POV-Ray : Newsgroups : povray.unofficial.patches : blob2 Server Time
16 Apr 2026 11:41:39 EDT (-0400)
  blob2 (Message 15 to 24 of 34)
Subject: Re: blob2 patch now available
Date: 19 Jul 2003 15:12:25
Message: <Xns93BD9A8864CF9tomatimporg@204.213.191.226>
Christopher James Huff <cja### [at] earthlinknet> wrote in
news:cja### [at] netplexaussieorg:
> It is really true, installing from source is a matter of typing a
> slightly different command at a terminal.
Assuming that the compile is successful, assuming that dependencies are
local and the correct version, assuming that the user knows what a compiler
is, assuming that a complier is even installed on the system....
Date: 20 Jul 2003 07:20:56
Message: <3F1A7B17.DD5DBD0D@gmx.de>
Christopher James Huff wrote:
> [some more explanations]
Well, it looks like a good start.  Illustrate it with some images, some
diagrams and formulas of the falloff functions, some render times for
comparison, a syntax summary and you already have a quite helpful addition
for the user.
> Isosurfaces: the main advantage is that it is faster. It uses
> optimizations that can't be done in even a hard-coded isosurface
> function. For example, it collects the components that influence a ray,
> and uses only those when searching for the intersection. If you have a
> blob2 with hundreds of components, but only two components affect the
> current intersection being tested, only those two components will get
> evaluated.
Well, in functions you could do the same on a point basis instead of ray
basis and add some caching if the next point is near the old one.  Surely
it will be slower but as i said having it in isosurfaces would also have
some serious advantages.
Note that handcoded isosurface functions for blobbing or CSGing many
components scale extremely badly, even if an internal function for this
would not be as fast as your new shape it would be ways faster than the
manual approach.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 20 Jul 2003 10:32:24
Message: <cjameshuff-FF840C.09255620072003@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
If someone can install the official command line version (which is
needed anyway before doing this), the dependencies are already taken
care of. A binary install would involve more time and work for
assembling and testing, and for very little benefit, especially
considering the level of interest I'm seeing.
http://tag.povray.org/
Date: 20 Jul 2003 10:55:45
Message: <cjameshuff-778A9A.09491620072003@netplex.aussie.org>
In article <3F1A7B17.DD5DBD0D@gmx.de>,
> for the user.
Demanding, aren't we?
Considering the lack of interest I'm seeing in this, I'm putting this
patch on the backburner, there won't be another MP+ release until I have
more patches moved over. When that happens, there will be documentation
of the syntax and some more sample scenes, and the documentation of the
source code will be improved. In the meantime, I have other projects I
need to attend to first.
Caching is useless here...at least, I see no way of applying it that
doesn't just add overhead. And without ray info, you can't do the same
thing. The point of doing it on a per-ray basis is that you can take a
fairly expensive computation (the bounds test/component collection
stage) and use it to optimize a large number of expensive computations
(all the point evaluations needed to find the intersections with the
ray) that would otherwise be many times the first calculation. Drop that
and you're back to looking at every single component for every point
evaluated. You could still derive some benefit from a heirarchial
bounding scheme, but so could the existing algorithm.
There will be a blob2 pattern. This will not be able to use these
optimizations either, but like any other pattern, you will be able to
use it in isosurfaces. But I have good reasons for not doing it this way
for the blob2 primitive.
> manual approach.
By scaling, you appear to mean performance with increasing numbers of
components...removing these optimizations would make the order of the
algorithm equal to hand coded functions, performance would deteriorate
linearly as number of components increases. You would only get the
benefits of compiled functions. (plus the fact that the functions
themselves are more optimized)
Date: 20 Jul 2003 11:05:31
Message: <3F1AAFBB.217DC3B7@gmx.de>
> > for the user.
I'd rather say suggesting.  If you don't want to go this way i won't urge
you but you were the one who wondered about the lack of interest.
Date: 20 Jul 2003 12:49:56
Message: <Xns93BE8260F1228tomatimporg@204.213.191.226>
I used the official binary for my Redhat linux box.  I don't want you to
make a binary for me.  I am capable of getting it running, but I don't have
the time to play with it.  I am just giving you the user perspective.
Date: 20 Jul 2003 14:47:17
Message: <MPG.198490c524cd528098983d@news.povray.org>
In article <cja### [at] netplexaussieorg>,
cja### [at] earthlinknet says...
I think it sounds interesting and more useful that the current blob
system, but then I am one of the people that refuses to compile this sort
of thing myself. I don't do that sort of thing often, I have had bad
experiences with stuff that the authors claimed was 'all ready, just type
blah... and it will work', I don't trust my system to not have dependency
problems that being Windows I might have a snowball's chance in hell of
fixing properly. For me, it is either a working patched version of the
binary or nothing. I suspect others feel much the same.
I also believe that as much documentation as possible is a necessity. One
reason I don't try to compile my own versions is that I don't know C very
well and the POV source looks like bloody greek to me. I have neither the
time nor the patience to wander through pages of someone else's code
trying to figure out what the hell it does, because the designer doesn't
document it or the use of its features completely. You may consider it a
waste of time, but if you aim for the lowest common denominator (the
people that haven't a single clue what is going on), then no one will be
cursing you for it. If you instead assume that everyone that will use it
has nearly the same knowledge you do, then even your equals will curse
your name for not giving a better explanation of what 'you' chose to do,
because 'they' would might have done it completely differently.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 22 Jul 2003 18:04:11
Message: <3f1db4da@news.povray.org>
> Was I wrong in thinking there were people interested in this?
> It's odd, there've been other threads about improving the blob object,
> exponential blobs, etc. But now that there's an actual working patch
> fixing several of these problems, there's not even a hint of interest?
Well, I was actually waiting for someone to come up with a better
blob because each time I model some blob object, I was unhappy with
these somewhat ugly lines caused by the linear falloff function.
I was happy when I read that you released you patch finally but
after seeing that I'd have to download more than 1Mb with my
slow modem, I decided to wait for the next MegaPov version...
So really, there _are_ people who are interested in the blob2
and if it is faster than isosurface, I'd apreciate that much because
rendering time is an issue for animations.
Wolfgang
Date: 22 Jul 2003 20:18:54
Message: <cjameshuff-752CEB.19115822072003@netplex.aussie.org>
In article <3f1db4da@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
This seems to be a common misconception...the blob falloff function is
not linear. The function given in the documentation is:
strength*(1 - (distance/radius)^2)^2
The problem is that it has non-0 second derivative when distance/radius
equals 0, which is at the very edges of the blob components where the
function gets chopped off. Because of this, while the surface is
continuous, it has abrupt changes in curvature. The function I used for
the blob2 object is:
((6*r - 15)*r + 10)*r*r*r
which is equivalent to:
6*r^5 - 15*r^4 + 10*r^3
with r = distance/radius in the first equation. It has a second
derivative which is 0 at r = 1, and seems to give a more fluid, less
chunky looking shape as well. This function actually comes from a recent
update to the Perlin noise algorithm which fixed a similar problem that
resulted in grid artifacts.
Date: 22 Jul 2003 22:32:44
Message: <3f1df3cc@news.povray.org>
If you want to raise interest, SHOW PICTURES to the public, in pbi.
Within a few days, many people will show interest, and as soon as
someone decides to compile a Windows (the most widely used platform
for POV-Ray, simply) binary, these many people will actually
be USING the patch.
Fabien.
