POV-Ray : Newsgroups : povray.unofficial.patches : Inverse Transformations patch Server Time
25 Dec 2025 22:17:07 EST (-0500)
  Inverse Transformations patch (Message 1 to 10 of 17)
Subject: Inverse Transformations patch
Date: 24 Apr 2000 20:31:17
Message: <chrishuff_99-C97FE1.19341424042000@news.povray.org>
I just finished testing my latest patch, which adds inverse transforms
to objects, textures, and anything else that can take a transform. The
syntax is very simple, just add "inverse" in the transform {} block.
#declare Trans =
transform {
#declare InvTrans =
transform {Trans inverse}
Applying "transform Trans" will transform something, applying "transform
InvTrans" will "undo" those transforms.
I added the patch in the MegaPOV 0.4 code, it only requires modifying
the function "Parse_Transform" in parse.c.
TRANSFORM *Parse_Transform ()
   VECTOR Local_Vector;
+   int isInverse = FALSE;
   EXPECT
+     CASE(INVERSE_TOKEN)
+       isInverse = TRUE;
+     END_CASE
   Parse_End ();
+   if(isInverse == TRUE)
+       MInvers(New->matrix, New->matrix);
+       MInvers(New->inverse, New->inverse);
   return (New);
This brings up the next issue: this requires that the transformation be
declared before inverse can be used. I think transform {...} blocks
should be allowed within objects, so you could use:
object {
    transform {
        blah, blah
instead of this:
#declare Trans =
transform {
    blah, blah
object {
    transform Trans
And of course, you should be able to "concatenate" transforms with
multiple transform {...} blocks. I will be working on this to see how
hard it will be to implement.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Subject: Re: Inverse Transformations patch
Date: 24 Apr 2000 20:36:22
Message: <3904E833.C69DE058@pacbell.net>
What purpose does an inverse tranformation serve (what does it do and
why do we need it) ?
Date: 24 Apr 2000 21:11:06
Message: <chrishuff_99-D161ED.20140424042000@news.povray.org>
In article <3904E833.C69DE058@pacbell.net>, lin### [at] povrayorg
Transform Trans changes pointA into another pointB. If the inverse of
Trans is applied to pointB, you get pointA back. It is just the reverse
of an ordinary transformation.
BTW, I got my new syntax for transform partially working, you can now
embed transform {} blocks in objects and in the vtransform() function.
And the old syntax still works. I haven't made the necessary
modifications to textures yet, though. I might try to get a cleaner way
of doing things, there is currently many similar chunks of largely
duplicated code.
Date: 24 Apr 2000 21:26:00
Message: <3904F3D5.CF178365@pacbell.net>
So if I had an object at <-1,0,-1> the inverse tranformation would now
locate the object to <1,0,1> ?
Date: 24 Apr 2000 21:59:47
Message: <chrishuff_99-50A0BD.21024524042000@news.povray.org>
In article <3904F3D5.CF178365@pacbell.net>, lin### [at] povrayorg
No. The inverse transform moves the point in a way that would undo the
transform. The inverse transform of "translate <-1, 0,-1>" would be
"translate < 1, 0, 1>", but the point being transformed doesn't matter.
The inverse of rotate x*45 is rotate -x*45, the inverse of scale 0.5 is
scale 2, and I don't feel like trying to invert a matrix right now. It
gets more complex with multiple transforms in a row, I think you have to
reverse each one and also reverse their order. The inverse transform
patch makes this juggling of transforms unnecessary.
Date: 25 Apr 2000 07:30:43
Message: <390581e3@news.povray.org>
I think that this patch is not of very much use if we can't get the
transformations from an object. You seldom define the transformations of
an object separately.
  How about a function to get the transformations applied to an object?
Something like:
#declare Trans = transformations(MyObject)
object
{ MyObject
  transform { Trans inverse }
  This would create an instance of MyObject without transformations.
  Of course there's a problem: What if MyObject is a CSG with nested
transformations?
Date: 25 Apr 2000 07:42:48
Message: <chrishuff_99-07B9FB.06454725042000@news.povray.org>
In article <390581e3@news.povray.org>, Warp <war### [at] tagpovrayorg>
> Something like:
> object
> { MyObject
> transformations?
I would really prefer the dot operator instead, it is shorter by 1
character and a lot more flexible(it doesn't have the problems with CSG
transforms).
#declare Trans = transform {transformations(MyObject)}
#declare Trans = transform {MyObject.transformations}
#declare Trans = transform {MyObject.SubObject.transformations}
However, I don't know how easy this would be...it would have to use the
label feature, and there is probably already code that can be adapted to
do the job in MegaPOV. The same thing would be useful for textures and
interior.
This patch is still useful in some cases, though. We could implement
functions to access those variables as a stop-gap measure, but I don't
think that is a good idea...people would begin to use them, and they
would have to be removed later.
I will check out the label code, and see if I can do anything about it.
Date: 25 Apr 2000 10:23:59
Message: <3905aa7f@news.povray.org>
There's another problem. What about this:
box
{ <1,2,3>, <4,5,6>
  rotate x*30
  texture { Whatever }
  rotate y*45
  What will be the transformation got out of that?
  Btw: I have one idea (which has only little to do with this transformations
thing):
  In latex you can attach a label to most items, for example:
\section{Why povray is the best?} \label{First section}
  Then you can refer to that section by writing for example:
For more information, see section \ref{First section}.
  This will substitute the \ref-statement with the appropriate section number
(which may change when adding more section before that one).
  In povray this kind of labeling would just be a shortcut for first
#declaring the thing and then creating an instance of it. It would just
do both things at once.
  Then perhaps you could do something like (not necessarily with this syntax):
box \label{MyBox}
{ <1,2,3>, <4,5,6>
  transform \label{MyBoxTrans}
  { rotate x*30
object { MyBox transform { MyBoxTrans inverse } }
  This would create two boxes. The first with transformations and the second
without.
Date: 25 Apr 2000 12:03:49
Message: <chrishuff_99-2E8B51.11064625042000@news.povray.org>
In article <3905aa7f@news.povray.org>, Warp <war### [at] tagpovrayorg>
> box
> { <1,2,3>, <4,5,6>
>   rotate x*30
>   rotate y*45
transform {rotate x*30 rotate y*45}
There is only one transform struct per object, all transforms are added
into it. The transform struct contains two matrices, this is what made
implementing "inverse" so easy.
>   syntax):
> box \label{MyBox}
> { <1,2,3>, <4,5,6>
>   { rotate x*30
> second without.
Maybe an "identifier" keyword could be added to everything that can be
defined, something like this:
object {...
    identifier local LocalObject
    texture {...
        identifier global GlobalTex
While I think all #declare and #local statements should at least allow a
semicolon ending, I don't think one should be used here. It would be
inconsistent with the other flags/settings.
While something like this might be handy, I don't think it is really
necessary.
Date: 25 Apr 2000 18:10:40
Message: <390617e0@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote...
But if you really cared about the transformations and needed to use them
(and/or their inverse) somewhere, it would be very easy to declare the
transformations separately.  This feature, though useful, is not necessary
for the functionality of Chris' patch.
-Nathan
