POV-Ray : Newsgroups : povray.unofficial.patches : Another post_process idea Server Time
29 Sep 2024 19:24:19 EDT (-0400)
  Another post_process idea (Message 1 to 10 of 34)
Subject: Another post_process idea
Date: 25 Apr 2000 08:20:19
Message: <chrishuff_99-BA61FD.07231725042000@news.povray.org>
How about a color_matrix? It would simply transform the colors of the
image according to a matrix, it should make a lot of effects possible.
This one should be easy enough to implement, I will make it my next
project.
After that, I will try the blur/convolution/displacement matrix(still
not sure if "convolution matrix" is the right name for it).
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Subject: Re: Another post_process idea
Date: 25 Apr 2000 08:51:53
Message: <B5QFORZjezhKLtkTgr2FzuvyFcJQ@4ax.com>
On Tue, 25 Apr 2000 07:23:17 -0500, Chris Huff
I'm not sure what you mean. Would you mind explaining more about what
you have in mind? A hypothetical example would be great.
Thanks,
Glen
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 25 Apr 2000 09:08:30
Message: <chrishuff_99-D28D5E.08112825042000@news.povray.org>
In article <B5QFORZjezhKLtkTgr2FzuvyFcJQ@4ax.com>, Glen Berry
It would be a 3*3 matrix, like this:
<AA, AB, AC,
 BA, BB, BC,
 CA, CB, CC>
resultRed   = AA*inputRed + AB*inputGreen + AC*inputBlue;
resultGreen = BA*inputRed + BB*inputGreen + BC*inputBlue;
resultBlue  = CA*inputRed + CB*inputGreen + CC*inputBlue;
This matrix would not make any change:
< 1, 0, 0,
  0, 1, 0,
  0, 0, 1>
This one would reverse the red and green components of the image:
< 0, 1, 0,
  1, 0, 0,
  0, 0, 1>
and so on.
BTW, I just got it to compile, time for testing. Oh, and another change
I made was allowing post_process to be specified in the camera
statement.(which is where I think it should have been in the first
place) :-)
Date: 25 Apr 2000 21:26:03
Message: <njUGOUFjcnSZ3qj34lbk51m8BluE@4ax.com>
On Tue, 25 Apr 2000 08:11:28 -0500, Chris Huff
><AA, AB, AC,
> BA, BB, BC,
> CA, CB, CC>
How hard would it be to do something like the following?
   resultRed = ( ((R+G+B)/3)^0.95)*1.05
   resultGreen = (R+G+B)/3
   resultBlue = ((R+G+B)/3)^0.9
This gives a fairly close approximation of Selenium Toning.
Or maybe this?
   resultRed = ((R+G+B)/3)^0.67
   resultGreen = ((R+G+B)/3)^0.85
This gives a fairly close approximation of Sepia Toning
Or maybe even this?
   output_Red = 100*sin(R*pi*3)
   output_Green = 100*cos(G*pi*3)
   output_Blue = -100*sin(B*pi*3)
This gives a very wild posterization effect
Note:  For the purpose of these examples, R = the values contained in
the Red channel *after* clipping/normalizing to values between 0 and
1. "G" and "B" refer to the Green and Blue channels in a likewise
manner.
I also wanted to ask if the values you are manipulating in your matrix
are the raw unclipped values, or have they already been clipped? It
might be handy to apply a matrix or a formula to either situation, for
different reasons. The above effects are meant to work with values
constrained between 0 and 1, but if I wanted to control image
contrast, I would need to work with the raw unclipped valiues.
Later,
Glen Berry
Date: 25 Apr 2000 21:42:14
Message: <nuhcgskdd7i2em02o2uri3ev28c51fjemm@4ax.com>
Make sure you provide the option to set the matrix size, the divisor
and the levelling value as well. This will give a lot of
possibilities.
Peter Popov ICQ : 15002700
Date: 25 Apr 2000 21:57:53
Message: <chrishuff_99-42CFE1.21005325042000@news.povray.org>
In article <njUGOUFjcnSZ3qj34lbk51m8BluE@4ax.com>, Glen Berry
> Or maybe this?
> Or maybe even this?
Those would be quite easy to do...but not in color_matrix. They should
all be possible with the specialized isosurface function idea though...
They are the raw, unclipped values. Maybe a clip_colors filter would be
useful, so different versions of each filter don't have to be made.
Date: 25 Apr 2000 22:01:09
Message: <chrishuff_99-E9884C.21040725042000@news.povray.org>
In article <nuhcgskdd7i2em02o2uri3ev28c51fjemm@4ax.com>, Peter Popov
I already have a working version. The matrix dimensions can be whatever
you want, though odd numbers are preferred. The matrix does not have to
be square.
> the divisor
Not implemented yet, I got sidetracked with other filters. It is
planned, though.
Levelling value? I don't understand this one...
Date: 26 Apr 2000 05:25:57
Message: <3906b624@news.povray.org>
Perhaps something like this:
#declare ColoringFunction = function { x*.25+y*.6+z*.15 }
global_settings
{ post_process { pixel_color ColoringFunction(Red, Green, Blue) }
or:
#declare RedFunction = function { ... }
#declare GreenFunction = function { ... }
#declare BlueFunction = function { ... }
global_settings
{ post_process
  { pixel_color <RedFuntion(Red, Green, Blue),
                 GreenFunction(Red, Green, Blue),
                 BlueFuntion(Red, Green, Blue)>
or something similar.
Date: 26 Apr 2000 08:44:03
Message: <chrishuff_99-F9EDE4.07470226042000@news.povray.org>
In article <3906b624@news.povray.org>, Warp <war### [at] tagpovrayorg>
> global_settings
> or:
> global_settings
> { post_process
What I was thinking of was something like this:
global_settings or camera {
    post_process {
        post_function < function {...red function...},
                        function {...green function...},
                        function {...blue function...} >
And there would be additional variables:
r, g, b                   - unclipped RGB colors.
x, y, z                   - intersection point.
u, v                      - UV coordinates.
depth                     - distance to intersection point.
inorm_x, inorm_y, inorm_z - surface normal at intersection point.
pnorm_x, pnorm_y, pnorm_z - perturbed surface normal.
dir_x, dir_y, dir_z       - ray direction(if I succeed in adding it to
the available information).
You could use this filter to do the same thing as the color_matrix
filter, and just about anything else that doesn't require information on
other pixels:
post_function < function {r*AA + g+AB + b*AC},
                function {r*BA + g+BB + b*BC},
                function {r*CA + g+CB + b*CC} >
Another possibility would be to implement these variables as functions
taking two parameters(pixel coordinates), and add h and v variables for
pixel coordinates...the functions would return the information for the
specified pixel. This would be tremendously flexible, and would allow
blurring filters.
Date: 26 Apr 2000 15:14:44
Message: <ur5dgsgctbpg7mva7203jsljrr70icukhu@4ax.com>
On Tue, 25 Apr 2000 21:04:07 -0500, Chris Huff
It's just a constant you add to the weighted sum before you divide it
by the divisor.
