POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOVPlus 0.3.1 Windows version released Server Time
19 Nov 2025 07:12:38 EST (-0500)
  MegaPOVPlus 0.3.1 Windows version released (Message 1 to 10 of 20)
Subject: MegaPOVPlus 0.3.1 Windows version released
Date: 11 Sep 2000 21:47:36
Message: <chrishuff-5E8D70.20492811092000@news.povray.org>
It took longer than I planned(I got delayed by a thunderstorm), and
there are some problems with this release(crashes have been reported
with the particle_system object), but it should be enough for you to
play with the glow patch which seems so popular...
http://homepage.mac.com/chrishuff/povpatch.html
Christopher James Huff
Subject: Re: MegaPOVPlus 0.3.1 Windows version released
Date: 12 Sep 2000 01:04:24
Message: <01c01c76$c8e8ea00$677889d0@daysix>
Major bug.  Whenever I render any scene with blobs in it MP+.31 crashes. :(
Here's the error code:
MEGAPOV05APLUSMOD031 caused an invalid page fault in
module MEGAPOV05APLUSMOD031.EXE at 016f:0045807f.
Registers:
EAX=00937dc0 CS=016f EIP=0045807f EFLGS=00010203
EBX=00000001 SS=0177 ESP=0187ff04 EBP=0187ff8c
ECX=00000000 DS=0177 ESI=00937dc0 FS=19cf
EDX=00000000 ES=0177 EDI=00967478 GS=0000
Bytes at CS:EIP:
8b 48 08 85 c9 74 06 8b 50 0c 89 51 0c 8b 48 0c
Stack dump:
00457fa9 00937dc0 00967478 0045c56c 00937dd8 004fa294 00000336 00967dd8
00967dd8 0045c599 00967518 00000000 00000000 0046ddbe 00973e98 00000000
I've pretty much narrowed it down to only blobs, though isosurfaces might
also me a problem.  Fix it quick!!  :)
Please?
H.E. Day
Date: 12 Sep 2000 01:36:57
Message: <39bdc0f9@news.povray.org>
Yeah, it'll do that. :( It was very apparent with the particle_system too.
That creates a bunch of blobs, doesn't it? Interesting... I'd recommend not
using 0.3.1 with blobs until someone figures it out.
Date: 12 Sep 2000 04:27:41
Message: <39BDE939.A2AD59F1@schunter.etc.tu-bs.de>
I just tried out the new parameters of the glow effect and found them quite
useful.  There is much more room for variations now.
Is there some kind of translation for the old syntax to the new? I tried to
achieve the old effects with the new version, but i did not succeed.  The old
one always looked more foggy.
Date: 12 Sep 2000 06:57:34
Message: <chrishuff-7563D9.05592512092000@news.povray.org>
In article <39BDE939.A2AD59F1@schunter.etc.tu-bs.de>,
> quite useful.  There is much more room for variations now.
> tried to achieve the old effects with the new version, but i did not
> succeed.  The old one always looked more foggy.
Use "type" instead of "glow_type", the existing types have not changed.
Use "warp {turbulence ...}" instead of "turbulence ...". Use "color
COLOR*GLOW_AMOUNT" for your color, since the glow amount was dropped(it
was 3 unnecessary multiplications per glow per trace, and wasn't very
useful). Don't use radius, falloff_exponent, or size, not using them
will turn them off.(and size doesn't work properly in all situations)
That should be everything...
Date: 12 Sep 2000 07:06:54
Message: <chrishuff-F67778.06084612092000@news.povray.org>
In article <01c01c76$c8e8ea00$677889d0@daysix>, "H. E. Day"
Well, that tells me where to look for the problem with my
particle_system...(which is actually a hybrid object using the blob code
for rendering). I am guessing this is a bug that exists in MegaPOV 0.5
and earlier versions of MP+ as well, it just didn't show up until I
plugged some memory leaks.
Date: 12 Sep 2000 07:20:08
Message: <39BE11A5.D06982B9@schunter.etc.tu-bs.de>
Thanks, it works perfect now.
Date: 12 Sep 2000 17:52:15
Message: <39BEA535.BF3D5DD3@totalise.co.uk>
Hmmm... the only way I could get the new glow to work was by putting and
object (box{0,0}) at the end of the scene file. If I didn't put a dummy
object at the end of the file the error "object or directive expected
but end of file found instead" comes out even with just a camera and a
"glow {}" statement. Ver 3.0 allowed the glows to be rendered without
any other objects but a camera in the scene.
Keith
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 12 Sep 2000 18:18:16
Message: <chrishuff-5D0FDB.17200712092000@news.povray.org>
In article <39BEA535.BF3D5DD3@totalise.co.uk>, Keith Hull
That's because glows aren't objects. And, um, version 0.3 didn't
consider them objects either, the same error would show up. In fact,
some of the work done between 0.3 and 0.3.1 was to make them behave more
like objects...it obviously wasn't complete, but they should now be
allowed in some places they weren't before(in unions, for example). I
still have to make them transform along with light sources and CSG
objects, though.(maybe they should be attachable to any object...)
My best guess is that you were using glows in light sources before, and
"naked" glows now. Since light sources are objects, that error didn't
show up.
Date: 12 Sep 2000 18:39:53
Message: <01c01d09$d01f5780$ab7889d0@daysix>
I'm hoping you can fix it before my time runs out for the IRTC. :)
You can, right?
H.E. Day
