POV-Ray : Newsgroups : povray.unofficial.patches : Isosurface feature request Server Time
18 Apr 2026 10:12:57 EDT (-0400)
  Isosurface feature request (Message 1 to 10 of 10)
Subject: Isosurface feature request
Date: 30 Dec 1999 16:15:57
Message: <chrishuff_99-350555.16165130121999@news.povray.org>
If my eval_pattern() function is added to MegaPov, I think it would also
be a good idea to add it as an isosurface function. I have a feeling
that evaluating the pattern directly could be much faster than
evaluating the pigment, but I don't know the isosurface code well enough
to add a function.
Another advantage could be the increased precision, aren't color_maps
limited to 255 levels of color?
An alternative would be to add the ability to call the patterns as
functions, this would require adding a function for each pattern, but
Might be even faster. There probably isn't a significant difference in
speed, though. And patterns which take parameters would have to have
more than the normal 3(x, y, and z), so you couldn't use the usual
pattern syntax. And some patterns(like my object pattern) have a syntax
which would look pretty strange used as a function.
Chris Huff
e-mail: chr### [at] yahoocom
Subject: Re: Isosurface feature request
Date: 31 Dec 1999 05:39:26
Message: <386c87de@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: Another advantage could be the increased precision, aren't color_maps
: limited to 255 levels of color?
  Says who?
Date: 31 Dec 1999 09:30:08
Message: <chrishuff_99-273CA9.09310431121999@news.povray.org>
In article <386c87de@news.povray.org>, Nieminen Juha
>   Says who?
I don't know. Which is why I didn't state it as a fact. :-)
I know they are limited to 255 entries, but I don't know how much
precision a float value derived from a color_map would have. I haven't
taken a close look at that part of the code. But the patterns can return
double precision values, and they don't have to interpret a color_map to
do so. This makes slightly less flexibility, you can't alter the
waveform with a color_map, but could be a lot faster.
Chris Huff
Date: 31 Dec 1999 11:03:37
Message: <386CD3C2.BEF15D5C@gci.net>
You could try this code segment.
#declare P=6; /* this is the number of decimal Places to display*/
#declare CapColor= color <1,.9999999,.2222222,0,0>;
#warning "Vector <"     #warning str(CapColor.red     ,0,P)
#warning ", "           #warning str(CapColor.green   ,0,P)
#warning ", "           #warning str(CapColor.blue    ,0,P)
#warning ", "           #warning str(CapColor.filter  ,0,P)
#warning ", "           #warning str(CapColor.transmit,0,P)
#warning "> "
This gives some fun results if you dont use the key word "color"
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 1 Jan 2000 10:53:31
Message: <386e22fb@news.povray.org>
mr.art <mr.### [at] gcinet> wrote:
: #warning "Vector <"     #warning str(CapColor.red     ,0,P)
: #warning ", "           #warning str(CapColor.green   ,0,P)
: #warning ", "           #warning str(CapColor.blue    ,0,P)
: #warning ", "           #warning str(CapColor.filter  ,0,P)
: #warning ", "           #warning str(CapColor.transmit,0,P)
: #warning "> "
  Take a look at the 'concat' function of povray.
Date: 1 Jan 2000 11:21:29
Message: <386E2977.17D976B4@gci.net>
As this wasn't my work,( I found it in another post) I haven't
adjusted it much. Just added the P variable.
> : #warning "> "
Date: 1 Jan 2000 17:19:09
Message: <386E7D29.2BAD5F3B@xenoarch.com>
First Thing, yes using patterns directly would be slightly faster
by removing per lookup approximately
10 multipulcations / divisions
5 add/subs
2 compares
1 or 2 function calls
(this is done from my color conversion so you can use red/green hf
images, and blending of colors of evalpigment, this is off the top of my
head so
for sake of argument lets triple these numbers)
How ever most patterns use noise which is a couple of magnitudes of more
adds and muls.
so depending on how much turbulence and which pattern you gain anywhere
from 0.01% to 50% gain, the 50% gain is if you use gradient with
no turbulence, might as well use y-floor(y) and possibly get an even
faster speed gain. but i would stay 99% of the functions the speed gain
would be less then %1
note on precision: colors do use floats, but some compilers reduce
doubles
to floats when they are told todo fast math, personally i compile
without fast math.
without the source in front of me i'm not sure if eval pattern does the
turbulence or not, however i don't see it a hard addition, just a
tedious
one. (as pattern in heightfields uses pigments too if i remember right
when i was trying to add a cap to 0..1 capability to use my fractal
terrains i haven't yet ben able to make sure it returns values between 0
and 1 .. i degress)
> >   Says who?
> Chris Huff
Date: 1 Jan 2000 19:11:37
Message: <chrishuff_99-FD1274.19113801012000@news.povray.org>
In article <386E7D29.2BAD5F3B@xenoarch.com>, Matthew Corey Brown
> 5 add/subs
> 2 compares
> head so
> adds and muls.
Hmm, are you sure the numbers would be that small? Per call, perhaps,
but how many times are those functions used? I suppose the only way to
get a real answer would be to add the function and run some tests. Does
anyone have some hints on adding an isosurface function?
> doubles
> without fast math.
Well, when I said that, I was thinking about the precision of the color
blending code, which I don't understand at all.
> turbulence or not
I am fairly certain it does, as well as the other warps and transforms.
As I remember, those are handled in Eval_TPat(), and my patch is
basically an interface to this function.
I am having school break now, and just got back from checking out a
possible new job(pulling traps at a target shooting range nearby), so I
will have some free time. I will take a closer look at that color_map
code, I have been putting that off long enough.
Chris Huff
Date: 1 Jan 2000 20:04:09
Message: <386EA3D7.1A53D563@xenoarch.com>
> > anywhere
> > gain would be less then %1
Not 100% sure but close, noise and especially turbulence has
over a hundred operands a piece (as turbulence calls noise a couple of
times)
yes there is an array in iso_func.c with a string and the function name,
the parse function calls a lookup function to put a pointer to the
function into the function data struct, do a search on isopigment of the
source, its been a year since i wrote it heh, maybe one of the other
patchers that have added more functions then I could correct me and add
the missing data.
> > doubles
> > without fast math.
Basically it does this
T=eval_pattern
CM[x] < T > CM[x+1] (finding x is fast if you have a color map with 2
entries ie {[0 rgb 0][1 rgb 1]} )
rat = (T-CM[x])/(CM[x+1]-CM[x])
then Color=Color[x]*(1-rat)+Color[x+1]*rat
umm i wish i could put it in english but it does a weighted average of
the colors, based on distance of T from the closest entries on the color
map.
A rule of thumb on precsion from basic science lab classes:
The precsion of your final value is the precsion of the coursest data
point.. ie in base 10
2.05 * 1.00000345 = 2.05
but floats are done in binary so its binarary precsion and not decimal
precsion as is done in science. So since the data uses floats or higher
and its all floating point code then the precsion is float.. the color
itself.
> Chris Huff
Date: 1 Jan 2000 20:32:41
Message: <chrishuff_99-026BEE.20324201012000@news.povray.org>
In article <386EA3D7.1A53D563@xenoarch.com>, Matthew Corey Brown -
> the missing data.
Hmn, thanks for the help.
> T=eval_pattern
> map.
Thanks, sounds somewhat similar to my z-buffer code.
If you put it into english, I probably couldn't understand it, no matter
how well you phrased it. :-)
Not that I have problems with english, it is the only human language I
know(although I can barely understand some written spanish, and can get
the sense of some other languages that are related closely enough). I
just find this type of explanation a lot easier to understand.
Chris Huff
