602898, -1.416993>
  photons {
	target 1.0
    refraction on
    reflection on
    //ignore_photons
sphere { // chrome
  <0,0,0>,1
  material {
    chrome_mat
  scale 0.9
  translate  <-1.354372, 2.131973, -1.402916>
  photons {
	target 1.0
    refraction off
    reflection on
    //ignore_photons
Subject: Re: MegaPOV 0.5a renders only black if I stop part way through a render. Must restart. Hmmm
Date: 25 Jul 2000 10:24:02
Message: <397DA355.45B2B001@videotron.ca>
Spaztic wrote:
> Hiya,
> SPECS:  256mb SDRAM
>         Win98SE/Win2000
>         V3 3000 AGP
POVRay doesn't care about your V3: 3dfx doesn't give any raytracing
abilities to their 3D cards 8)
What's your Processor? What OS are you using when it happens, etc?
I'm sure it'll help more than knowing you have a V3(i'm getting a Ge
Force 256 8p~~)
[snip]
AKA paul_virak_khuong at yahoo.com, pkhuong at deja.com, pkhuong at
crosswinds.net and pkhuong at technologist.com(list not complete)...
Date: 25 Jul 2000 12:20:00
Message: <mafrnscui2pcpvhevkuua3ruuah93d37cf@4ax.com>
Adden:
My specs are:
256mb SDRAM
P3 450
Win98SE/Win2K
PS. This strange occurance is happening in both OSs. And with only
some POV files. All my files contain photon mapping and radiosity
code, but only some will re-render without restarting MegaPOV.
Thanks again
On Tue, 25 Jul 2000 10:25:25 -0400, pk <thi### [at] videotronca> wrote:
>Spaztic wrote:
>> Hiya,
>> SPECS:  256mb SDRAM
>>         Win98SE/Win2000
>>         V3 3000 AGP
>Force 256 8p~~)
>[snip]
