POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOVPlus 0.3 released(with glow effect) Server Time
21 Apr 2026 04:47:00 EDT (-0400)
  MegaPOVPlus 0.3 released(with glow effect) (Message 19 to 28 of 48)
Subject: Re: MegaPOVPlus 0.3 released(with glow effect)
Date: 5 Sep 2000 18:35:12
Message: <chrishuff-FD841A.17365405092000@news.povray.org>
I just uploaded the demo scenes:
http://homepage.mac.com/chrishuff/mpovplus/Demo%20Scenes03.zip
Christopher James Huff
Date: 5 Sep 2000 18:53:01
Message: <chrishuff-DD0E3A.17544305092000@news.povray.org>
In article <39b57274$1@news.povray.org>, "Alan Holding"
<man### [at] freeukcom> wrote:
> Regarding the glow command, is there any chance of making the location and
> color/colour keywords optional?
> Would save my aching fingers a bit of typing.
A better syntax would be:
glow {POSITION, COLOR, AMOUNT
    type TYPE
    turbulence...
The example you gave would confuse POV constantly, and would require the
type to always be specified.
And this wouldn't work very well with light source glows...currently,
the location and color are optional if the glow is specified within a
light source, they take on the values of the light source. With this
syntax, the ones in front of the one being overridden will always have
to be specified.
I could make it so you can't override the position or color of a light
source glow, but I don't want to impose unnecessary limitations and
inconsistencies like that without a good reason.
I could put the amount first...but that would break tradition with the
rest of POV, which seems to always put scalars after floats. I am
reluctant to make design decisions based on typing speed...in fact, I
have considered making the amount specified by a separate keyword.
Date: 5 Sep 2000 18:55:53
Message: <39b579f9@news.povray.org>
>I am reluctant to make design decisions based on typing speed...
Ahh, phooey!
Date: 5 Sep 2000 20:02:46
Message: <chrishuff-F9EA20.19042805092000@news.povray.org>
In article <39b579f9@news.povray.org>, "Alan Holding"
> Ahh, phooey!
You can always use a macro if it is really that important to you...
#macro Glow(Pos, Col, Amt, Type)
    glow {
        location Pos
        color Col
        brightness Amt
        type Type
Glow(< 0, 0, 0>, White, 1, 0)
Date: 5 Sep 2000 23:07:06
Message: <39b5b4da@news.povray.org>
Excellent... May the Valar extend your life and glory to match that of the
Date: 5 Sep 2000 23:08:03
Message: <39b5b513@news.povray.org>
Woohoo! A'rendering I shall go, a'rendering I shall go, la la la la la la,
a'rendering I shall go!
Date: 5 Sep 2000 23:22:16
Message: <39B5B8AA.142D3E3F@hotmail.com>
The link on http://homepage.mac.com/chrishuff/povpatch.html to these has
a space in place of %20, causing an invalid url error in netscape 4.7
Bye
Pabs
Date: 6 Sep 2000 00:27:42
Message: <39B5C7FF.40DE60A5@hotmail.com>
Some probs with them below
particlesystem2.pov has errors or the patch does related to the jitter
keyword in a particle emitter
"direction < 0.2, 0, 0>
//direction < 1, 1, 0>
jitter <----ERROR
particleSystem2.pov:61: error: No matching } in particle_emitter, jitter
found instead.
Returned from renderer (non-zero return value)"
Also ipf.pov, ipf2.pov & others have a problem with #set & #background
(set not used in the file) - think you have mistakenly put a '#' in
front of background (mp5a & pov-official accept background (also camera,
plane, sphere & others) with/without the '#')
"rotate y*25
#background <----ERROR
ipf.pov:20: error: #set cannot assign to uninitialized identifier
background.
also after fixing the above problem in objectEmitter.pov &
particlefountain.pov the following error occured _after_ the first
particle simulation
"jitter 0
drag 0.025
environment object {Floor}, <----ERROR
objectEmitter.pov:43: error: No matching } in particle_system, ,  found
instead.
& this _after_ simulation
"gravity < 0,-0.00981, 0>
iterations 100
time_unit <----ERROR
particleFunnel.pov:52: error: No matching } in particle_system,
undeclared identifier 'time_unit' found instead.
& this
"#if(1)
#declare particleFunc =
function {
particle_system <----ERROR
particlepattern.pov:101: error: No matching } in pigment,
particle_system found instead.
Bye
Pabs
Date: 6 Sep 2000 08:35:19
Message: <chrishuff-5494EE.07370206092000@news.povray.org>
In article <39B5B8AA.142D3E3F@hotmail.com>, Pabs <pab### [at] hotmailcom>
Fixed.
Date: 6 Sep 2000 08:36:28
Message: <chrishuff-7BABC2.07381206092000@news.povray.org>
In article <39b5b4da@news.povray.org>, "Tony[B]"
Er, you're welcome...I think.
