POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOVPlus 0.3.1 Windows version released Server Time
15 Sep 2025 12:05:11 EDT (-0400)
  MegaPOVPlus 0.3.1 Windows version released (Message 11 to 20 of 20)
Subject: Re: MegaPOVPlus 0.3.1 Windows version released
Date: 12 Sep 2000 21:03:39
Message: <39bed26b@news.povray.org>
I was comparing source from Megapov 0.5a and MP+ .31 and I did notice
something particularly conspicuous.
frame.h
from MP 0.5a:
struct Blob_Pattern_Data_Struct
  VECTOR center;/*Also point A if component is cylinderical*/
  VECTOR pointB;/*point B if component is cylinderical*/
  DBL radius;
  DBL strength;
  DBL falloff;
  PIGMENT * pigment;
  TRANSFORM * transform;
/*  int transformed;*/
/*NOTE: do benchmark to find overhead of transforms.
Use this to avoid unnecessary ones if overhead too much.*/
  int type;/*0 for spherical, 1 for cylinderical. Change to enum?*/
  int function;/*The density function. 0 for standard blob. Change to
enum?*/
  BLOB_PATTERN_DATA * next;
// from MP+ .31
typedef struct Blob_Pattern_Data_Struct BLOB_PATTERN_DATA;
  DBL radius;
  DBL strength;
  DBL falloff;
  PIGMENT * pigment;
  BLOB * blob;
  TPATTERN * pattern;
  int inverse;
  int type;/*0=sphere, 1=cylinder, 2=box, 3=pattern, 4=blob. Change to
enum?*/
enum?*/
This is the main thing that kept me from making a servicable Windows build.
There just happens to be a Windows data structure of the name BLOB. I don't
know how Jetlag handled this. Or whether it has anything to do with
anything.
http://www.capital.net/~hhawkins
Date: 12 Sep 2000 22:04:54
Message: <chrishuff-F48D35.21064612092000@news.povray.org>
In article <39bed26b@news.povray.org>, "Halbert" <hha### [at] capitalnet>
...snip...
> build. There just happens to be a Windows data structure of the name
> BLOB. I don't know how Jetlag handled this. Or whether it has
> anything to do with anything.
That is part of the code for allowing blob objects to be used with the
blob pattern, it has nothing to do with the rendering, creating, or
destroying of blob objects which seems to be the problem. And that
structure exists in other POV versions too, it is the name of the blob
object's struct. It is normally typedef'ed in blob.h, but that
definition is moved to frame.h in MegaPOVPlus to allow the blob pattern
to use it without running into multiple definitions.
Christopher James Huff
Date: 12 Sep 2000 22:39:38
Message: <39bee8ea@news.povray.org>
I see. Something to keep in mind next time I try to compile it.
Date: 13 Sep 2000 01:43:48
Message: <39bf1414@news.povray.org>
The BLOB keyword does make all the Windows GUI files blow up. This is new
because frame.h is included in them, while blob.h is not. I usually just
change it globally from BLOB to BLOBA or something since my main goal to
just get a compile anyway. There are other issues to deal with before it'll
compile, but most are trivial.
Date: 13 Sep 2000 02:02:22
Message: <39bf186e$1@news.povray.org>
Actually there is a very simple way to fix it [kludge], in frame.h just
change:
#define BlobPatternPatch
-- to: --
#ifndef POVWIN_FILE
#endif
Now, if only the blob bug was that easy...
Date: 14 Sep 2000 06:45:01
Message: <chrishuff-A8CD66.05465514092000@news.povray.org>
In article <01c01d09$d01f5780$ab7889d0@daysix>, "H. E. Day"
<Pov### [at] aolcom> wrote:
> I'm hoping you can fix it before my time runs out for the IRTC. :)
> You can, right?
I'm working on it when I can. Unfortunately, school is now taking most
of my time.
Date: 14 Sep 2000 06:47:24
Message: <chrishuff-2D5FD4.05491814092000@news.povray.org>
In article <39bf186e$1@news.povray.org>, "Jetlag"
> change:
If you can call that fixing...you just disabled the blob pattern on
Windows machines.
I would change the name "BLOB" to something like "BLOB_OBJ" or
"META_BALL". Or maybe "GOO_BALL".
Date: 14 Sep 2000 11:03:53
Message: <39c0e8d9@news.povray.org>
> Windows machines.
Nope, it just disables the blob pattern initialization strictly within the
Windows GUI files; POVWIN_FILE is only defined in those files.  But when
other files include it, it still in turns on the blob pattern patch. I even
went ahead and tested your demo scenes, just in case, and they work
perfectly.
Date: 14 Sep 2000 11:48:48
Message: <39c0f360@news.povray.org>
I believe I like "GOO_BALL". I had already done it with the disabled blob
pattern but your right; it really isn't much of a fix. Maybe one day I might
want to try experimenting with the blob pattern.
Date: 14 Sep 2000 17:09:10
Message: <chrishuff-CDF16A.16110314092000@news.povray.org>
In article <39c0e8d9@news.povray.org>, "Jetlag" <bga### [at] microsoftcom>
> within the Windows GUI files; POVWIN_FILE is only defined in those
> files.  But when other files include it, it still in turns on the
> blob pattern patch. I even went ahead and tested your demo scenes,
> just in case, and they work perfectly.
Oh, ok...I will include that fix in my code then. I still think BLOB_OBJ
or something would be better, but it is too much for me to do right
now(my text editor supports regular expressions and multi-file
operations, but I don't...yet).
