POV-Ray : Newsgroups : povray.unofficial.patches : Bug with post_process and Mac PICT file output Server Time
29 Sep 2024 19:22:01 EDT (-0400)
  Bug with post_process and Mac PICT file output (Message 1 to 4 of 4)
Subject: Bug with post_process and Mac PICT file output
Date: 25 Apr 2000 09:44:00
Message: <chrishuff_99-3B043C.08465925042000@news.povray.org>
Here's an odd problem: when you choose PICT format for the output in
MacMegaPOV(and my personal compile as well), every line in the
post-processed image is off by one. The bottom line is garbage, the top
line is missing, and all lines are moved up by one. This offset might
also occur with image_maps, etc, but I have not tested that yet.(I
rarely use images in my scenes, and usually use PNG or TGA format when I
do)
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Subject: Re: Bug with post_process and Mac PICT file output
Date: 25 Apr 2000 12:19:51
Message: <3905c5a7@news.povray.org>
In article <chrishuff_99-3B043C.08465925042000@news.povray.org> , Chris Huff
> do)
It might be that some MegaPOV code counts from 1 to image height.  Make sure
that when MegaPOV calls MacFile_ReadLine the parameter line_number starts
with 0, not 1.  Then fix the MegaPOV code (not the sysmacpict code as a 0
base is required for it to work with other POV-Ray code).  You do not notice
this problem with other formats because PICT images cannot be loaded line by
line and therefore need a working line counter, while other formats may not
even use it.
      Thorsten
Date: 25 Apr 2000 12:31:20
Message: <3905c858$1@news.povray.org>
In article <3905c5a7@news.povray.org> , "Thorsten Froehlich"
> even use it.
Actually it needs to be -1, not 0 (as MegaPOV sets it).  Just set the inital
line number in DoPostProcess to tmp = -1 .  This is required because the
reading functions are responsible for incrementing the line number.  For the
other formats it just does not matter as they don't use this line number
anyway.  Note that this requirement is based on the function
Read_Rendered_Part in POV-Ray 3.1.
     Thorsten
Date: 25 Apr 2000 17:36:39
Message: <1e9nsdo.1uuhx7i1lnbce0N%smellenbergh@skynet.be>
Will be fixed in MegaPov 0.5. Thanks!
Smellenbergh(s)
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
