POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV test versions for problems with 1.2 Windows built Server Time
29 May 2024 04:58:30 EDT (-0400)
  MegaPOV test versions for problems with 1.2 Windows built (Message 1 to 3 of 3)
Subject: MegaPOV test versions for problems with 1.2 Windows built
Date: 20 Jul 2005 12:20:02
Message: <dbltfu$c7p$1@chho.imagico.de>
Because of the problems observed with the Windows built of MegaPOV 1.2
we have prepared a test built with MinGW you can find on:
http://megapov.inetart.net/megapov-1.2-windows-test.zip
(This is not a complete package, you need the normal WinMegaPOV package
in addition)
That built also contains a fix for the problem with the mechsim patch
(which is not Windows specific) but is mainly intended to test for the
Windows specific problems.  If you had troubles with the old version you
should test this and report if the problems are not solved.  Note this
version will run slower in most cases.
http://www.tu-bs.de/~y0013390/ (Last updated 01 Jul. 2005)
Subject: Re: MegaPOV test versions for problems with 1.2 Windows built
Date: 21 Jul 2005 10:40:02
Message: <42dfb3c2$1@news.povray.org>
The following example stops with an 'invalid page fault'
After "Generating Grid...Done"
#version unofficial megapov 1.2;
#include "mechsim.inc"
global_settings{
  mechsim{
    method 1
    bounding 0
    gravity <0,0,0>
    time_step 0.1
    step_count 10
    topology{
      MechSim_Generate_Block(
        <0, 0, 0>, 0.08, 20, 1000, 2000,true,
        <0, 0, 0>, <1, 1, 1>, <4, 4, 4>, No_Trans, 3
    } // end topology
  } // end mechsim
} // end global_settings
MechSim_Show_Objects(0, 0, 0, -1, -1, -1, -1, false, -1, "")
Can someone else confirm this?
Changing the time_step to 0.001 as previously suggested does not help.
Trying different values of time_step/step_count/gravity, it failed in module
MSVCRT.dll or KERNEL32.dll
Win 98 se
AMD Athlon XP 2200+  256mb
The included demo scene 'blocks.pov' in the full distribution, did not run
correctly with the suggested command line settings (same picture on every
frame). Changing line 93 form ' save_file "blocks1.dat" ' to ' save_file
"blocks.dat" ' gave me the expected sequence. Making this change the file
did not run on MegaPov 1.2 but does on MegaPov 1.2.1test.
The newer version works better on my system (blocks.pov), but still fails on
my test scene.
Date: 21 Jul 2005 13:00:02
Message: <dbok8k$a9s$1@chho.imagico.de>
Yes, changes related to mechsim are incomplete - this version will crash
on all mechsim scenes using method 1. :-(
> Win 98 se
Yes, blocks.pov uses method 2 and therefore works (apart from the typo).
