POV-Ray : Newsgroups : povray.unofficial.patches : My personal wishlist Server Time
15 Sep 2025 02:20:23 EDT (-0400)
  My personal wishlist (Message 68 to 77 of 77)
Subject: Re: C++ (was:Re: My personal wishlist)
Date: 1 Mar 2000 01:17:23
Message: <38BCB726.7352E9E9@geocities.com>
Thorsten Froehlich wrote:
> In article <38BBF253.DD031485@pacbell.net> , Ken <tyl### [at] pacbellnet>
> wrote:
> > It is not really so much that they are unwilling to discuss this with
> > you it's just that your timing is not good. POV-Ray v3.5 isn't even
> > out the door yet and there is still work to be done on it before it
> > is ready. Any discussions you may wish to hold now would not be timely
> > and would only distract them from what they are working on now.
> > Thorsten's somewhat cryptic reply was his attempt to let you know that
> > they do not want to discuss it now.
> Exactly.  I wish I could write as short and still understandable in English
> as Ken does...
>       Thorsten
And I wish that I were as functionally bilingual as Thorsten is. Sigh.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Subject: Re: C++
Date: 1 Mar 2000 05:35:46
Message: <38bcf281@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: Exactly.  I wish I could write as short and still understandable in English
: as Ken does...
  Me too! When Ken decides to write something in a very "official tone of
voice", he writes (IMHO) extremely good english. I hope I'll learn someday
that much about the english language.
Subject: Re: My personal wishlist
Date: 1 Mar 2000 05:36:56
Message: <38bcf2c7@news.povray.org>
Isn't there some kind of proximity patch? Can't it be used for displacement
calculations?
Date: 1 Mar 2000 07:17:03
Message: <chrishuff_99-C36264.07183701032000@news.povray.org>
In article <38bcf2c7@news.povray.org>, Nieminen Juha
> displacement calculations?
I wrote a proximity pattern which is included in MegaPOV, it calculates
a value which depends on the distance from the surface of an object by
shooting rays at it...I am not sure how good it would be for
displacements though. It might just be too slow for an isosurface,
unless it could be calculated once and output as a density file.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 1 Mar 2000 08:04:14
Message: <38bd154e@news.povray.org>
Obviously, creating a density file from an object is trivial.  Once you
have that, you can relatively easily perform a filter of some kind that fills
in the voxels with a number corresponding to their distance from voxels
containing the surface of the object, then build an isosurface with that.
But it'll take lots and lots of memory, probably more than the mesh.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 1 Mar 2000 20:08:54
Message: <slrn8brfh1.ps.sjlen@zero-pps.localdomain>
On Thu, 24 Feb 2000 22:44:23 +0200, Peter Popov wrote:
>With time I've compiled a list of features I would be happy to see in
>POV-Ray. I think it wouldn't hurt if I posted it here.
I'd like to add one to the list:
scale_map
If not used scale an object as normal, but if used eg.
box{
    <-1,-1,-1>,<1,1,1>
    pigment {Blue}
    scale_map {
               gradient y
               [0.0    1    ]
               [0.25   1    ]
               [0.26  0.75  ]
               [0.74  0.75  ]
               [1.0   1     ]
it'd pinch the object in at the center, all the way round,  being scale 1 at
y*1 scale 0.75 from y*0.5 to y*-0.5, and would be back at one again from there
to y*-1.
It'd be really good if you could add more than one of these to an object, and
hopefully be able to add them to CSG objects not only single primitives.
I've thought about this many times, and hope it's a viable addition to the
current features in POV/MegaPOV.
 12:17am  up  5:22,  3 users,  load average: 1.00, 1.00, 1.00
Date: 2 Mar 2000 00:47:46
Message: <38be0082@news.povray.org>
Chris Huff wrote in message ...
Use eval_pattern() or eval_pigment() on the proximity pattern to scan the
image and output the voxels to a df3 file.
Mark
Date: 2 Mar 2000 04:45:15
Message: <38be382a@news.povray.org>
This is non-uniform scaling and not possible in raytracing.
  Note 1: Well, strictly theoretically speaking it _is_ possible, but it
would be prohibitively slow.
  Note 2: AFAIK non-uniform scaling is not implemented in _any_ renderer.
In most scanline renderers there's an option to scale object seemingly
non-uniformly, but it's not true non-uniform scaling; it just moves the
vertices of the triangles. A true non-uniform scaling would bend the
triangles. In raytracing even this "hack" wouldn't help since objects have
no vertices, but are completely mathematical entities.
Date: 2 Mar 2000 05:39:45
Message: <38BE43C0.F01392A@pacbell.net>
Ken wrote:
> Here is my little wish list - tee hee !
> 1.) displacement mapping
For those interested in online resources for displacement mapping -
http://www.computer.org/cga/cg1998/g2044abs.htm
http://www.education.siggraph.org/materials/HyperGraph/mapping/displace.htm
http://graphics.stanford.EDU/papers/displace/gamma-corrected/
Date: 2 Mar 2000 09:27:00
Message: <38BE7A46.B56C4051@gci.net>
Here is my short list that I haven't seen anything
about:
	 gel{ color_information, opacity_value }
	|gel_map{filetype "FileName", opacity_value }
This would allow the application of many different
affects. i.e. filters, ghost images and such.
In my mind this would be even more useful than
camera {... normal{...}}
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
